Updated on 2026-09-29 GMT+08:00
LoadBalancer Service Annotations
You can add annotations to a YAML file to enable advanced CCE functions. This section describes the available annotations when a LoadBalancer Service is created.
Interconnection with ELB
Table 1 Annotations for interconnecting with ELB
Type
Supported Cluster Version
kubernetes.io/elb.class
String
Select a proper load balancer type. This parameter cannot be modified after the Service is created.
Options:
The default value is union.
v1.9 or later
kubernetes.io/elb.id
String
Mandatory when an existing load balancer is associated. This parameter cannot be modified after the Service is created.
ID of a load balancer.
How to obtain:
Log in to the ELB console and click the load balancer name. On the Summary tab of the load balancer details page, find the ID field and copy it.
The system preferentially uses the kubernetes.io/elb.id annotation to associate the Service with a load balancer. If this annotation is not specified, it falls back to the spec.loadBalancerIP field. spec.loadBalancerIP may be deprecated in future Kubernetes versions. Therefore, using annotations is recommended. For details, see Deprecation.
v1.9 or later
kubernetes.io/elb.autocreate
Table 28
Mandatory when load balancers are automatically created. This parameter cannot be modified after the Service is created.
CAUTION:
kubernetes.io/elb.id and kubernetes.io/elb.autocreate cannot be specified concurrently.
If both annotations are specified in a Service, CCE will use an existing load balancer instead of automatically creating one. If this Service is deleted, the existing load balancer is considered as an automatically created one. If no other resources are associated with the load balancer, the load balancer will also be deleted.
Example:
  • Automatically created dedicated load balancer with an EIP bound:
    '{"type":"public","bandwidth_name":"cce-bandwidth-1741230802502","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_bgp","available_zone":["*****"],"elb_virsubnet_ids":["*****"],"l7_flavor_name":"","l4_flavor_name":"L4_flavor.elb.pro.max","vip_subnet_cidr_id":"*****"}'
  • Automatically created dedicated load balancer with no EIP bound:
    '{"type":"inner","available_zone":["*****"],"elb_virsubnet_ids":["*****"],"l7_flavor_name":"","l4_flavor_name":"L4_flavor.elb.pro.max","vip_subnet_cidr_id":"*****"}'
  • Automatically created shared load balancer with an EIP bound:
    '{"type":"public","bandwidth_name":"cce-bandwidth-1551163379627","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_bgp","name":"james"}'
  • Automatically created shared load balancer with no EIP bound:
    {"type":"inner","name":"A-location-d-test"}
  • Automatically created dedicated load balancer with an EIP added to a shared bandwidth
    '{"type":"public","bandwidth_id":"*****","bandwidth_sharetype":"WHOLE","eip_type":"5_bgp","available_zone":["*****"],"elb_virsubnet_ids":["*****"],"l7_flavor_name":"","l4_flavor_name":"L4_flavor.elb.pro.max","vip_subnet_cidr_id":"*****"}'
  • Automatically created shared load balancer with an EIP added to a shared bandwidth
    '{"type":"public","bandwidth_id":"*****","bandwidth_sharetype":"WHOLE","eip_type":"5_bgp","name":"james"}'
v1.9 or later
kubernetes.io/elb.enterpriseID
String
Optional when load balancers are automatically created.
This parameter is available in clusters v1.15 or later. In clusters earlier than v1.15, load balancers are created in the default project by default.
This parameter indicates the ID of the enterprise project in which the ELB load balancer will be created.
If this parameter is not specified or is set to 0, resources will be bound to the default enterprise project.
How to obtain:
Log in to the EPS console, click the name of the target enterprise project. On the enterprise project details page, find the ID field and copy the ID.
v1.15 or later
kubernetes.io/elb.subnet-id
String
ID of the subnet where the cluster is located. The value can contain 1 to 100 characters.
  • Mandatory when a cluster v1.11.7-r0 or earlier will be automatically created.
  • Optional for clusters of a version later than v1.11.7-r0.
Mandatory for clusters of a version earlier than v1.11.7-r0
Discarded in clusters of a version later than v1.11.7-r0
kubernetes.io/elb.lb-algorithm
String
Specifies the load balancing algorithm of the backend server group. The default value is ROUND_ROBIN.
Options:
  • ROUND_ROBIN: weighted round robin algorithm
  • LEAST_CONNECTIONS: weighted least connections algorithm
  • SOURCE_IP: source IP hash algorithm
If this parameter is set to SOURCE_IP, the weight setting (weight field) of backend servers bound to the backend server group is invalid, and sticky session cannot be enabled.
v1.9 or later
The following shows how to use the preceding annotations:
  • Associate an existing load balancer. For details, see Using kubectl to Create a Service (Using an Existing Load Balancer).
    apiVersion: v1
    kind: Service
      annotations:
        kubernetes.io/elb.id: <your_elb_id>                         # Load balancer ID. Replace it with the actual value.
        kubernetes.io/elb.class: performance                        # Load balancer type
        kubernetes.io/elb.lb-algorithm: ROUND_ROBIN                   # Load balancer algorithm
      selector:
         app: nginx
      ports:
      - name: service0
        port: 80
        protocol: TCP
        targetPort: 80
      type: LoadBalancer
  • Automatically create a load balancer. For details, see Using kubectl to Create a Service (Automatically Creating a Load Balancer).
