Ingesting CCE Application Logs to LTS
CCE provides highly scalable, high-performance, enterprise-class Kubernetes clusters. With CCE, you can easily deploy, manage, and scale containerized applications.
After ingesting CCE logs to LTS, you can centrally manage and analyze them on the LTS console. This helps you promptly detect container issues and improve container performance and reliability. In addition, log reports can be displayed in a visualized manner for you to better monitor and manage containerized applications.
Follow these steps to complete the ingestion configuration:
Step 1: Select a Log Stream: Store various log types in separate log streams for better categorization and management.
Step 2: Check Dependencies: LTS automatically checks whether the ICAgent, custom identifier, log group, or log stream settings meet the requirements.
Step 3: (Optional) Select Host Groups: Define the range of hosts for log ingestion. Host groups are virtual groups of hosts. They help you organize and categorize hosts, making it easier to configure log ingestion for multiple hosts simultaneously. You can add one or more hosts whose logs are to be collected to a single host group, and associate it with the same ingestion configuration.
Step 4: Configure the Collection: Configure the log collection details, including collection paths and policies.
Step 5: Configure Indexing: An index is a storage structure used to query log data. Configuring indexing makes log searches and analysis faster and easier.
Step 6: Complete the Ingestion Configuration: After a log ingestion configuration is created, manage it in the ingestion list.
Setting Multiple Ingestion Configurations in a Batch: Select this mode to collect logs from multiple scenarios.
Video Tutorial
- ICAgent has been installed in the CCE cluster. For details, see Managing ICAgent in Container Scenarios.
Currently, ICAgent can be installed only in CCE standard and Turbo clusters. You cannot install ICAgent in CCE Autopilot or Agile clusters.
(You are advised to install ICAgent before configuring CCE log ingestion. This avoids automatic checks and repairs during configuration, saving time.)
- Add the CCE cluster with ICAgent installed to a host group of the custom identifier type. For details, see Creating a Host Group (Custom Identifier).
- You have disabled Output to AOM.
- A log group and a log stream have been created. For details, see Managing Log Groups and Managing Log Streams.
- Before configuring log ingestion, ensure that ICAgent collection is enabled by referring to Setting LTS Log Collection Quota and Usage Alarms.
- This function is enabled by default. If you do not need to collect logs, disable this function to reduce resource usage.
- After this function is disabled, ICAgent will stop collecting logs, and the log collection function on the AOM console will also be disabled.
- If no CCE cluster is displayed on the Hosts page, you need to authorize LTS to access AOM 2.0. Log in to the AOM 2.0 console and grant AOM 2.0 permissions to access cloud services, such as LTS and CCE. For details, see Authorizing AOM to Access Other Cloud Services.
- CCE cluster nodes whose container engine is Docker are supported. For details, seeNode Overview.
- CCE cluster nodes whose container engine is containerd are supported. You must be using ICAgent 5.12.130 or later.
- CCE Turbo clusters are supported. You must be using ICAgent 5.12.130 or later.
- Constraints on the Docker storage driver: Currently, container file log collection supports only the overlay2 storage driver. devicemapper cannot be used as the storage driver. Run the following command to check the storage driver type:
docker info | grep "Storage Driver"
- If you select Fixed log stream for log ingestion, ensure that you have created a CCE cluster.
- After LTS delivers the collection configuration, ICAgent collects files according to the following rules:
- New files (collected for the first time): If the last modification time of a file is more than 12 hours earlier than the current time, the file is not collected.
- Old files (not collected for the first time): If the last modification time of a file is more than 2 hours earlier than the current time, the file is not collected.
- Log in to the LTS console.
- In the navigation pane, choose Log Ingestion > Ingestion Center. On the displayed page, select Running environments or Cloud services under Types. Hover the cursor over the Cloud Container Engine(CCE) card and click Ingest Log (LTS) to access the configuration page. Figure 1 Accessing the CCE log ingestion configuration page
Alternatively, choose Log Ingestion > Ingestion Management in the navigation pane. Click Create. On the displayed page, select Running environments or Cloud services under Types. Hover the cursor over the Cloud Container Engine(CCE) card and click Ingest Log (LTS) to access the configuration page.
