Updated on 2025-11-06 GMT+08:00
Network
You can configure a default security group and secondary CIDR block for your clusters.
Cluster Network
Table 1 Parameters
VPC
VPC where a cluster resides
VPC enables you to provision logically isolated, configurable, manageable virtual networks for cloud servers, cloud containers, and cloud databases. You can configure IP address ranges, subnets, security groups, and more in a VPC, and assign EIPs and bandwidth to build your service system.
VPC CIDR Block
Available only in v1.27 clusters
For details about how to expand the VPC CIDR block, see Adding a Secondary VPC CIDR Block for a Cluster.
Default Node Subnet
Node subnet of a cluster
A subnet is a network that manages ECS network planes. It supports IP address management and DNS. ECSs in a subnet are assigned IP addresses from this subnet.
By default, ECSs in all subnets of the same VPC can communicate with one another, but ECSs in different VPCs cannot.
You can create a VPC peering connection to enable ECSs in different VPCs to communicate with each other.
Default Node Subnet | IPv4 CIDR Block/IPv6 CIDR Block
Node subnet CIDR block of a cluster
IPv4/IPv6 Dual Stack
Whether to enable IPv6 dual stack
Network Model
Network model of a cluster
After a cluster is created, its network model cannot be changed. For details about the comparison between different network models, see Overview.
Default Node Security Group
Default security group of the worker nodes in a cluster
You can select a custom security group as the default node security group for a cluster, and you need to allow traffic from specified ports in the security group to ensure normal communications in the cluster.
If the custom security group needs some modifications, the modified security group applies only to newly created or accepted nodes. For existing nodes, you need to manually modify the security group rules.
Non-Translated CIDR Blocks for External Communication (available only in clusters using the VPC network model)
In a cluster using a VPC network, 10.0.0.0/8, 172.16.0.0/12, and 192.168.0.0/16 are regarded as private CIDR blocks of the cluster by default. If the VPC to which the cluster resides uses a secondary CIDR block, operations such as creating or resetting a node will also add the secondary CIDR block to the private CIDR blocks.
If a pod tries to access a private CIDR block, the source node will not perform NAT on the pod IP address. Instead, the upper-layer VPC can directly send the pod data packet to the destination, which means, the pod IP address is directly used to communicate with the private CIDR block in the cluster.
This function is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions. For details, see Retaining the Original IP Address of a Pod.
To enable a node to access a pod in another node, the node CIDR block must be added to this parameter.
Similarly, to enable an ECS to access the IP address of a pod in a cluster that is in the same VPC as the ECS, the ECS CIDR block must be added to this parameter.
Pod Access to Metadata (available only in CCE Turbo clusters)
Whether to allow a newly created pod in a cluster to access the node metadata, such as AZs and enterprise project ID. For details about the metadata types and how to obtain metadata, see ECS Metadata Types.
This function is available only in clusters of v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later versions.
  • If a pod is created when the function is enabled, whether it can access metadata depends on the function status.
  • If a pod is created when the function is disabled or in a cluster of an earlier version, it cannot access metadata regardless of the function status. To grant a pod access to metadata, it must be rebuilt while the function is enabled.
Network Policies (supported by clusters using the container tunnel network model)
Whether to enable network policies. The change works within 10 seconds. This configuration is supported by clusters of v1.25.16-r10, v1.27.16-r10, v1.28.15-r0, v1.29.10-r0, v1.30.6-r0, v1.31.1-r0, and later versions.
  • Disabled: The network policy capability is not supported, and the created policies do not take effect.
  • Enabled: If a customer's Service CIDR block conflicts with an on-premises CIDR block, the link to a newly added gateway may not be established.
    For example, when a cluster accesses an external address through a Direct Connect connection, the switch outside the cloud does not support ip-option. If this configuration is enabled, the network access may fail.
Service Settings
Table 2 Parameters
Request Forwarding
Forwarding mode of a cluster
After a cluster is created, the service forwarding mode cannot be changed. IPVS and iptables are supported. For details, see Comparing iptables and IPVS.
IPv4 Service CIDR Block/IPv6 Service CIDR Block
Each Service in a cluster has its own IP address. When creating a CCE cluster, you can specify the Service address range (Service CIDR block). The Service CIDR block cannot overlap with the subnet or the container CIDR block. The Service CIDR block can be used only within the cluster.
Service Port Range
NodePort port range
The default port range is 30000 to 32767. The port range can be changed to 20106 to 32767. After changing the value, go to the security group page and change the TCP/UDP port range of node security groups 30000 to 32767. Otherwise, ports other than the default port cannot be accessed from external networks.
If the port number is smaller than 20106, a conflict may occur between the port and the system health check port, which may further lead to unavailable cluster. If the port number is greater than 32767, a conflict may occur between the port and the random port of the OS, which may further affect the performance.