    Shared load balancer:
    apiVersion: v1
    kind: Service
      annotations:
        kubernetes.io/elb.class: union
        kubernetes.io/elb.autocreate: '{
          "type": "public",
          "bandwidth_name": "cce-bandwidth-1551163379627",
          "bandwidth_chargemode": "bandwidth",
          "bandwidth_size": 5,
          "bandwidth_sharetype": "PER",
          "eip_type": "5_bgp"
        kubernetes.io/elb.enterpriseID: '0'               # ID of the enterprise project to which the load balancer belongs
      labels:
        app: nginx
      ports:
      - name: service0
        port: 80
        protocol: TCP
        targetPort: 80
      selector:
        app: nginx
      type: LoadBalancer
    Dedicated load balancer:
    apiVersion: v1
    kind: Service
      labels:
        app: nginx
      namespace: default
      annotations:
          "type": "public",
          "bandwidth_name": "cce-bandwidth-1626694478577",
          "eip_type": "5_bgp",
          "available_zone": [
          "l4_flavor_name": "L4_flavor.elb.s1.small"
      selector:
        app: nginx
      ports:
      - name: cce-service-0
        targetPort: 80
        nodePort: 0
        port: 80
        protocol: TCP
      type: LoadBalancer
Sticky Session
Table 2 Annotations for sticky session
Type
kubernetes.io/elb.session-affinity-mode
String
Source IP address-based sticky session means that access requests from the same IP address are forwarded to the same backend server.
  • To disable sticky sessions, leave this parameter unconfigured.
  • To enable sticky session, add this parameter and set it to SOURCE_IP, indicating that the sticky session is based on the source IP address.
When kubernetes.io/elb.lb-algorithm is set to SOURCE_IP (source IP hash), sticky session cannot be enabled.
v1.9 or later
kubernetes.io/elb.session-affinity-option
Table 31
Sticky session timeout.
v1.9 or later
apiVersion: v1
kind: Service
  annotations:
    kubernetes.io/elb.session-affinity-mode: SOURCE_IP          # The sticky session type is source IP address.
    kubernetes.io/elb.session-affinity-option: '{"persistence_timeout": "30"}'     # Stickiness duration, which is measured in minutes
  selector:
     app: nginx
  ports:
  - name: service0
    port: 80
    protocol: TCP
    targetPort: 80
  type: LoadBalancer
Health Check
Table 3 Annotations for health check
Type
kubernetes.io/elb.health-check-flag
String
Whether to enable the ELB health check. If this annotation is not added, the health check is enabled by default.
  • Enabling health check: Leave this parameter blank or set it to on.
  • Disabling health check: Set this parameter to off.
If this function is enabled, you must set kubernetes.io/elb.health-check-option or kubernetes.io/elb.health-check-options. Otherwise, ELB health checks will fail.
v1.9 or later
Table 29
ELB health check configuration option.
v1.9 or later
Table 30
ELB health check configuration options. Each Service port can be configured separately, and you can configure only some ports.
Either kubernetes.io/elb.health-check-option or kubernetes.io/elb.health-check-options can be configured.
v1.19.16-r5 or later
v1.21.8-r0 or later
v1.23.6-r0 or later
v1.25.2-r0 or later
  • The following shows how to use kubernetes.io/elb.health-check-option:
    apiVersion: v1
    kind: Service
      annotations:
        kubernetes.io/elb.health-check-flag: 'on'                   # Enable ELB health check.
        kubernetes.io/elb.health-check-option: '{
          "protocol":"TCP",
          "delay":"5",
          "timeout":"10",
          "max_retries":"3"
      selector:
         app: nginx
      ports:
      - name: service0
        port: 80
        protocol: TCP
        targetPort: 80
      type: LoadBalancer
  • For details about how to use kubernetes.io/elb.health-check-options, see Configuring Health Check on Multiple LoadBalancer Service Ports.
Passthrough Capability
Table 4 Annotations for passthrough capability
Type
kubernetes.io/elb.pass-through
String
Whether the access requests from within the cluster to the Service pass through the ELB load balancer.
v1.19 or later
For details about applications and use cases, see Configuring Passthrough Networking for a LoadBalancer Service.
Resource Tags
Table 5 Annotations
Type
kubernetes.io/elb.tags
String
Add resource tags to a load balancer. This parameter can be configured only when a load balancer is automatically created.
A tag is in the format of "key=value". Use commas (,) to separate multiple tags.
v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, v1.23.8-r1, v1.25.3-r1, or later
For details about applications and use cases, see Using kubectl to Create a Service (Automatically Creating a Load Balancer).
Changing a Custom EIP
Table 6 Annotations for changing a custom EIP
Type
kubernetes.io/elb.custom-eip-id
String
ID of the custom EIP, which can be seen on the EIP console.
The EIP must not already be bound.
v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, v1.29.4-r0, v1.30.1-r0, or later
For details about applications and use cases, see Changing a Custom EIP for a LoadBalancer Service.
