- Billing
- Getting Started
User Guide
- Preparations
- CodeArts Req
- CodeArts Repo
- CodeArts Pipeline
- CodeArts Check
- CodeArts Build
- CodeArts Artifact
- CodeArts Deploy
- CodeArts TestPlan
- CodeArts PerfTest
Best Practices
- Best Practices Summary
Using CodeArts to Manage an e-Mall Development Project
- Overview
- Resource Planning
- Process
Implementation Procedure
- Preparation
- Step 1: Managing Project Plans
- Step 2: Managing Project Configurations
- Step 3: Writing Code
- Step 4: Checking Code
- Step 5: Building an Application
- Step 6: Deploying an Application (CCE)
- Step 6: Deploying an Application (ECS)
- Step 7: Managing Project Tests
- Step 8: Configuring a Pipeline for Continuous Delivery
- Releasing Resources
General
- How Do I Collect or Archive Project Information Locally After a CodeArts Project Is Complete?
- Why Can't an IAM User View Any CodeArts Projects After Login?
- How Do I View All CodeArts Projects and Members Under My Account as Administrator?
- Will the Tasks Created by a Project Member Be Deleted After the Member Leaves the Project?
- Will a New User with the Same Name as a Deleted User Inherit Their Permissions and Tasks?
- CodeArts Req
- CodeArts Repo
- CodeArts Pipeline
- CodeArts Check
- CodeArts Build
- CodeArts Artifact
- CodeArts Deploy
- CodeArts TestPlan
- CodeArts PerfTest
General
- Videos
On this page
Show all
Help Center/
CodeArts/
User Guide/
Preparations/
Adding Project Members/
Adding Members from an Agency
Huawei Cloud IAM Identity Center works with the Organizations service to provide unified identity management and access control across accounts.
In CodeArts, you can add users created and authorized in IAM Identity Center as project members.
- A CodeArts project is available, and you have the member settings permission for the project.
- An agency whose delegated object is IAM Identity Center exists. If there is no such agency, perform the following steps to create one:
- Go to the CodeArts homepage.
- Log in to the CodeArts console, click
, and select a region.
- Click Access Service.
- Click the target project name to access the project.
- In the navigation pane, choose Settings > Members.
- Click the Member View tab, choose Add Members, and choose to import users from an agency.
- In the displayed dialog box, select users, specify a role for each user, and click Save.
Figure 1 Adding users from an agency
- Check the new members in the member list.
Parent topic: Adding Project Members