- Choose a collection mode between Fixed log stream (recommended) and Custom log stream.
Table 1 Collection modes Collection Mode
Fixed log stream
- Advantages: All logs are collected to one log stream. You can view them by namespace, workload, or container name.
- Disadvantages:
- Since logs of different structures are collected into the same stream, log structuring and SQL visual analysis are unavailable.
- Since each stream has a limited write rate of 100 MB/s, there may be performance bottlenecks in heavy traffic.
Custom log stream
- Advantages:
- Since logs of different structures are collected to different streams, log structuring and SQL visual analysis are available.
- Since the cumulative write rate of multiple streams is not limited, there are no performance bottlenecks in heavy traffic.
- Disadvantage: Logs cannot be viewed by namespace, workload, or container name.
- If you set Collect to Fixed log stream, perform the following steps:
Logs will be collected to a fixed log stream. The default log streams for a CCE cluster are stdout-{ClusterID} for standard output/errors, hostfile-{ClusterID} for node files, event-{ClusterID} for Kubernetes events, and containerfile-{ClusterID} for container files. Log streams are automatically named with a cluster ID. For example, if the cluster ID is Cluster01, the standard output/error log stream is stdout-Cluster01.
Log streams that can be created for a CCE cluster are stdout-{ClusterID} for standard output/errors, hostfile-{ClusterID} for node files, event-{ClusterID} for Kubernetes events, and containerfile-{ClusterID} for container files. If one of them has been created in a log group, the log stream will no longer be created in the same log group or other log groups.
- Select a cluster from the CCE Cluster drop-down list.
- The default log group is k8s-log-ClusterID. For example, if the cluster ID is c7f3f4a5-bcb8-11ed-a4ec-0255ac100b07, the default log group will be k8s-log-c7f3f4a5-bcb8-11ed-a4ec-0255ac100b07. If there is no such group, the system displays the following message: This log group does not exist and will be automatically created to start collecting logs.
- Click Next: Check Dependencies.
- If you set Collect to Custom log stream, perform the following steps:
- Select a log group from the Log Group drop-down list. If there are no desired log groups, click Create Log Group to create one.
- Select a log stream from the Log Stream drop-down list. If there are no desired log streams, click Create Log Stream to create one.
The system automatically checks the following items:
- ICAgent has been installed (version 5.12.130 or later).
- There is a host group with the custom identifier k8s-log-ClusterID.
- There is a log group named k8s-log-ClusterID. If Fixed log stream is selected, this item is checked.
- The recommended log stream exists. If Fixed log stream is selected, this item is checked.
You need to meet all the requirements before moving on. If not, click Auto Correct.
- Auto Correct: Configure the previous dependencies with one click.
- Check Again: Recheck dependencies.
A host group is a virtual group of hosts, allowing you to configure host log collection efficiently. ICAgent has been installed in the CCE cluster and a host group with custom identifiers has been created for related nodes. The system will automatically check these configurations and make necessary corrections when CCE logs are ingested to LTS.
- On the Select Host Group page, the host group k8s-log-Cluster ID created during dependency check is selected by default.
- You can also select other host groups as required.
- For a host group of CCE clusters, its custom identifier must be in the format of k8s-log-Cluster ID.
- You can skip this step and configure host groups as follows after the ingestion configuration is complete. However, you are advised to configure host groups during the first ingestion configuration to ensure that the configuration takes effect.
- Choose Host Management > Host Groups in the navigation pane and associate host groups with ingestion configurations.
- Choose Log Ingestion > Ingestion Management in the navigation pane. In the ingestion configuration list, click Modify in the Operation column. On the page displayed, select required host groups.
- Click Next: Configurations.
Collection configuration items include the log collection scope, collection mode, and format processing. Configure them as follows.
- Collection Configuration Name: Enter 1 to 64 characters. Only letters, digits, hyphens (-), underscores (_), and periods (.) are allowed. Do not start with a period or underscore, or end with a period.