Configuring a Reclaim Policy for an Auto-created Load Balancer
Table 7 Annotation for configuring a reclaim policy for an auto-created load balancer
Type
kubernetes.io/elb.instance-reclaim-policy
String
Configure a reclaim policy for an auto-created load balancer. The options are as follows:
  • (Default) Absence of the parameter or presence as blank: The auto-created load balancer is deleted along with the Service/ingress. However, if the load balancer is associated with multiple Services/ingresses and the Service/ingress that is created along with the load balancer is deleted first, the load balancer may be retained even after all its associated Services/ingresses are deleted.
  • retain: The auto-created load balancer is retained when the Service/ingress is deleted.
  • alwaysDelete: The auto-created load balancer is deleted along with the Service/ingress. If the load balancer is associated with multiple Services/ingresses, it will be deleted only after all its associated Services/ingresses are deleted.
  • If an auto-created load balancer is associated with other resources or its billing mode is changed to yearly/monthly, it will be retained even if the reclaim policy is not set to retain.
  • If an auto-created load balancer is associated with multiple Services/ingresses, this parameter applies only to the Service/ingress that is created along with the load balancer.
v1.28.15-r60, v1.29.15-r20, v1.30.14-r20, v1.31.10-r20, v1.32.6-r20, v1.33.5-r10, or later
The following shows how to use the preceding annotation:
apiVersion: v1
kind: Service
  labels:
    app: test
    version: v1
  namespace: default
  annotations:
    kubernetes.io/elb.autocreate: '{"type":"inner","available_zone":["******"],"elb_virsubnet_ids":["******"],"ipv6_vip_virsubnet_id":"******","l7_flavor_name":"","l4_flavor_name":"L4_flavor.elb.pro.max","vip_subnet_cidr_id":"******"}'
    kubernetes.io/elb.health-check-option: '{"protocol":"TCP","delay":"5","timeout":"10","max_retries":"3"}'
    kubernetes.io/elb.instance-reclaim-policy: retain   # Configure a reclaim policy for an auto-created load balancer.
  selector:
    app: nginx
    version: v1
  externalTrafficPolicy: Cluster
  ports:
      targetPort: 80
      nodePort: 0
      port: 80
      protocol: TCP
  type: LoadBalancer
  loadBalancerIP: ''
HTTP/HTTPS/QUIC
Table 8 Annotations for using HTTP or HTTPS
Type
kubernetes.io/elb.protocol-port
String
If a Service is HTTP/HTTPS/QUIC-compliant, configure the protocol and port in the format of protocol:port.
where,
  • protocol: specifies the protocol used by the listener port. The value can be http, quic, or https.
  • port: Service port specified by spec.ports[].port.
v1.19.16 or later
v1.28.15-r80, v1.29.15-r40, v1.30.14-r40, v1.31.14-r0, v1.32.9-r0, v1.33.7-r0, v1.34.2-r0, or later (if QUIC is used)
kubernetes.io/elb.cert-id
String
ID of an ELB certificate, which is used as the HTTPS server certificate.
How to obtain: Log in to the ELB console and choose Certificates. In the certificate list, copy the ID under the target certificate name.
v1.19.16 or later
For details about applications and use cases, see Configuring HTTP/HTTPS for LoadBalancer Services and Configuring a QUIC Listener for a LoadBalancer Service.
SNI
Table 9 Annotations for using SNIs
Type
kubernetes.io/elb.tls-certificate-ids
String
In ELB, the IDs of SNI certificates that must contain a domain name are separated by commas (,).
v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later
HTTPS must be enabled. For details, see Configuring SNI for a LoadBalancer Service.
HTTP/2
Table 10 Annotations for using HTTP/2
Type
kubernetes.io/elb.http2-enable
String
Whether HTTP/2 is enabled. Request forwarding using HTTP/2 improves access performance between your application and the load balancer. However, the load balancer still uses HTTP/1.x to forward requests to the backend server.
Options:
  • true: enabled
  • false: disabled (default value)
Note: HTTP/2 can be enabled or disabled only when the listener uses HTTPS. This parameter is invalid and defaults to false when the listener protocol is HTTP.
For details about applications and use cases, see Configuring HTTP/2 for LoadBalancer Services.
Configuring Mutual Authentication
Table 11 Annotation for configuring mutual authentication
Type
kubernetes.io/elb.client-ca-cert-id
String
Required only for mutual authentication. The ELB certificate ID serves as the CA certificate.
Dedicated load balancers are available in clusters v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later. Shared load balancers are available in clusters v1.28.15-r60, v1.29.15-r20, v1.30.14-r20, v1.31.10-r20, v1.32.6-r20, v1.33.5-r10, or later.
apiVersion: v1
kind: Service
  labels:
    app: test
  namespace: default
  annotations:
    kubernetes.io/elb.id: *****
    kubernetes.io/elb.protocol-port: https:443
    kubernetes.io/elb.cert-id: *****
    kubernetes.io/elb.client-ca-cert-id: *****   # Configure mutual authentication.
    kubernetes.io/elb.security-pool-protocol: 'off'
    kubernetes.io/elb.tls-ciphers-policy: tls-1-2
  selector:
    app: test
  ports:
      targetPort: 80
      nodePort: 0
      port: 443
      protocol: TCP
  type: LoadBalancer
  loadBalancerIP: **.**.**.**
Configuring the Backend Routing Policy of a Listener
For details about applications and use cases, see Configuring a UDP listener for the QUIC Protocol for a LoadBalancer Service.
