Help Center/ IoT Device Access/ User Guide/ Rules/ Data Forwarding to Huawei Cloud Services/ Forwarding Data to DMS for Kafka for Storage
Updated on 2024-11-06 GMT+08:00
If you want to store data reported by devices, you can either forward the data to application servers or to Distributed Message Service (DMS) for Kafka for storage.
In this example, data reported by all devices is forwarded to DMS for Kafka.
Buying a Kafka Instance
  1. Log in to Huawei Cloud and visit DMS for Kafka.
  2. Click Access Console to go to the DMS for Kafka console.
  3. Click Buy Instance in the upper right corner, select instance specifications and configure a security group as required, and click Buy.
    Figure 1 Buying a Kafka Instance
Configuring IoTDA
Using IoTDA, you can create a product model, register a device, and set a data forwarding rule to forward data reported by the device to DMS for Kafka.
  1. Access the IoTDA service page and click Access Console. Click the target instance card.
  2. In the navigation pane, choose Rules > Data Forwarding, and click Create Rule in the upper left corner.
  3. Set the parameters based on the table below. The following parameter values are only examples. You can create a rule by referring to Data Forwarding Overview and click Create Rule.
    Rule Name
    Customize a name, for example, iotda-kafka.
    Customize a rule description, for example, forwarding data to DMS for Kafka for storage.
    Data Source
    Select Device property.
    Trigger
    Device property reported is automatically populated.
    Resource Space
    Select All resource spaces.
    Figure 2 Rules triggered by property reporting - Forwarding data to Kafka
  4. Click the Set Forwarding Target tab, and then click Add to set a forwarding target.
    Forwarding Target
    Select Distributed Message Service (DMS) for Kafka.
    Region
    Select the region where DMS for Kafka is located. If IoTDA is not authorized to access the service in this region, configure cloud service access authorization as prompted.
    Connection Address
    Obtain the connection address by following the instructions provided in Accessing a Kafka Instance with SASL. Basic and standard instances support only access to Kafka premium instances over the Internet. Enterprise instances support access to Kafka premium instances over a private network.
    Topic
    Customize a topic. For details, see Creating a Topic.
    SASL
    If SASL authentication is enabled, enter the security protocol, SASL authentication mechanism, and SASL username and password you used when you buy a Kafka instance.
    Kafka Security Protocol
    Select the Kafka security protocol you used when you buy a Kafka instance.
    SASL Mechanism
    Select the SASL authentication mechanism you enabled when you buy a Kafka instance.
    SASL Username
    Enter the SASL username you entered when buying a Kafka instance.
    Password
    Enter the password you entered when buying a Kafka instance.
    Figure 3 Creating a forwarding target - to Kafka with a custom certificate
  5. Click Enable Rule to activate the configured data forwarding rule.
    Figure 4 Enabling a rule - Forwarding data to Kafka
Verifying the Configurations
Expected result:
Log in to the DMS for Kafka management console and click the Kafka instance name to go to the instance management page. On the Message Query page, you can view the data reported by the device.
Figure 5 Viewing Kafka messages - Kafka
You can also use the DMS for Kafka API Querying Messages to read files.