- Data Source: Select a data source type and configure it. For details, see Table 2. If multiple hosts are configured to collect logs from the mounted network disks or shared storage devices at the same time, duplicate logs will be collected.
Table 2 Data source parameters Parameter
Container standard output
Collects stderr and stdout logs of a specified container in the cluster.
The standard output of the matched container is collected to the specified log stream. Standard output to AOM stops.
- Output to AOM1.0: ICAgent has been installed on hosts in the cluster and collects container standard output to AOM only. This function is disabled by default. To collect container standard output to LTS, disable this function.
If Output to AOM is enabled, LTS will charge you based on the actual log traffic. For details, see LTS Pricing Details.
- Either Container Standard Output (stdout) or Container Standard Error (stderr) must be enabled.
- If you enable Container Standard Error (stderr), select your collection destination path: Collect standard output and standard error to different files (stdout.log and stderr.log) or Collect standard output and standard error to the same file (stdout.log).
- Allow Repeated File Collection
After you enable this function, one host log file can be collected to multiple log streams. This function is available only to certain ICAgent versions. For details, see Checking the ICAgent Version.
After you disable this function, each collection path must be unique. That is, the same log file in the same host cannot be collected to different log streams.
Container file
Collects file logs of a specified container in the cluster.
- Add Collection Path: Specify the paths from which LTS will collect logs. For more examples, see Collection Paths.
If a container mount path has been configured for the CCE cluster workload, the paths added for this field are invalid. The collection paths take effect only after the mount path is deleted.
LTS does not collect logs from symbolic links when collecting container logs. To ensure successful collection, configure the path to point directly to the actual physical files.
Only physical paths are supported for log file mounts. Do not use symbolic links (for example, avoid using /var/log if it points to /mnt/logs). Instead, provide the absolute physical path (for example, /mnt/logs).
- Add Custom Wrapping Rule: ICAgent determines whether a file is wrapped based on the file name rule. If your wrapping rule does not comply with the built-in rules, you can add a custom wrap rule to prevent log loss during repeated collection and wrapping.
The built-in rules are {basename}{connector}{wrapping identifier}.{suffix} and {basename}.{suffix}{connector}{wrapping identifier}. Connectors can be hyphens (-), periods (.), or underscores (_), wrapping identifiers can contain only non-letter characters, and the suffix can contain only letters.
A custom wrapping rule consists of {basename} and the feature regular expression of the wrapped file. Example: If your log file name is test.out.log and the names after wrapping are test.2024-01-01.0.out.log and test.2024-01-01.1.out.log, configure the collection path to /opt/*.log, and add a custom wrapping rule for Linux: {basename}\.\d{4}-\d{2}-\d{2}\.\d{1}.out.log, and a wrapping rule for Windows: {basename}.[0-9]{4}-[0-9]{2}-[0-9]{2}.[0-9]{1}.out.log.
- You can verify collection paths to ensure that logs can be properly collected. Click use path verification, enter the collection paths and absolute paths of the log files, and click OK. You can add up to 30 collection paths. If the paths are correct, a success message will be displayed.
- You can verify wrapping rules to ensure that logs can be properly collected. Click wrapping rule verification, enter the name of the collected file, file name after wrapping, and wrapping rule, and click OK. If the wrapping rule is correct, a success message will be displayed.
- Set Collection Filters: Blacklisted directories or files will not be collected. If you specify a directory, all files in the directory are filtered out.
Node file
Collects files of a specified node in a cluster.
Kubernetes event
Collects event logs of the Kubernetes cluster.
Kubernetes events of a Kubernetes cluster can be collected to only one log stream.
- (Optional) Kubernetes Matching Rules: Set these parameters only when the data source type is set to Container standard output or Container file.
After entering a regular expression, click Verify to verify it. ICAgent supports only RE2 regular expressions. For details, see Syntax.
Table 3 Kubernetes matching rules Parameter
Namespace Name Regular Expression
Specifies the container whose logs are to be collected based on the namespace name. Regular expression matching is supported.
LTS will collect logs of the namespaces with names matching this expression. To collect logs of all namespaces, leave this field empty.