Table 12 Annotation for configuring the backend routing policy of a listener
Type
kubernetes.io/elb.pools-options
String
Backend server group configuration, including the backend protocol, load balancing algorithm, and sticky session.
The annotation value is a JSON array. For details, see Table 13.
CAUTION:
After the kubernetes.io/elb.pools-options annotation is configured, the legacy annotations for load balancing algorithm (kubernetes.io/elb.lb-algorithm), sticky sessions (kubernetes.io/elb.session-affinity-option or kubernetes.io/elb.session-affinity-options), or backend protocol (kubernetes.io/elb.security-pool-protocol) cannot be used.
The following is an example of using the preceding annotation:
apiVersion: v1
kind: Service
  labels:
    app: nginx
  namespace: default
  annotations:
    kubernetes.io/elb.id: 95df847a-dec7-4c7f-8e8b-5422344f6153
    kubernetes.io/elb.cert-id: d30be9bc114a40099bc2c8e4d1855eb3
    kubernetes.io/elb.pools-options: '[{"protocol":"HTTP","lb_algorithm":"ROUND_ROBIN","target_service_port":"TCP:443"}]'
  selector:
    app: nginx
  ports:
      targetPort: 80
      nodePort: 0
      port: 443
      protocol: TCP
  type: LoadBalancer
Table 13 Parameters for configuring a backend server group
Mandatory
Type
protocol
Yes
String
Definition: Protocol of a backend server. If the frontend protocol and port remain unchanged, the backend protocol cannot be modified.
Constraints: The custom configuration must match the protocol of the frontend listener. For details about the matching rules, see Mapping Between Frontend and Backend Protocols for Load Balancing and Configuration Examples. No constraints apply to global configurations.
Range: TCP, TLS, UDP, HTTP, HTTPS, or QUIC
Default value: N/A
target_service_port
No
String
Definition: The backend server group to which the configuration applies. The value is composed of the protocol and port defined in spec.ports. For example, TCP:80 applies the configuration to the backend server group using TCP on port 80. If omitted or set to *, the configuration is treated as global and applies to all backend server groups.
Constraints: For global configuration, the array length must be 1. A Service may contain listeners with different frontend protocols, but backend protocol options are limited. If this parameter is set globally and the backend protocol does not match the frontend protocol, the default value will be used. For details about the matching rules, see Mapping Between Frontend and Backend Protocols for Load Balancing and Configuration Examples. Other parameters depend on the backend protocol, so defaults may be applied when mismatches occur.
Range: <protocol>:<port>
Default value: None (Global configuration is used.)
lb_algorithm
Yes
String
Definition: The load balancing algorithm used by a backend server group
Constraints:
  • If set to SOURCE_IP or QUIC_CID, the weights of backend servers in the backend server group are invalid.
  • QUIC_CID is supported only when the backend protocol of the backend server group is QUIC.
Range:
  • QUIC_CID: QUIC connection ID hash
Default value: If the backend protocol is QUIC, the value can only be QUIC_CID. The default value is ROUND_ROBIN for other protocols.
session_persistence
No
SessionPersistence
Definition: The sticky session settings
Constraints: None
Default value: Disabled
quic_cid_hash_strategy
No
QuicCidHashStrategy
Definition: The multi-path forwarding behavior based on destination QUIC connection IDs
Constraints: This parameter can be configured only when lb_algorithm is set to QUIC_CID.
Default value: N/A
Dynamically Adjusting the Weight of the Backend Server
Table 14 Annotation for dynamically adjusting the weight of the backend server
Type
kubernetes.io/elb.adaptive-weight
String
Dynamically adjust the weight of the load balancer backend server based on the number of pods on the server. In this way, the requests received by each pod are more balanced.
  • true: enabled
  • false: disabled
v1.21 or later
This parameter is invalid in passthrough networking, where dedicated load balancers are used in the CCE Turbo cluster.
This parameter is invalid after cross-cluster ELB access is enabled.
apiVersion: v1
kind: Service
  annotations:
    kubernetes.io/elb.adaptive-weight: 'true'                   # Enable dynamic adjustment of the weight of the backend ECS.
  selector:
     app: nginx
  ports:
  - name: service0
    port: 80
    protocol: TCP
    targetPort: 80
  type: LoadBalancer
Cross-cluster Access
Table 15 Annotations
Type
kubernetes.io/elb.multicluster
String
Value true indicates cross-cluster Service access is enabled.
v1.19.16-r0, v1.21.4-r0, v1.23.1-r0, or later
kubernetes.io/elb.multivpc
String
Value true indicates cross-cluster access in different VPCs is enabled. This function is available only if kubernetes.io/elb.multicluster is set to true. This parameter cannot be modified after the Service is created.
