Help Center/TaurusDB/User Guide/Suggestions on TaurusDB Instance Selection
Updated on 2025-12-08 GMT+08:00
Overview
Before purchasing a TaurusDB instance, consider factors such as the price, performance, workload capacity, and service scenario to choose the right one for your needs. This section describes the differences between types, billing modes, and storage types of TaurusDB instances, helping you select the most suitable instance.
Storage Engine
By default, TaurusDB uses the InnoDB storage engine to provide high-performance and reliable transaction processing. The TaurusDB kernel provides functions such as parallel query, database/table recycle bin, hot row update, and multi-tenancy. It is widely used in high-performance and high-concurrency scenarios.
Storage Types
TaurusDB provides two storage types: DL6 and DL5. The table below explains their key differences to help you choose the best option for your needs.
Table 1 Storage type description
Storage Type
Characteristic
Applicable Scenario
DL6
The shared storage is the default storage type for TaurusDB instances created before July 2024.
DL6-based instances achieve zero RPO with a 3-AZ deployment and deliver better performance and higher peak throughput.
Core application systems that are sensitive to performance and have demanding requirements on storage I/O during peak hours, such as those in finance, e-commerce, government, and gaming
DL5
The new storage type uses Huawei Cloud's hardware and network infrastructure technologies, ensuring that DL5-based instances maintain the same high availability (zero RPO in the 3-AZ deployment) as DL6-based instances. Although the peak performance of DL5-based instances may be a bit less than what you get with DL6-based instances, the cost per unit of capacity is a lot less.
CPU-intensive sub-core business systems, or application modules that need to minimize costs
Billing Modes
TaurusDB provides three billing modes, yearly/monthly, pay-per-use, and serverless billing, to meet your requirements in different scenarios.
Table 2 Comparison of billing modes
Billing Mode
Yearly/Monthly
Pay-per-Use
Serverless
Payment
Prepaid
Billed by the required duration specified in your order
Postpaid
Billed for what you use
Postpaid
Supported Instance Type
  • Single-node
  • Cluster
  • Single-node
  • Cluster
  • Multi-primary
Serverless
Billing Cycle
Calculated by the second but billed every hour
Billing Item
Instance specifications (vCPUs and memory), storage space, backup space, EIP, and monitoring by seconds
Compute, storage space, backup space, EIP, and monitoring by seconds
Billing Mode Change
Can be changed to pay-per-use.
The change is only applied after the yearly/monthly subscription expires. For details, see Yearly/Monthly to Pay-per-Use.
Can be changed to yearly/monthly. For details, see Pay-per-Use to Yearly/Monthly.
N/A
Applicable Scenario
Recommended for resources expected to be in use long-term. A cost-effective option for scenarios where the resource usage duration is predictable.
Good for short-term, bursty, or unpredictable workloads that cannot tolerate any interruptions, such as applications for e-commerce flash sales, temporary testing, and scientific computing.
The instance capacity automatically changes based on application requirements.
The table below lists the billing items.
Table 3 Billing items
Billing Item
Billing Factor
(Mandatory) DB instance
You are billed for the selected instance specifications, including vCPUs, memory, and nodes.
vCPUs, memory, and number of nodes
(Mandatory) Storage
Pre-purchased storage is billed on a yearly/monthly basis.
However, if the actual usage exceeds your purchased storage, you will be billed for additional storage on a pay-per-use basis.
Storage space, which is billed based on the unified standard
(Mandatory) Backup space
TaurusDB provides free backup space equal to the amount of your purchased storage space.
After the free backup space is used up, charges are applied based on the backup space pricing details. Pricing is listed on a per-hour basis, but bills are calculated based on actual usage.
Backup space, which is billed based on the unified standard
(Optional) EIP bandwidth
  • TaurusDB instances can be accessed through a public network, and traffic fees are generated accordingly.
  • You are not billed for traffic generated through a private network.
Bandwidth, traffic, and EIP reservation (An EIP is required if a DB instance needs to access the Internet.)
EIP for a yearly/monthly DB instance: billed by bandwidth
(Optional) Monitoring by seconds
TaurusDB provides monitoring every 60 seconds for free, but you are billed for monitoring by seconds. Its pricing is listed on a per-hour basis, but bills are calculated based on actual usage.
Monitoring interval, which is billed based on the unified standard
(Optional) HTAP instance
If you create a standard HTAP instance for a TaurusDB instance, you will be billed for the HTAP instance.
Instance specifications and storage type
(Optional) Cross-region backup
If cross-region backup is enabled, you will be billed for backup space and network traffic required for dumping cross-region backups.
Backup space and network traffic required for dumping cross-region backups
(Optional) Proxy instance
Proxy instances are free.
N/A
(Optional) DRS migration
If you use Data Replication Service (DRS) for data migration, you will be billed based on the DRS pricing standard.
For details, see DRS Billing.
Table 4 Billing items
Billing Item
Billing Factor
(Mandatory) Storage
You are billed for database storage.
  • DB instances can be accessed through a public network, and traffic fees are generated accordingly.
  • Billing by bandwidth: bandwidth fee + EIP reservation fee
  • Billing by traffic: traffic fee + EIP reservation fee
  • Shared bandwidth added: bandwidth fee + EIP reservation fee
Enabling monitoring by seconds will incur additional fees. Its pricing is listed on a per-hour basis, but bills are calculated based on actual usage.
N/A
Table 5 Billing items
Billing Item
Billing Factor
DB instance
You are billed for the selected instance specifications. The billing starts immediately after the instance is purchased.
You do not need to select storage when purchasing a DB instance. Storage will be scaled up dynamically based on how much data needs to be stored. It is billed hourly on a pay-per-use basis.
Backup space
TaurusDB provides free backup space equal to the amount of your used storage space. If the backup space usage exceeds 100% of your provisioned database storage, the additional part will be billed based on the backup pricing.
(Optional) Public network traffic
Instance Type
TaurusDB supports cluster, serverless, multi-primary, and single-node instances. You can select an instance type based on your service scenario and scale. For details, see Table 6.
Table 6 Instance type description
Instance Type
Highlight
Applicable Scenario
Cluster
Compatible database version: 8.0
Node: 1 primary node + 1 to 15 read replicas
  • The primary node processes read and write requests, and the read replicas process only read requests.
  • If the primary node becomes unavailable, TaurusDB automatically fails over to a read replica.
Medium- and large-sized enterprises in the Internet, taxation, banking, and insurance sectors
Single-node
Node: 1 primary node + 0 read replicas
Single-node instances do not involve data synchronization between nodes and can easily ensure atomicity, consistency, isolation, and durability of transactions.
Development and testing of microsites, and small and medium enterprises, or learning about TaurusDB
Serverless
Node: 1 primary node + 0 to 7 read replicas
Scenarios where capacity needs to be automatically expanded based on services
Multi-primary
Node: 2 to 63 primary nodes + 0 read replicas
Such an instance can process multiple reads and writes, delivering excellent read/write performance at high concurrency.
Scenarios where high concurrent write performance is required
Instance Specifications
There are general-purpose and dedicated specifications for pay-per-use and yearly/monthly TaurusDB instances, as listed in Table 7. For a serverless instance, you do not need to select the instance specifications. You only need to specify a compute range. A serverless instance is billed by TCU. 1 TCU is approximately equal to 1 vCPU and 2 GB of memory.
Table 7 Instance specifications
Supported CPU Architecture
Applicable Scenario
General-purpose
x86
The vCPUs and memory are shared with other general-purpose instances on the same physical machine. vCPU usage is maximized through resource overcommitment. General-purpose instances are cost-effective.
Scenarios where stable performance is not critical
Dedicated
x86 and Kunpeng
Your instance gets dedicated vCPUs and memory, so the performance is stable. It is not affected by other instances on the same physical machine.
Scenarios that require stable performance
Functions Supported by Different Instance Types
Table 8 Reference for instance type selection
Reference
Single-node
Cluster
Serverless
Multi-primary (OBT)
Specification change
Changing the vCPUs and Memory of a DB Instance or Node
x
x
Changing the Compute Range
x
x
x
Changing the Storage Space of a DB Instance
Supported only by yearly/monthly instances
x
x
Configuring Autoscaling for a DB Instance
x
x
Version upgrade
Upgrading the Minor Version of a DB Instance
x
Backup and restoration
Data Backups
x
Data Restorations
x
Data migration
Migrating Data to TaurusDB Enterprise Edition (OBT)
x
x
x
Proxy instance
Changing Configurations of a Proxy Instance
Upgrading the Kernel Version of a Proxy Instance
DBA Assistant
Performance Monitoring
x
Problem Diagnosis
x
SQL Analysis and Tuning
x
Security and encryption
Configuring SSL for a DB Instance
x
Enabling TDE for a DB Instance
x
Cold and hot data separation
Configuring a Cold Table
x
x
x
HTAP analysis
What Is HTAP Standard Edition?
x
x
Tag
Tag Management