Pod Name Regular Expression
Specifies the container whose logs are to be collected based on the pod name. Regular expression matching is supported.
LTS will collect logs of the pods with names matching this expression. To collect logs of all pods, leave this field empty.
Container Name Regular Expression
Specifies the container whose logs are to be collected based on the container name (the Kubernetes container name is defined in spec.containers). Regular expression matching is supported.
LTS will collect logs of the containers with names matching this expression. To collect logs of all containers, leave this field empty.
Label Whitelist
Specifies the containers whose logs are to be collected. If you want to set a Kubernetes label whitelist, Label Key is mandatory and Label Value is optional.
When adding multiple whitelists, you can select the And or Or relationship. This means a container will be matched when it satisfies all or any of the whitelists.
If Label Value is empty, LTS will match all containers whose Kubernetes label contains a specified Label Key. If Label Value is not empty, only containers whose Kubernetes label contains a specified Label Key that is equal to its Label Value are matched. Label Key requires full matching while Label Value supports regular matching.
Label Blacklist
Specifies the containers whose logs are not to be collected. If you want to set a Kubernetes label blacklist, Label Key is mandatory and Label Value is optional.
When adding multiple blacklists, you can select the And or Or relationship. This means a container will be excluded when it satisfies all or any of the blacklists.
If Label Value is empty, LTS will exclude all containers whose Kubernetes label contains a specified Label Key. If Label Value is not empty, only containers whose Kubernetes label contains a specified Label Key that is equal to its Label Value will be excluded. Label Key requires full matching while Label Value supports regular matching.
Kubernetes Label
After the Kubernetes Label is set, LTS adds related fields to logs.
LTS adds the specified fields to the log when each Label Key has a corresponding Label Value. For example, if you enter app as the key and app_alias as the value, when the container label contains app=lts, {app_alias: lts} will be added to the log.
Container Label Whitelist
Specifies the containers whose logs are to be collected. If you want to set a container label whitelist, Label Key is mandatory and Label Value is optional.
If Label Value is empty, LTS will match all containers whose container label contains a specified Label Key. If Label Value is not empty, only containers whose container label contains a specified Label Key that is equal to its Label Value are matched. Label Key requires full matching while Label Value supports regular matching.
Container Label Blacklist
Specifies the containers whose logs are not to be collected. If you want to set a container label blacklist, Label Key is mandatory and Label Value is optional.
If Label Value is empty, LTS will exclude all containers whose container label contains a specified Label Key. If Label Value is not empty, only containers whose container label contains a specified Label Key that is equal to its Label Value will be excluded. Label Key requires full matching while Label Value supports regular matching.
Container Label
After the Container Label is set, LTS adds related fields to logs.
Environment Variable Whitelist
Specifies the containers whose logs are to be collected. If you want to set an environment variable whitelist, Label Key is mandatory and Label Value is optional.
If Environment Variable Value is empty, LTS will match all containers whose environment variable contains a specified Environment Variable Key. If Environment Variable Value is not empty, only containers whose environment variable contains a specified Environment Variable Key that is equal to its Environment Variable Value are matched. Label Key requires full matching while Label Value supports regular matching.
Environment Variable Blacklist
Specifies the containers whose logs are not to be collected. If you want to set an environment variable blacklist, Label Key is mandatory and Label Value is optional.
If Environment Variable Value is empty, LTS will exclude all containers whose environment variable contains a specified Environment Variable Key. If Environment Variable Value is not empty, only containers whose environment variable contains a specified Environment Variable Key that is equal to its Environment Variable Value will be excluded. Label Key requires full matching while Label Value supports regular matching.
Environment Variable Label
After the environment variable label is set, the log service adds related fields to the log.
LTS adds the specified fields to the log when each Environment Variable Key has a corresponding Environment Variable Value. For example, if you enter app as the key and app_alias as the value, when the Kubernetes environment variable contains app=lts, {app_alias: lts} will be added to the log.