Only dedicated load balancers are supported.
v1.19.16-r4, v1.21.7-r0, v1.23.5-r0, or later
kubernetes.io/elb.multicluster-loadbalancer-weight
String
Weight of the traffic received by the cluster Service. The value ranges from 0 to 100. A larger value indicates more traffic distributed.
kubernetes.io/elb.multicluster-resource-recycle-policy
String
Policy for deleting ELB resources. The default value of this parameter is member-only.
  • member-only: Only the backend servers of the load balancer will be deleted when the Service is deleted.
  • cascade: All ELB resources will be deleted when the Service is deleted.
For details about applications and use cases, see Configuring Multiple Cross-Cluster Backend Servers for a LoadBalancer Service.
Blocklist/Trustlist
Table 16 Annotations for ELB access control
Type
kubernetes.io/elb.acl-id
String
  • If this parameter is not specified, CCE does not modify access control on the ELB.
  • If this parameter is left empty, all IP addresses are allowed to access the load balancer.
  • If this parameter is set to the IP address group ID of the load balancer, access control is enabled and you need to configure an IP address blocklist or trustlist for the load balancer. Additionally, you need to configure both kubernetes.io/elb.acl-status and kubernetes.io/elb.acl-type.
    For clusters v1.25.16-r10, v1.27.16-r10, v1.28.15-r0, v1.29.10-r0, v1.30.6-r0, v1.31.1-r0, or later, when using a dedicated load balancer, you can select a maximum of five IP address groups at a time, separated by commas (,).
    How to obtain:
    Log in to the ELB console, choose Elastic Load Balance > IP Address Groups, and copy the ID of the target IP address group. For details, see Creating an IP Address Group.
v1.23.12-r0, v1.25.7-r0, v1.27.4-r0, v1.28.2-r0, or later
String
This parameter is mandatory when you configure an IP address blocklist or trustlist for a load balancer. Options:
  • on or true: Access control is enabled.
  • off or false: Access control is disabled.
String
  • black: indicates a blocklist. The selected IP address group cannot access the load balancer.
  • white: indicates a trustlist. Only the selected IP address group can access the load balancer.
apiVersion: v1
kind: Service
  annotations:
    kubernetes.io/elb.acl-id: <your_acl_id>               # ID of an IP address group for accessing a load balancer
    kubernetes.io/elb.acl-status: 'on'                    # Enable access control.
    kubernetes.io/elb.acl-type: 'white'                   # Trustlist for access control
  selector:
     app: nginx
  ports:
  - name: service0
    port: 80
    protocol: TCP
    targetPort: 80
  type: LoadBalancer
For details about applications and use cases, see Configuring a Blocklist/Trustlist Access Policy for a LoadBalancer Service.
Host Network
Table 17 Annotation for host network
Type
kubernetes.io/hws-hostNetwork
String
This annotation can be used by the Service only if the pod uses the host network. After this annotation is used, ELB forwards requests to the host network.
Options:
  • true: enabled
  • false (default): disabled
v1.9 or later
apiVersion: v1
kind: Service
  annotations:
    kubernetes.io/hws-hostNetwork: 'true'                     # The load balancer forwards the request to the host network.
  selector:
     app: nginx
  ports:
  - name: service0
    port: 80
    protocol: TCP
    targetPort: 80
  type: LoadBalancer
Timeout
Table 18 Annotation for configuring timeout
Type
kubernetes.io/elb.keepalive_timeout
String
Timeout for client connections. If there are no requests reaching the load balancer during this period, the load balancer will disconnect the connection from the client and establish a new connection when there is a new request.
Value:
  • For TCP listeners, the value ranges from 10 to 4000 (in seconds). The default value is 300.
  • For HTTP, TERMINATED_HTTPS, or HTTPS listeners, the value ranges from 0 to 4000 (in seconds). The default value is 60.
  • For UDP listeners (supported only by dedicated load balancers), the value ranges from 10 to 4000 (in seconds). The default value is 300.
Dedicated load balancers: v1.19.16-r30, v1.21.10-r10, v1.23.8-r10, v1.25.3-r10, or later
Shared load balancers: v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later
kubernetes.io/elb.client_timeout
String
Timeout for waiting for a request from a client. There are two cases:
  • If the client fails to send a request header to the load balancer during this period, the request will be interrupted.
  • If the interval between two consecutive request bodies reaching the load balancer exceeds this period, the connection will be disconnected.
The value ranges from 1 to 300 (in seconds). The default value is 60.
kubernetes.io/elb.member_timeout
String
Timeout for backend server response. After a request is forwarded to the backend server, if the backend server does not respond within the duration specified by member_timeout, the load balancer will stop waiting and return HTTP 504 Gateway Timeout.
For details about applications and use cases, see Configuring Timeout for a LoadBalancer Service.
Configuring an HTTP/HTTPS Header
Table 19 Annotations for configuring an HTTP/HTTPS header
Type
kubernetes.io/elb.x-forwarded-port
String
Enables the load balancer to pass the listener port to backend servers via the X-Forwarded-Port header field in forwarded requests.
  • true: Enable
  • false: Disable
kubernetes.io/elb.x-forwarded-for-port
String
Enables the load balancer to pass the client port to backend servers via the X-Forwarded-For-Port header field in forwarded requests.