Container CIDR Blocks (Available only in Clusters Using the VPC Network Model)
If a container CIDR block configured during cluster creation cannot meet service expansion requirements, you can add more container CIDR blocks. For details, see Expanding the Container CIDR Block of a Cluster That Uses a VPC Network.
  • This function is available only in clusters of v1.19 or later using a VPC network.
  • An added container CIDR block cannot be deleted.
Container Network (Available only in CCE Turbo Clusters)
If you want different namespaces or workloads to use different subnet CIDR blocks or security groups, you can create a policy to associate subnets or security groups with namespaces or workloads. For details, see Binding a Subnet and Security Group to a Namespace or Workload Using a Container Network Configuration.
  • Pod Subnet: Pod IP addresses are allocated from this subnet. Only the pods in the same namespace or for running the same workload can communicate with each other.
  • Associate Security Group: You can configure security group rules for pods in the same namespace or for running the same workload to customize access policies.
This configuration is supported only by CCE Turbo clusters. Pod subnets can be deleted from clusters of v1.23.17-r0, v1.25.12-r0, v1.27.9-r0, v1.28.7-r0, v1.29.3-r0, and later versions.
Container Network Pre-binding Settings (Available only in CCE Turbo Clusters)
A CCE Turbo cluster requests for and binds a network interface or supplementary network interface to each pod. Pods support fast scaling. However, it takes some time to create and bind a network interface to a pod, which slows down the pod startup speed if large-scale network interfaces are to be created in batches. Dynamic container network interface pre-binding is enabled by default to speed up pod startup while improving the IP address usage. Cluster pre-binding policies take effect globally. Cluster nodes will pre-bind container network interfaces based on the configured policies. To configure a separate pre-binding policy for a group of nodes, enable node pool pre-binding.
All Container ENI Pre-binding
  • After this function is enabled, your cluster nodes will request for and be pre-bound with the maximum number of network interfaces supported by the node flavor. For example, if the maximum number of supplementary network interfaces supported by an s7.large.2 node is 16, CCE will dynamically pre-bind 16 supplementary network interfaces to this node.
  • After this function is disabled, you can customize the pre-binding parameters on the console.
    Table 3 Parameters of the dynamic elastic network interface pre-binding policy
    Default Value
    Suggestion
    Minimum Number of Container ENIs Bound to a Node
    10
    Minimum number of container elastic network interfaces bound to a node.
    The parameter value must be a positive integer. The value 10 indicates that there are at least 10 container elastic network interfaces bound to a node. If the number you entered exceeds the container elastic network interface quota of the node, the elastic network interface quota of the node will be used.
    Configure these parameters based on the number of pods typically running on most nodes.
    Upper Limit of Pre-bound Container ENIs
    0
    If the number of elastic network interfaces bound to a node exceeds the value of nic-maximum-target, the system does not proactively pre-bind elastic network interfaces.
    If the value of this parameter is greater than or equal to the value of nic-minimum-target, the check on the maximum number of the pre-bound elastic network interfaces is enabled. Otherwise, the check is disabled.
    The parameter value must be a positive integer. The value 0 indicates that the check on the upper limit of pre-bound container elastic network interfaces is disabled. If the number you entered exceeds the container elastic network interface quota of the node, the elastic network interface quota of the node will be used.
    Configure these parameters based on the maximum number of pods running on most nodes.
    Container ENIs Dynamically Pre-bound to a Node
    2
    Minimum number of pre-bound elastic network interfaces on a node. The value must be a number.
    When the value of nic-warm-target + the number of bound elastic network interfaces is greater than the value of nic-maximum-target, the system will pre-bind elastic network interfaces based on the difference between the value of nic-maximum-target and the number of bound elastic network interfaces.
    Set this parameter to the number of pods that can be scaled out instantaneously within 10 seconds.
    Threshold for Unbinding Pre-bound Container ENIs
    2
    Only when the number of idle elastic network interfaces on a node minus the value of nic-warm-target is greater than the threshold, the pre-bound elastic network interfaces will be unbound and reclaimed. The value can only be a number.
    • Setting a larger value of this parameter slows down the recycling of idle elastic network interfaces and accelerates pod startup. However, the IP address usage decreases, especially when IP addresses are insufficient. Therefore, exercise caution when increasing the value of this parameter.
    • Setting a smaller value of this parameter accelerates the recycling of idle elastic network interfaces and improves the IP address usage. However, when a large number of pods increase instantaneously, the startup of some pods slows down.
    Set this parameter based on the difference between the number of pods that are frequently scaled on most nodes within minutes and the number of pods that are instantly scaled out on most nodes within 10 seconds.