- Structuring Parsing:
LTS offers various log parsing rules, including Single-Line - Full-Text Log, Multi-Line - Full-Text Log, JSON, Delimiter, Single-Line - Completely Regular, Multi-Line - Completely Regular, and Combined Parsing. Select a parsing rule that matches your log content. Once collected, structured logs are sent to your specified log stream, enabling field searching.
- If you enable Structuring Parsing, configure it by referring to Configuring ICAgent Structuring Parsing. Figure 2 ICAgent structuring parsing configuration
- If you disable Structuring Parsing, log data will not be structured. Raw logs will be sent to the specified log stream, allowing only keyword-based searches.
- Other: After setting the collection paths, you can also set log splitting, binary file collection, and custom metadata.
- Configure the log format and time by referring to Table 5. If Structuring Parsing is enabled, these parameters are unavailable.
Table 5 Log collection settings Parameter
Log Format
- Single-line: Each log line is displayed as a single log event.
- Multi-line: Multiple lines of exception logs can be displayed as a single log event and each line of regular logs is displayed as a log event. This is helpful when you check logs to locate problems.
Log Time
System time: log collection time by default. It is displayed at the beginning of each log event.
- Log collection time is the time when logs are collected and sent by ICAgent to LTS.
- Log printing time is the time when logs are printed. ICAgent collects and sends logs to LTS every second.
- Restriction on log collection time: Logs are collected within 24 hours before and after the system time.
Time wildcard: You can set a time wildcard so that ICAgent will look for the log printing time as the beginning of a log event.
- If the time format in a log event is 2019-01-01 23:59:59.011, the time wildcard should be set to YYYY-MM-DD hh:mm:ss.SSS.
- If the time format in a log event is 19-1-1 23:59:59.011, the time wildcard should be set to YY-M-D hh:mm:ss.SSS. If a log event does not contain year information, ICAgent regards it as printed in the current year.
Example:
YY - year (19) YYYY - year (2019) M - month (1) MM - month (01) D - day (1) DD - day (01) hh - hours (23) mm - minutes (59) ss - seconds (59) SSS - millisecond (999) hpm - hours (03PM) h:mmpm - hours:minutes (03:04PM) h:mm:sspm - hours:minutes:seconds (03:04:05PM) hh:mm:ss ZZZZ (16:05:06 +0100) hh:mm:ss ZZZ (16:05:06 CET) hh:mm:ss ZZ (16:05:06 +01:00)
Log Segmentation
This parameter needs to be specified if the Log Format is set to Multi-line. By generation time indicates that a time wildcard is used to detect log boundaries, whereas By regular expression indicates that a regular expression is used.
You can set a regular expression to look for a specific pattern to indicate the beginning of a log event. This parameter needs to be specified when you select Multi-line for Log Format and By regular expression for Log Segmentation.
The time wildcard and regular expression will look for the specified pattern right from the beginning of each log line. If no match is found, the system time, which may be different from the time in the log event, is used. In general cases, you are advised to select Single-line for Log Format and System time for Log Time.
- Click Next: Index Settings.
An index is a storage structure used to query log data. Configuring indexing makes log searches and analysis faster and easier. Different index settings generate different query and analysis results. Configure index settings to fit your service requirements.
- If you do not want to query or analyze logs using specific fields, you can skip configuring indexing when configuring log ingestion. This will not affect log collection. You can also configure indexing after creating the log ingestion configuration. However, index settings will only apply to newly ingested logs. For details, see Configuring Log Indexing. If you choose to skip this step, retain the default settings on the Index Settings page and click Skip and Submit. The message "Logs ingested" will appear.
- To query or analyze logs using specific fields, configure indexing on the Index Settings page when creating an ingestion configuration. For details, see Configuring Log Indexing.
On this page, click Auto Configure to have LTS generate index fields based on the first log event in the last 15 minutes or common system reserved fields (such as hostIP, hostName, and pathFile). You can also manually add structured fields. After completing the settings, click Submit. The message "Logs ingested" will appear. You can also adjust the index settings after the ingestion configuration is created. However, the changes will only affect newly ingested logs.
- Click its name to view its details.
- Click Modify in the Operation column to modify the ingestion configuration.