  • true: Enable
  • false: Disable
kubernetes.io/elb.x-forwarded-host
String
  • true: Enable the function of rewriting X-Forwarded-Host. Then, the X-Forwarded-Host header will be rewritten using the Host header of the client request and transmitted to backend servers.
  • false: Disable the function of rewriting X-Forwarded-Host. Then, the X-Forwarded-Host header of the client will be transmitted to backend servers.
kubernetes.io/elb.x-real-ip
String
  • true: Enable the function of rewriting X-Real-IP. The source IP address of the client will be written into the X-Real-IP header and transmitted to the backend servers.
  • false: Disable the function of rewriting X-Real-IP. The X-Real-IP header of the client will be transmitted to the backend servers.
v1.25.16-r30, v1.27.16-r30, v1.28.15-r20, v1.29.13-r0, v1.30.10-r0, v1.31.6-r0, v1.32.1-r0, or later
For details about applications and use cases, see Configuring an HTTP/HTTPS Header for a LoadBalancer Service.
Enabling GZIP
Table 20 Annotations for enabling GZIP
Type
kubernetes.io/elb.gzip-enabled
String
LoadBalancer Services support data compression, which reduces the size of files to be transferred, improves file transfer efficiency, and reduces the bandwidth needed for the transmission.
If this function is enabled, specific files will be compressed. If it is not enabled, files will not be compressed. By default, data compression is disabled.
The files in the following format can be compressed:
  • Brotli can compress all file formats.
  • GZIP can compress the files of the following types: text/xml, text/plain, text/css, application/javascript, application/x-javascript, application/rss+xml, application/atom+xml, application/xml, and application/json
This function is available only for HTTP/HTTPS listeners of dedicated load balancers. Deleting the advanced configuration for data compression or the target annotations will not modify the existing ELB settings.
For details about applications and use cases, see Configuring GZIP Data Compression for a LoadBalancer Service.
Configuring Graceful Exit for the Load Balancer Backend
You can configure the graceful exit time for the backend servers of load balancers associated with TCP- or UDP-compliant Services. Graceful exit is set to 300s by default.
ELB does not offer this feature to everyone. This feature is only supported by dedicated load balancers. To use this feature, submit a service ticket to ELB.
Table 21 Annotations for the graceful exit of the load balancer backend
Type
kubernetes.io/elb.connection-drain-enable
String
Whether to enable graceful exit for the load balancer backend.
  • true: This function is enabled.
  • false: This function is disabled.
kubernetes.io/elb.connection-drain-timeout
String
Graceful exit time of the load balancer backend. The value ranges from 10 to 4000 (in seconds). The default value is 300.
Obtaining Client IP Addresses
Table 22 Annotations for obtaining client IP addresses
Type
kubernetes.io/elb.transparent-client-ip
String
This parameter is available only when a shared load balancer is used to create a LoadBalancer Service that is TCP/UDP-compliant.
  • true: Enabling the function of obtaining the client source IP address.
  • false: Disabling the function of obtaining the client source IP address.
v1.23.17-r0, v1.25.12-r0, v1.27.9-r0, v1.28.7-r0, v1.29.3-r0, or later
For details about applications and use cases, see Enabling a LoadBalancer Service to Obtain the Client IP Address.
Configuring Port Ranges for a Listener
Table 23 Annotations for configuring port ranges for a listener
Type
kubernetes.io/elb.port-ranges
String
When using a dedicated load balancer with TCP, UDP, or TLS selected, you can create listeners that monitor ports within a range from 1 to 65535. Each listener supports a maximum of 10 non-overlapping port ranges.
The parameter value is in the following format, where ports_name and port must be unique:
 '{"<ports_name_1>":["<port_1>,<port_2>","<port_3>,<port_4>"], "<ports_name_2>":["<port_5>,<port_6>","<port_7>,<port_8>"]}'
For example, the port names are cce-service-0 and cce-service-1, and the listener listens to ports 100–200 and 300–400, and 500–600 and 700–800, respectively.
'{"cce-service-0":["100,200", "300,400"], "cce-service-1":["500,600", "700,800"]}'
This function requires ELB. Before using this function, check whether ELB supports full-port listening and forwarding for layer-4 protocols in the current region.
For details about applications and use cases, see Configuring a Range of Listening Ports for LoadBalancer Services.
Configuring IP Addresses as Backend Servers
Table 24 Annotation for configuring IP addresses as backend servers
Type
kubernetes.io/elb.ip-target-enabled
String
Enable IP addresses as backend servers for a load balancer. After this function is enabled, the backend IP addresses added to the associated Service or ingress are all IP addresses in VPC subnets. For a CCE Turbo cluster, the backend is <pod-IP-address>:<target-port>. For a CCE standard cluster, the backend is <node-IP-address>:<NodePort>.
  • true: Enable IP addresses as backend servers.
  • Other values are not supported.
CAUTION:
  • Only dedicated load balancers support this function.
  • This function can only be enabled during Service or ingress creation. Annotations cannot be added to or removed from existing resources. To use this function, recreate the Service or ingress.
