- What's New
- Getting Started
User Guide
Detailed Instructions on Using Teleport
- Process
- Logging In to DES Console
- Creating a Bucket
- Creating a Teleport-based DES Order
- Receiving Teleport and Connecting Cables
- Copying Data
- Downloading and Importing the Signature File
- Powering Off and Packing Teleport
- Sending Back the Teleport
- Starting Data Transmission
- Viewing Data Transmission Results
- Detailed Instructions on Using Disks
- Managing DES Orders
About the Service
- What Is DES?
- What Are the Advantages of DES Over the Internet in Data Transmission?
- What Are the Scenarios to Which DES Is Applicable?
- In What Conditions Is DES Recommended?
- Is the Data Volume Limited for DES?
- Where Is Data Uploaded by DES Stored?
- What Information Is Contained in the DES Transmission Report?
- What Are the Requirements for Disks by Disk-based DES?
- What Is Teleport?
- In What Conditions Is Teleport Recommended?
- What Are the Advantages of Teleport-based Transmission?
- What Is the Storage Capacity of a Teleport?
- What Is the Difference Between the Source Data Parameter and teleportshare?
- Can DES Provide Data Export Service?
- How Long Does It Take to Ship a Teleport?
- How Long Does It Take for My Data to Migrate to Huawei Cloud After I Have Created a DES Order?
Operations
- How Do I Subscribe to DES?
- Why Do I Need to Create OBS Destination Buckets When Using DES?
- Can I Post Several Disks with One Service Order?
- Can I Cancel a Submitted DES Order?
- How Do I Use a Teleport?
- In What Conditions Will I Be Notified by SMS Text Messages?
- How Can I Start Uploading Data After My Disk or Teleport Has Been Mounted?
- Does the Data Directory Structure Change After Data Is Uploaded to OBS Using DES?
- What Can I Do if the Device Is Damaged During DES Delivery?
- For Disk-based DES, How Do I Send a Disk?
- In Which Statuses Can a Service Order Be Modified?
Service Order Status
- How Can I Obtain the Status of a DES Service Order?
- What Are the Possible Statuses of a Disk-based Service Order?
- What Are the Possible Statuses of a Teleport-based Service Order?
- What Does Disk to be sent Mean?
- What Does Expired Mean?
- What Does Service order canceled Mean?
- What Does Access key (AK/SK) to be entered Mean?
- What Does Data transmitting Mean?
- What Does Disk to be sent back Mean?
- What Does Transmission failed Mean?
- What Does Order under review Mean?
- What Does Preparing device Mean?
- What Does Sending to user Mean?
- What Does Sending to Huawei Mean?
- What Does Staff signed Mean?
Security
- How Does DES Prevent Data from Being Stolen?
- How Does DES Ensure Data Security?
- What Is the Anti-Misoperation Mechanism of DES?
- What Is the Function of a Signature File?
- How Can I Obtain a Signature File?
- What Is the Content of a Signature File?
- Do I Need to Post the Signature File Along with the Disk or Teleport?
- Can Background Management Personnel Obtain My Data?
- How Does Teleport Ensure Data Security?
- How Does HUAWEI CLOUD Handle the Storage Media Used for Migration After Data Is Uploaded to HUAWEI CLOUD?
- Service Tariff
About the Service
- Glossary
On this page
Show all
- Process
- Creating a Bucket
- Copying Data