You can quickly navigate and modify settings by clicking Select Log Stream, (Optional) Select Host Group, Configurations, or Index Settings in the navigation tree at the top of the page. After making your modifications, click Submit to save the changes. This operation is available for all log ingestion modes except CCE logs, ServiceStage containerized application logs, and self-built Kubernetes cluster logs.
- Click More > Configure Tag in the Operation column to add a tag.
- Click More > Copy in the Operation column to copy the ingestion configuration.
- Click Delete in the Operation column to delete the ingestion configuration.
Deleting an ingestion configuration may lead to log collection failures, potentially resulting in service exceptions related to user logs. In addition, the deleted ingestion configuration cannot be restored. Exercise caution when performing this operation.
- To stop log collection of an ingestion configuration, toggle off the switch in the Ingestion Configuration column to disable the configuration. To restart log collection, toggle on the switch in the Ingestion Configuration column.
Disabling an ingestion configuration may lead to log collection failures, potentially resulting in service exceptions related to user logs. Exercise caution when performing this operation.
- Click More > ICAgent Collect Diagnosis in the Operation column of the ingestion configuration to monitor the exceptions, overall status, and collection status of ICAgent. If this function is not displayed, enable ICAgent diagnosis by referring to Setting ICAgent Collection.
You can set multiple ingestion configurations for multiple scenarios in a batch, avoiding repetitive setups.
- On the Ingestion Management page, click Batch Create to go to the configuration details page.
- Ingestion Type: Select CCE (Cloud Container Engine).
- Rule List:
- Enter the number of ingestion configurations in the text box and click Add.
- Enter a rule name under Configuration Items on the right. You can also double-click the name of the ingestion configuration on the left to replace it with a custom name after setting the configuration items. Enter 1 to 64 characters, including only letters, digits, hyphens (-), underscores (_), and periods (.). Do not start with a period or underscore or end with a period.
- To copy an ingestion configuration, move the cursor to it and click
. - To delete an ingestion configuration, move the cursor to it and click
. In the displayed dialog box, click OK.
- Configuration Items:
- The ingestion configurations are displayed on the left. You can add up to 99 more configurations.
- The ingestion configuration items are displayed on the right. Set them by referring to Step 4: Configure the Collection.
- After an ingestion configuration is complete, you can click Apply to Other Configurations to copy its settings to other configurations.
- Click Check Parameters. After the check is successful, click Submit.
The added ingestion configurations will be displayed on the Ingestion Management page after the batch creation is successful.
- (Optional) Perform the following operations on ingestion configurations:
- Select multiple existing ingestion configurations and click Edit. On the displayed page, select an ingestion type to modify the corresponding ingestion configurations.
- Select multiple disabled ingestion configurations, click Enable/Disable Ingestion Configuration, and select Enable to enable them in a batch.
- Select multiple enabled ingestion configurations, click Enable/Disable Ingestion Configuration, and select Disable. Logs will not be collected for disabled ingestion configurations. Exercise caution when disabling these configurations.
- Select multiple existing ingestion configurations and click Delete.
Helpful Links
- After logs are ingested to LTS, you can use the search and analysis functions of LTS to quickly gain insights into log data. For details, see Log Search and Analysis (SQL Analysis Offline Soon).
- You can use LTS's log alarm function to set alarm rules to notify you of exceptions in the ingested logs. For details, see Configuring Log Alarm Rules.
- If you have any questions when installing ICAgent, see Host Management in the FAQ.
- If you have any questions when configuring log ingestion, see Log Ingestion in the FAQ.
- You can call APIs to create, query, and delete log ingestion configurations. For details, see Log Ingestion.
- You are advised to learn several best practices of data collection. For details, see Log Ingestion in the Best Practices.
- To collect logs across clouds or regions, see Collecting Host Logs from Third-Party Clouds, Internet Data Centers, and Other Huawei Cloud Regions to LTS.
- To collect data from multiple channels, see Collecting Logs from Multiple Channels to LTS.
- To implement cross-account log ingestion, see Implementing Cross-Account Ingestion.
