Updated on 2026-11-24 GMT+08:00
Viewing O&M To-Dos in the O&M Overview
During routine O&M, O&M personnel need to frequently handle O&M to-dos, such as incident tickets, aggregated alarms, and to-do tasks, and analyze statistics of applications and resources managed by the accounts. However, these tasks are usually scattered in different systems, resulting in low O&M efficiency. To improve O&M efficiency and simplify O&M processes, O&M personnel can use COC to centrally query and trace the O&M to-dos, and query statistics such as applications and resources managed by the accounts.
O&M Overview
  1. Log in to COC.
  2. On the COC Overview page, check the number of pending incidents, pending alarms, my to-dos, applications, and resources in the O&M Overview area.
    In the O&M overview area, other cloud resources and IDC resources are not affected by any Huawei Cloud region.
    Figure 1 Tracing O&M transactions
    If O&M Overview is not displayed on the Overview page, perform the following operations:
    1. Click Custom Settings in the upper right corner.
    2. On the displayed page, toggle on O&M Overview.
    3. Click OK.
  3. Click the corresponding statistics to go to the corresponding O&M task page.
    Table 1 Module description
    Module
    Pending Incidents
    Collects the total number of pending incident tickets.
    After you click it, the Fault Management > Incidents > Pending tab page is displayed.
    Pending Alarms
    Collects the total number of pending alarms.
    After you click it, the Fault Management > Alarms > Aggregated Alarms > Unhandled Alarms tab page is displayed.
    My To-Dos
    Collects the total number of to-do tasks.
    After you click it, the Task Management > To-Do Center > Pending tab page is displayed.
    Applications
    Collects the total number of applications under the account.
    After you click it, the Resources > Application and Resource Management > Applications tab page is displayed.
    Huawei Cloud Resources
    Collects the total number of Huawei Cloud resources under the account.
    After you click it, the Resources > Application and Resource Management > Resources tab page is displayed.
    Other Cloud Resources
    Collects the total number of other cloud resources managed by the account.
    IDC Resources
    Collects the total number of imported IDC resources under the account.
Helpful Links
Data in the O&M Overview area comes from various O&M tasks. For details about transaction processing, see the following:
