Creating a Batch Server Migration Plan
Preparations
- Prepare a HUAWEI ID or an IAM user that has the permissions to access MgC. For details, see Preparations.
- Create an application migration project.
- Discover source servers and collect their details. MgC provides three methods to meet your requirements in different scenarios.
- If your source servers are on a cloud platform, such as Alibaba Cloud, Huawei Cloud, AWS, Tencent Cloud, Google Cloud, or Azure, you are advised to perform an online discovery. You can also manually add the server details to MgC.
- If your source servers are in an on-premises IDC or vCenter, you can perform an intranet discovery. MgC enables you to scan for servers by network range or VMware vCenter Server. You can also manually add the server details to MgC.
- Install the MgC Agent in the source intranet environment. For details, see Installing the MgC Agent on Windows. Then log in and connect the MgC Agent to MgC.
- Migration plans can be created only in the AP-Singapore and TR-Istanbul regions.
- Only one migration workflow can be created for a migration plan.
- A migration plan can only include source servers from the same platform.
- A server can only be included in one migration plan.
- A migration plan can include a maximum of 100 servers.
For more information, see Constraints on Server Migration.
Step 1: Create a Migration Plan
- Sign in to the MgC console. In the navigation pane, under Project, select your application migration project from the drop-down list.
- In the navigation pane, choose Migration Plans (NEW).
- Click Create Migration Plan.
- Set migration plan parameters based on Table 1.
- Click Confirm. The migration plan is created, and the page for selecting source resources is displayed.
Step 2: Select Source Resources
- On the Select Source Resources page, from the Source Platform drop-down list, select the platform where your source servers are located.
The subsequent procedure depends on the source platform. Ensure that all servers included in the plan come from the same platform.
- Click Add.
- Select the source servers to be migrated together and click Confirm.
The source servers included in this plan will be migrated using the same migration workflow. The same migration settings, such as the VPC, subnet, and security group settings, will be applied to these source servers.
- Click Next to open the Check Migration Readiness page.
Step 3: Check Migration Readiness
- Configure server credentials. There are two methods for you to do this.
The credentials you provide must have sufficient permissions, so the MgC Agent can collect necessary server details. The requirements for server credentials are as follows:
- Linux: root and its password
- Windows: administrator and its password
- Manual addition: You can choose this method if you configure credentials for a small number of servers. For more information, see Adding Resource Credentials.
- Batch addition: You can choose this method if you configure credentials for a large number of servers.
- On the Check Migration Readiness page, click Associate Credentials above the list of servers to be migrated to download the template for configuring credentials in batches. Open the template file, enter the credential information (username and password) of all servers in the current migration plan, and save the file.
- Import the saved template file to the MgC Agent you connected to MgC. The system automatically configures the MgC Agent and credentials for the servers.
- On the Check Migration Readiness page, in the list of servers to be migrated, click Configure in the MgC Agent column to configure an MgC Agent for each server.
- Configure the parameters listed in Table 2.
Table 2 Parameters for configuring migration readiness check Parameter
Configuration
OS Type
Set this parameter based on the source server OS type.
MgC Agent
Select the MgC Agent installed in the source environment.
Access IP Address
Specify the IP address for accessing the source server. You can specify a public or private IP address. After the migration readiness check is passed, the IP address you specify here will be used for migration.
Access Port
Enter the accessible port of the source server. This port is used for deep collection and subsequent migration.
- The port defaults to 5985 for Windows. You can change it to any port that is accessible on the source server.
- The port defaults to 22 for Linux. You can change it to any port that is accessible on the source server.
To change the connection ports of source servers in batches, use the Change Port button above the list.
Credential
Select the server credential added to the MgC Agent. If batch credential association is performed, the system automatically fills in the credential, and you do not need to select it.
- Click Confirm. The system checks whether the source server can be accessed using the information you provide and whether the server can be migrated. If Completed shows up in the Migration Readiness Check column, the source server can be migrated.
If the check fails, move the cursor to Check failed in the Migration Readiness Check column to view the failure cause. After rectifying the fault, click Check Again.
- After all the source servers pass the readiness check, click Next to configure target servers.
Step 4: Configure Target Servers
There are two methods for configuring target servers.
If you have servers on Huawei Cloud, you can associate them with source servers for receiving migrated data.
- On the Configure Target page, select Associate existing target servers for Configuration Method.
- In the Target Region drop-down list, select the region where the existing target servers are located. For Project, the default IAM project in the selected region is used.
- Locate a source server and click Associate Target in the Operation column.
- Select the desired target server and click Confirm.
You can define target server specifications and allow the system to purchase target servers as part of the migration process.
- On the Configure Target page, select Purchase new target servers for Configuration Method.
- Configure target servers using any of the following methods:
- Method 1: Generating target recommendations. The system can provide recommendations for Huawei Cloud server sizes tailored based on the specifications of the source servers. If the recommended configurations do not align with your requirements, you can make changes as necessary. In the migration process, the system will automatically purchase target servers based on your settings.
- In the source server list, select the ones for which you want to generate target recommendations. Then click Generate Target Recommendations above the list.
- Configure an assessment policy based on Table 3.
Table 3 Settings used for computing target recommendations Parameter
Priority
Preferences
Configure your preferences for target servers. The system will prioritize your preferences and try to match them first during the recommendation process. For details about how the system recommends appropriate target resources, see How Does MgC Generate Target Recommendations?
- Server Types (Optional)
- Server Series (Optional)
Select the server series you prefer. The system will generate recommendations based on your preferred server types and series.
NOTICE:If you select Display only series allowed on DeHs, Server Types will be dimmed, and the server series allowed on DeHs in the target region will be listed.
- System Disk (Optional)
- Data Disk (Optional)
- Sizing Criteria
Choose the criteria that the system will use to generate server recommendations.
- If you select As-in on source, the system will recommend target servers with the same or similar CPU and memory capacity as the source servers.
- If you select Performance-based, you need to perform a performance collection for the source servers, and then set assessment parameters. The system will then recommend target servers with your desired CPU and memory capacity.
NOTICE:
The more performance data is collected, the more accurate the recommendations are. The collection of server performance data should take no less than seven days.
- Click Confirm. If Configured shows up in the Target Configuration column, the target recommendations are generated. You can check the recommended configurations in the next two columns.
- Method 2: Defining target server specifications. You can manually configure target server specifications. Before proceeding with this method, carefully assess any associated risks. It is also essential to ensure that the chosen specifications meet your system requirements and compatibility standards.
- In the source server list, select the servers for which you want to manually configure target servers. Then click Configure Target above the list. Alternatively, click Configure Target in the Operation column.
- In the Target Specifications area, select the target server specifications as required.
- In the Target Disks area, select a storage type and size for each target server disk.
- Click Confirm. Manual will appear in the Target Configuration column.
- Method 3: Importing target server configurations. You can export the server records, configure target server flavors, disks, and images, and then import the records back. Some technical expertise is needed for this process.
- In the list of source servers, choose Export/Import Target Configuration > Export Target Configuration to download the server records as an Excel file to the local PC.
- Open the exported file. On the first sheet named servers, the blue columns (A to G) indicate the source server information, which does not need to be modified. The yellow columns (H to K) indicate the target server information, which needs to be configured.
- Configure the target server information (in columns H to K) according to Table 4.
Table 4 Parameters in columns H to K Parameter
Configuration
flavor
Specify a flavor for each target server. The second sheet flavors lists the flavors in S (general-purpose) and C (computing-plus) server series available in the target region. Choose a proper flavor and copy the flavor name to this cell.
NOTE:If a source server has been assessed, the recommended flavor is included in the exported file. If a source server has not been assessed, its flavor field is empty.
disks(name,osDisk,type,capacity;)
Enter the information about all disks. Separate multiple disks with semicolons (;). You must specify the name, function (system disk or not), type, and size for each disk. Separate these items with commas (,). Specify a disk size as a numeric value without a unit. The default unit is GiB.
Example: /dev/sda,true,SAS,1024;/dev/sdb,false,SAS,2046
NOTE:If a source server has been assessed, the recommended disk specifications show up in the exported file. If a source server has not been assessed, the source disk specifications remain in this column, but the disk type changes to SAS by default.
image_type
Enter an image type. The options are:
- public: public image
- private: private image
- shared: shared image
Enter an image name. You can view all images available in the target region on the third sheet images.
- After configuring a target server for each source server, save the Excel file. Return to the MgC console. Choose Export/Import Target Configuration > Import Target Configuration above the list of source servers.
- In the displayed dialog box, click Access OBS.
- Select a bucket and upload the Excel file to the bucket.
- After the upload is successful, return to the MgC console. In the Import Target Configuration dialog box, select the file stored in the OBS bucket from the drop-down list.
- Click Confirm to import the target server configurations.
- If the flavor field is empty in a row, this row will be ignored during the import.
- If the disk or image field is left empty in a row, the source server's disk and image information is used during the import.
- If the number in the disk field in a row is inconsistent with what the source server actually has, an error message is reported, indicating that the disk numbers are inconsistent.
- If in a row, the disk type conflicts with the flavor, an error message will be reported, indicating that the disk type is incorrect.
- (Optional) Configure an image to define the OS for target servers. Before proceeding with this method, carefully assess any associated risks. It is also essential to ensure that the chosen image meets your system requirements and compatibility standards.
- In the server list, select the source servers and click Configure Image above the list.
- On the displayed page, choose an image type, an OS, and an OS version and click Confirm. If a target server has a system disk smaller than what defined in the image you choose, configuring the image will fail for that server.
- (Optional) Configure a DeH to receive applications and data migrated from source servers. Then after you create a migration workflow using this plan, the system will provision target servers on that DeH.
- In the upper right corner of the source server list, enable Use DeH.
- Select the source servers and choose DeH Configuration > Associate DeH above the list.
- Select the target DeH to be associated from the drop-down list and click Confirm. Associated will show up in the DeH column. You can click Details to view the associated DeH.
- Configure a target environment based on Table 5.
Table 5 Parameters for configuring a target environment Parameter
Configuration
VPC
Select a VPC for the target servers from the drop-down list. For details about how to create a VPC, see Creating a VPC.
- If the source IP address is 192.168.X.X, you are advised to create a VPC and a subnet that both belong to network range 192.168.0.0/16.
- If the source IP address is 172.16.X.X, you are advised to create a VPC and a subnet that both belong to network range 172.16.0.0/12.
- If the source IP address is 10.X.X.X, you are advised to create a VPC and a subnet that both belong to network range 10.0.0.0/8.
Subnet
The subnet has to be in the same network segment as the VPC.
Security Group
The selected security group must:
- Allow inbound ports 8899, 8900, and 22 required for Windows migrations.
- Allow inbound port 22 required for Linux file-level migrations.
CAUTION:
- For security purposes, you are advised to only allow traffic from the source servers on these ports.
- These ports must also be opened on the firewalls of target servers.
For details about how to create a security group, see Creating a Security Group.
Disk Encryption
If this option is not selected, the system and data disks of target servers created in the migration workflow will remain unencrypted.
If this option is selected, the system and data disks of target servers created in the migration workflow will be encrypted.
NOTICE:- This setting applies to all target servers newly created in the workflow. Their disks will be encrypted using the same key.
- Once a disk is created, the encryption attribute of the disk cannot be modified.
- Keys can be shared with accounts, not IAM users.
To enable disk encryption, you need to create an agency to authorize EVS to access KMS. If you have the right to grant the permissions, grant the KMS access permissions to EVS directly. Once the authorization succeeds, you no longer need to perform the authorization again. If you do not have the right to grant the permissions, contact a user with the Security Administrator permissions to grant you the right and then repeat the preceding operations. After the authorization is successful, configure the following parameters:
- Select an existing key
NOTICE:
Only enabled keys generated using the AES_256 encryption algorithm are supported.
Select a key from the drop-down list. You can select one of the following keys:
Default keys: After the KMS access permissions have been granted to EVS, the system automatically creates a default key and names it evs/default.
Custom keys: You can choose an existing key or create a new one. For details about how to create a key, see Creating a Key.
- Enter a key ID
Enter the ID of a key shared from another user. Ensure that the key is in the target region. For details, see Creating a Grant.
Enterprise Project
Select the enterprise project you want to migrate to. The enterprise project default is selected by default. For details about enterprise projects, see What Is Enterprise Project Management Service?
Tags
You can add tags to the target servers automatically created by the workflow to facilitate resource management.
Click Add Tag and enter a tag key and tag value. For details about tags and tag naming rules, see Tag Overview.
To add the same tag to multiple servers or other types of resources, you can create a predefined tag on the TMS console and then select it for the servers or resources. This frees you from repeatedly entering tag keys and values. For details, see Creating Predefined Tags.
- Configure the ports required for the migration based Table 6.
Table 6 Parameters about migration ports Parameter
Configuration
Migration Port
It defaults to 22. If port 22 is occupied, you can use one from 10000 to 65535.
CAUTION:The following ports cannot be used as the migration port:
135, 139, 445, 5357, 5985, 5986, 8899, 8900, 47001, 49664, 49665, 49666, 49668, 49669, 49671, 49674, 49677, 49679, 49680, 49681, 49682, 49683, 49685, 49690, 49691, 49693, 49694, 49695, 49698, 49699, 49700, 49702, 49703, 49704, 49705, 49706, 49707, 49708, 49709, 49710, 49711, 49712, and 49713
Ensure the specified port is not in the blacklist above or occupied by another service on source servers, and verify that network settings permit traffic through this port.
The functions of the port are as follows:
- For Linux servers, this port is used to establish transmission channels and transmit data.
- For Windows servers, this port is used to establish transmission channels.
Control Port
This port is used to transmit task control signals for Windows servers. It defaults to 8899 and cannot be changed.
