- What's New
- Product Bulletin
- Billing
Getting Started
Quick Device Access - Property Reporting and Command Receiving
- Subscribing to IoTDA
- Connecting a Smart Smoke Detector to the Platform (Quick Usage)
- Registering a Simulated Smart Street Light Device
- Using MQTT.fx to Simulate Communication Between the Smart Street Light and the Platform
- Using a Virtual Smart Street Light to Communicate with the Platform (Java SDK)
- Using a Virtual Smart Street Light to Communicate with the Platform (C SDK)
- Quick Device Access - Message Sending and Receiving
- Quick Application Access
User Guide
- Overview
- IoTDA Instances
- Resource Spaces
- Device Access
- Message Communications
- Device Management
Rules
- Overview
- Data Forwarding Process
- SQL Statements
- Connectivity Tests
- Data Forwarding to Huawei Cloud Services
- Data Forwarding to Third-Party Applications
- Data Forwarding Channel Details
- Data Forwarding Stack Policies
- Data Forwarding Flow Control Policies
- Abnormal Data Target
- Device Linkage
- Monitoring and O&M
- Granting Permissions Using IAM
Best Practices
- Introduction
Device Access
- Developing an MQTT-based Simulated Smart Street Light Online
- Developing a Smart Street Light Using NB-IoT BearPi
- Developing a Smart Smoke Detector Using NB-IoT BearPi
- Connecting and Debugging an NB-IoT Smart Street Light Using a Simulator
- Developing a Protocol Conversion Gateway for Access of Generic-Protocol Devices
- Connecting a Device That Uses the X.509 Certificate Based on MQTT.fx
- Connecting to IoTDA Based on the BearPi-HM_Nano Development Board and OpenHarmony 3.0
- Testing MQTT Performance Using JMeter
- Device Management
- Data Forwarding
- Device Linkage
Developer Guide
- Before You Start
- Obtaining Resources
- Product Development
- Development on the Device Side
- Development on the Application Side
API Reference
API Reference on the Application Side
- Before You Start
- Calling APIs
- API Overview
API
- Product Management
- Device Management
- Device Message
- Device Command APIs
- Device Property
- AMQP Queue Management
- Access Credential Management
- Data Forwarding Rule Management
Transition Data
- Push a Device Status Change Notification
- Push a Device Property Reporting Notification
- Push a Device Message Status Change Notification
- Push a Batch Task Status Change Notification
- Push a Device Message Reporting Notification
- Push a Device Addition Notification
- Push a Device Update Notification
- Push a Device Deletion Notification
- Push a Product Addition Notification
- Push a Product Update Notification
- Push a Product Deletion Notification
- Push an Asynchronous Device Command Status Change Notification
- Rule Management
- Device Shadow
- Group Management
- Tag Management
- Instance Management
- Resource Space Management
- Batch Task
- Device CA Certificate Management
- OTA Upgrade Package Management
- Message Broadcasting
- Device Tunnel Management
- Stack policy management
- Flow control policy management
- Device Proxy
- Device Policy Management
- Bridge Management
- Pre-provisioning Template Management
- Custom Authentication
- Codec Function Management
- Examples
- Appendix
MQTT or MQTTS API Reference on the Device Side
- Before You Start
- Communication Modes
- Topics
- Device Connection Authentication
- Device Commands
- Device Messages
- Device Properties
Gateway and Child Device Management
- Platform Notifying a Gateway of New Child Device Connection
- Platform Notifying a Gateway of Child Device Deletion
- Gateway Synchronizing Child Device Information
- Gateway Updating Child Device Status
- Responding to a Request for Updating Child Device Statuses
- Gateway Requesting for Adding Child Devices
- Platform Responding to a Request for Adding Child Devices
- Gateway Requesting for Deleting Child Devices
- Platform Responding to a Request for Deleting Child Devices
- Software and Firmware Upgrade
- File Upload and Download
- Device Time Synchronization
- Device Reporting Information
- Device Log Collection
- Remote Configuration
- HTTPS API Reference on the Device Side
- LwM2M API Reference on the Device Side
- Security Tunnel WebSocket API Reference
- Module AT Command Reference
- Change History
- SDK Reference
- Top FAQs
Solution Consulting
- In What Scenarios Can the IoT Platform Be Applied?
- What Are the Changes Brought by the Integration of IoT Device Management and IoTDA?
- Can I Enable IoTDA for IAM Users or Sub-Projects?
- Which Regions of Huawei Cloud Are Supported by the IoT Platform?
- Does Huawei Provide Modules, Hardware Devices, and Application Software?
- What Should I Do If I Want to Call an API But Have No Permissions to Do So as an IAM User? (Is It Edition-specific?)
- Why Was I Prompted to Grant Security Administrator Permissions When I Create a Rule or Set Resource File Storage?
- Which Resource Space Will Be Set As Default on the IoT Platform?
- How Does IoTDA Obtain Device Data?
- Is There Any Limitation on the Number of Resource Spaces and Devices I Can Add on the IoT Platform?
- Does the IoTDA Support Device Registration in Batches?
- Are There Any Limitations on the Use of the IoT Platform?
- What DTLS Encryption Algorithms Are Supported by the IoT Platform?
- Does the IoT Platform Support Conversion Between Big-Endian and Little-Endian for Binary Data?
- What Is NB-IoT?
- What Are the Components of the IoT Platform and What Hardware Architectures Does It Support?
- How Do I Obtain the Platform Access Address?
- Device Integration
- IoT Device SDKs
- LwM2M/CoAP Device Access
- MQTT-based Device Access
- Products Models
- Subscription and Push
- Codecs
- OTA Upgrades
- Application Integration
MQTT(S) Access
Overview
An MQTT message consists of fixed header, variable header, and payload.
Common MQTT message types include CONNECT, SUBSCRIBE, and PUBLISH.
- CONNECT: A client requests a connection to a server. For details about main parameters in the payload of a CONNECT message, see Device Connection Authentication.
- SUBSCRIBE: A client subscribes to a topic. The main parameter Topic name in the payload of a SUBSCRIBE message indicates the topic whose subscriber is a device. For details, see Topics.
- PUBLISH: The platform publishes a message.
- The main parameter Topic name in the variable header of a PUBLISH message indicates the topic whose publisher is a device. For details, see Topics.
- The payload contains the data reported or commands delivered. It is a JSON object.
Topics
If you connect devices to the platform using MQTT, you can use topics to send and receive messages.
- Topics starting with $oc are preset system topics in IoTDA. You can subscribe to and publish messages through these topics. For details about the topic list and functions, see Topics.
- You can create topics that do not start with $oc to send and receive custom messages.
Description |
Limit |
Number of concurrent connections to a directly connected MQTT device |
1 |
Connection setup requests of an account per second on the device side |
Number of upstream requests for an instance per second on the device side (when average message payload is 512 bytes) |
Number of upstream messages for an MQTT connection |
50 per second |
Bandwidth of an MQTT connection (upstream messages) |
1 MB (default) |
Length of a publish message sent over an MQTT connection (Oversized messages will be rejected.) |
1 MB |
Standard MQTT protocol |
MQTT v5.0, MQTT v3.1.1, and MQTT v3.1 |
Differences from the standard MQTT protocol |
Security levels supported by MQTT |
TCP channel and TLS protocols (TLS v1, TLS v1.1, TLS v1.2, and TLS v1.3) |
Recommended heartbeat interval for MQTT connections |
Range: 30s to 1200s; recommended: 120s |
MQTT message publish and subscription |
A device can only publish and subscribe to messages of its own topics. |
Number of subscriptions for an MQTT connection |
100 |
Length of a custom MQTT topic |
128 bytes |
Number of custom MQTT topics added to a product |
10 |
Number of CA certificates uploaded for an account on the device side |
100 |
Compatibility
IoTDA supports device access using MQTT 5.0, MQTT 3.1.1, and MQTT 3.1. However, IoTDA is not a simple MQTT broker. It also integrates capabilities such as message communications, device management, rule engine, and data forwarding. The differences between the MQTT function provided by IoTDA and standard MQTT specifications are as follows:
- Devices can communicate with IoTDA using CONNECT, CONNACK, PUBLISH, PUBACK, SUBSCRIBE, SUBACK, UNSUBSCRIBE, UNSUBACK, PINGREQ, PINGRESP, and DISCONNECT packets in MQTT specifications.
- IoTDA supports MQTT QoS 0 and QoS 1, but does not support QoS 2.
- IoTDA supports clean sessions.
- IoTDA does not support the will feature. IoTDA can push device statuses. After a device goes offline, IoTDA pushes its status to your application or other cloud services based on a forwarding rule.
- IoTDA does not support retained messages. IoTDA can cache messages during message reporting and delivery.
Supported MQTT 5.0 Features
Only enterprise edition instances support MQTT 5.0-related features.
IoTDA supports the following new MQTT 5.0 features:
- Topic aliases. Message communication topics are reduced to an integer to reduce MQTT packets and save network bandwidth resources.
- Response topics and correlation data. The two parameters can be carried during message reporting and delivery to implement cloud HTTP-like requests and responses.
- User property list. Each property consists of a key and a value and is used to transmit property data in the non-payload area.
- Content-Type. Message reporting packets can carry Content-Type to identify the packet type.
- Return codes can be carried in CONNACK and PUBACK packets, helping devices quickly locate request statuses and issues.
TLS Support for MQTT
TLS is recommended for secure transmission between devices and the platform. Currently, TLS v1.1, v1.2, v1.3, and GMTLS are supported. TLS v1.3 is recommended. TLS v1.1 will not be supported in the future. GMTLS is supported only by the enterprise edition using Chinese cryptographic algorithms.
When TLS connections are used for the basic edition, standard edition, and enterprise edition that support general cryptographic algorithms, the IoT platform supports the following cipher suites:
- TLS_AES_256_GCM_SHA384
- TLS_AES_128_GCM_SHA256
- TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
- TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
- TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA
- TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA
When the enterprise edition that supports Chinese cryptographic algorithms uses TLS connections, the IoT platform supports the following cipher suites:
- ECC_SM4_GCM_SM3
- ECC_SM4_CBC_SM3
- ECDHE_SM4_GCM_SM3
- ECDHE_SM4_CBC_SM3
- TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
- TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
CBC cipher suites may pose security risks.
Service Flow
MQTT devices communicate with the platform without data encryption. For security purposes, MQTTS access is recommended.
You are advised to use the IoT Device SDK to connect devices to the platform over MQTTS.
- Create a product on the IoTDA console or by calling the API Creating a Product.
- Register a device on the IoTDA console or calling the API Creating a Device.
- The registered device can report messages and properties, receive commands, properties, and messages, perform OTA upgrades, and report data using custom topics. For details about preset topics of the platform, see Topic Definition.
You can use MQTT.fx to debug access using the native MQTT protocol. For details, see Developing an MQTT-based Smart Street Light Online.