  • If the load balancer associated with a Service or ingress does not have IP as a backend enabled, CCE will automatically enable it when the annotation is applied. This setting cannot be disabled once enabled.
  • Ensure that the backend subnets of the load balancer associated with the Service or ingress have sufficient IP addresses, or this function cannot be used. If the IP addresses are not enough, you can add more backend subnets on the Summary page of the load balancer.
  • For more details, see Using IP as a Backend to Route Traffic Across Backend Servers.
For details about applications and use cases, see Configuring IP Addresses as Backend Servers for a LoadBalancer Service.
Configuring the Weight of StatefulSet Backend Pods
Table 25 Annotations for configuring the weight of StatefulSet backend pods
Type
kubernetes.io/elb.custom-backend-weights
String
The weight of StatefulSet backend pods. This function is supported only by CCE Turbo clusters and dedicated load balancers.
v1.29.15-r60, v1.30.14-r60, v1.31.14-r20, v1.32.9-r20, v1.33.7-r20, v1.34.3-r10, v1.35.1-r0, or later
For details about applications and use cases, see Configuring Weights for StatefulSet Backend Pods in a LoadBalancer Service.
Disabling Listener Hosting for an Associated LoadBalancer Service
Table 26 Annotations for canceling listener hosting of an associated LoadBalancer Service
Type
kubernetes.io/elb.skip-managed-listener
String
Disables listener hosting. Once disabled, CCE no longer manages the listener associated with this Service.
  • true: disables listener hosting when creating a Service. CCE creates only the backend server group, health check, and backend server members, but does not create or manage any listener.
  • Not set or set to another value: retains the default behavior. CCE fully manages the listener.
v1.29.15-r90, v1.30.14-r90, v1.31.14-r50, v1.32.13-r20, v1.33.12-r0, v1.34.8-r0, v1.35.5-r0, v1.36.1-r10, or later
For details about applications and use cases, see Disabling Listener Hosting for LoadBalancer Services.
Configuring Rate Limiting for New and Concurrent Connections
Table 27 Annotations for configuring rate limiting on new and concurrent connections
Type
kubernetes.io/elb.cps
Integer
Definition: The maximum number of new connections that a listener can handle per second.
Constraints: If this value exceeds the limit defined in the load balancer, the load balancer's limit takes precedence.
Range: 0 to 1000000
Default value: 0, indicating no limit.
v1.30.14-r100, v1.31.14-r60, v1.32.13-r30, v1.33.12-r10, v1.34.8-r10, v1.35.5-r10, v1.36.2-r0, or later
Integer
Definition: The maximum number of concurrent connections that a listener can handle.
Range: 0 to 1000000
For details about applications and use cases, see Configuring Rate Limiting on a LoadBalancer Service for New and Concurrent Connections.
Parameters for Automatically Creating a Load Balancer
Table 28 elb.autocreate data structure
Mandatory
Type
name
No
String
Name of the automatically created load balancer.
The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed.
Default: cce-lb+service.UID
type
No
String
Network type of the load balancer.
  • public: public network load balancer
  • inner: private network load balancer
Default: inner
bandwidth_id
No
String
Shared bandwidth ID, which must be specified when you use an existing shared bandwidth. The cluster version must be v1.30.14-r100, v1.31.14-r60, v1.32.13-r30, v1.33.12-r10, v1.34.8-r10, v1.35.5-r10, v1.36.2-r0, or later.
bandwidth_name
Yes for public network load balancers when no shared bandwidth ID is provided
String
Bandwidth name. The default value is cce-bandwidth-******.
String
Bandwidth billing mode.
  • bandwidth: billed by bandwidth
  • traffic: billed by traffic
bandwidth_size
Integer
Bandwidth size. The value ranges from 1 Mbit/s to 2000 Mbit/s by default. Configure this parameter based on the bandwidth range allowed in your region.
The minimum increment for bandwidth adjustment varies depending on the bandwidth range.
  • The minimum increment is 1 Mbit/s if the allowed bandwidth does not exceed 300 Mbit/s.
  • The minimum increment is 50 Mbit/s if the allowed bandwidth ranges from 300 Mbit/s to 1000 Mbit/s.
  • The minimum increment is 500 Mbit/s if the allowed bandwidth exceeds 1000 Mbit/s.
bandwidth_sharetype
String
Bandwidth sharing mode.
  • PER: dedicated bandwidth
  • WHOLE: shared bandwidth. This parameter is supported only in clusters v1.30.14-r100, v1.31.14-r60, v1.32.13-r30, v1.33.12-r10, v1.34.8-r10, v1.35.5-r10, v1.36.2-r0, and later versions.
    When set to WHOLE, the shared bandwidth ID must be specified.
eip_type
String
EIP type.
  • 5_telcom: China Telecom
  • 5_union: China Unicom
  • 5_bgp: dynamic BGP
  • 5_sbgp: static BGP
The types vary by region. For details, see the EIP console.
vip_subnet_cidr_id
No
String
The ID of the IPv4 subnet where the load balancer resides. This subnet is used to allocate IP addresses for the load balancer to provide external services. The IPv4 subnet must belong to the cluster's VPC.
If this parameter is not specified, the load balancer and the cluster will be in the same subnet by default.