Transmission Port
This port is used to transmit data for Windows servers. It defaults to 8900 and cannot be changed.
- Click Next to open the Configure Migration Settings page.
Step 5: Configure Migration Settings
- Configure migration settings based on Table 7.
Table 7 Migration settings Area
Migration Network
Public
If you select Public, ensure that all target servers have EIPs bound. These EIPs will be used for the migration.
Private
If you select Private, configure Direct Connect connections, VPN connections, VPC peering connections, or subnets in the target VPC in advance to connect the source environment to the target environment.
- If the source environment cannot access the Internet, enter the private IP address of the source proxy server and the port used by the proxy software.
- If the source proxy server cannot access the Internet, put the SMS-Agent installation package at a location where the source servers can access directly or over a proxy. You can download the SMS-Agent installation package from the SMS console.
Source Settings
Install rsync on Source
Linux migrations depend on rsync. If rsync is not installed on a source server, the server will fail to be migrated.
- If this option is not selected, rsync will not be installed on the source servers.
- If this option is selected, rsync will be automatically installed on the source servers. The installation can succeed only if the source servers:
- Have the Internet access. If a proxy server is required, ensure that the proxy settings are correctly set in /etc/yum.conf (for CentOS and Red Hat) or /etc/apt/apt.conf (for Ubuntu).
- Have outbound ports 80 (HTTP) and 443 (HTTPS) enabled by the firewalls and security groups.
- Have accessible software sources. You are advised to configure a source based on your location. Cross-country access to the official source may experience high latency and packet loss, which may result in download failures.
- Have sufficient CPU, memory, and I/O resources to prevent latencies or interruptions during installation.
NOTE:If the automatic installation fails, manual installation is required. For details, see rsync Not Installed on the Source Server.
Target Settings
Start Target After Migration
- If this option is not selected, the target servers will be stopped after the migration is complete.
- If this option is selected, the target servers will be started after the migration is complete.
Retain IP Address
If this option is selected, the private IP addresses of the source servers will be retained on the target servers after the migration is complete. Enabling it may cause risks. You need to evaluate and take responsibility for any potential risks. For details, see How Do I Keep the Private IP Address of a Server Unchanged After the Migration?
Consistency Verification
Verify Data Consistency
- If this option is not selected, data consistency will not be verified after the full replication is complete. You can modify the verification policy after the incremental synchronization is complete.
- If this option is selected, the system will automatically verify data consistency after the full replication is complete. This is a quick verification, and only the file size and last modification time will be verified. You can modify the verification policy after the incremental synchronization is complete.
Advanced Settings
Set Bandwidth Limit
- If this option is not selected, the migration traffic is not limited.
- If this option is selected, you can limit the bandwidth that can be used for migration based on the source bandwidth and service requirements.
CAUTION:Consider the migration scale to set an appropriate bandwidth limit. If too small a bandwidth is allocated to a workflow that includes 10 servers, migration tasks in the workflow may preempt the limited bandwidth resource, and some servers may fail to be migrated.
Enable Quick Mode
Enable this option if incremental synchronization is not required. This option is disabled by default. If it is enabled, incremental synchronization is skipped and then subsequent steps are performed after full replication is complete in the workflow. Set this option based on your requirements.
Send SMN Notifications
Determine whether to get SMN notifications about the migration. You can configure Topic, Language, and Trigger Condition.
Before enabling this function, create an SMN topic and subscribe to it. For details, see Publishing a Template Message.
NOTE:You can only choose an SMN topic in the default IAM project of the region where you currently use MgC.
To enable this function, you need to authorize MgC when the system prompts you.
Select one or more trigger conditions.
- Migration succeeded: A notification will be sent if all resources in the migration workflow are migrated.
- Migration failed: A notification will be sent if any resource in the migration workflow fails to be migrated.
- Manual checkpoint: A notification will be sent if all resources in the migration workflow are waiting for manual confirmation.
- Click Next to open the Confirm page.
Step 6: Confirm the Configurations
After performing steps 1 to 5, check the resource and migration settings on the Confirm page. To update the settings, click Previous to return to the corresponding stage for modification.
Step 7: Perform Follow-Up Operations
After confirming that the configurations are correct, perform follow-up operations as required.
- If you want to start the migration immediately, click OK to start the workflow and view the workflow details.
- If you want to save the migration workflow without starting the migration, click Cancel. The migration workflow will move to a Waiting status, and the migration has not started yet. To run the workflow, click Run in the Operation column to manually start the migration.
For more information about migration workflows, see Creating a Batch Server Migration Workflow.
- Click Design in the Operation column to update the migration plan.
- Click Create Workflow in the Operation column to create a migration workflow based on the plan. For details, see Creating a Batch Server Migration Workflow.