This field can be specified only for clusters v1.21 or later.
How to obtain:
Log in to the VPC console. In the navigation pane, choose Subnets. Filter the target subnet by the cluster's VPC name, click the subnet name, and copy the IPv4 Subnet ID on the Summary tab.
No
String
The ID of the IPv6 subnet where the load balancer is deployed. IPv6 must be enabled for the subnet.
This parameter is available only for dedicated load balancers.
How to obtain:
Log in to the VPC console. In the navigation pane, choose Subnets. Filter the target subnet by the cluster's VPC name, click the subnet name, and copy the Network ID on the Summary tab.
elb_virsubnet_ids
No
Array of strings
The network ID of the subnet where the load balancer is located. This subnet is used to allocate IP addresses for accessing the backend server. If this parameter is not specified, the subnet specified by vip_subnet_cidr_id will be used by default. Load balancers occupy varying numbers of subnet IP addresses based on their specifications. Do not use the subnet CIDR blocks of other resources (such as clusters or nodes) as the load balancer's CIDR block.
Example:
"elb_virsubnet_ids": [
   "14567f27-8ae4-42b8-ae47-9f847a4690dd"
How to obtain:
vip_address
No
String
Private IP address of the load balancer. Only IPv4 addresses are supported.
The IP address must be in the ELB CIDR block. If this parameter is not specified, an IP address will be automatically assigned from the ELB CIDR block.
This parameter is only available in clusters v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later versions.
available_zone
Yes
Array of strings
AZ where the load balancer is located.
You can obtain all supported AZs by getting the AZ list.
l4_flavor_name
No
String
Flavor name of the Layer 4 load balancer. This parameter is mandatory when TCP, TLS, or UDP is used.
You can obtain all supported types by getting the flavor list.
l7_flavor_name
No
String
Flavor name of the Layer 7 load balancer. This parameter is mandatory when HTTP or HTTPS is used.
This parameter is available only for dedicated load balancers. Its value must match that of l4_flavor_name, both of which must be either elastic or fixed.
Table 29 elb.health-check-option data structure
Mandatory
Type
delay
No
String
Health check interval (s)
Value range: 1 to 50. Default value: 5
timeout
No
String
Health check timeout, in seconds.
Value range: 1 to 50. Default value: 10
max_retries
No
String
Maximum number of health check retries.
Value range: 1 to 10. Default value: 3
protocol
No
String
Health check protocol.
Value options: HTTPS, TLS, gRPC, TCP, UDP, and HTTP
To use HTTPS, TLS, or gRPC, you need to use a dedicated load balancer, and the cluster version must be v1.28.15-r90, v1.29.15-r50, v1.30.14-r50, v1.31.14-r10, v1.32.9-r10, v1.33.7-r10, v1.34.3-r0, or later. gRPC and TLS depend on the ELB capabilities. Before using this function, submit a service ticket to enable the required ELB capabilities.
  • If the protocol of the backend server group is UDP or QUIC, the health check protocol can only be UDP.
  • If the protocol of the backend server group is TCP, the health check protocol can be TCP, HTTP, or HTTPS.
  • If the protocol of the backend server group is TLS, HTTP, HTTPS, or gRPC, the health check protocol can be TCP, HTTP, HTTPS, TLS, or gRPC.
CAUTION:
To change the health check protocol (including the switchover between global check and custom check), disable the health check, enable it again, and change the protocol.
path
No
String
Health check URL. This parameter needs to be configured when the protocol is HTTP, HTTPS, or gRPC.
Default value: /
Value range: 1-80 characters
Table 30 elb.health-check-options
Mandatory
Type
target_service_port
Yes
String
Port for health check specified by spec.ports. The value consists of the protocol and port number, for example, TCP:80.
monitor_port
No
String
Re-specified port for health check. If this parameter is not specified, the service port is used by default.
Ensure that the port is in the listening state on the node where the pod is located. Otherwise, the health check result will be affected.
delay
No
String
timeout
No
String
max_retries
No
String
protocol
No
String
Default value: protocol of the associated Service
  • When the listener's backend protocol is UDP or QUIC, the health check protocol must be UDP.
  • When the listener's backend protocol is TCP, the health check protocol must be TCP, HTTP, or HTTPS.
  • When the listener's backend protocol is TLS, HTTP, HTTPS, or gRPC, the health check protocol must be TCP, HTTP, HTTPS, TLS, or gRPC.
CAUTION:
path
No
String
Default value: /
expected_codes
No
String
Expected response status code. This parameter is supported only by clusters v1.19.16-r50, v1.21.11-r10, v1.23.9-r10, v1.25.4-r10, v1.27.1-r10, or later.
Value:
  • A specific value, for example, 200
  • A list of values that are separated with commas (,), for example, 200, 202
  • A value range, for example, 200–204
Default value: 200. The status code ranges from 200 to 599. For gRPC health checks, the default value is 0, and the status code ranges from 0 to 99.
This parameter is available only for HTTP, HTTPS, or gRPC. It has no effect on other protocols.
Table 31 elb.session-affinity-option data structure
Mandatory
Type
persistence_timeout
Yes
String
Sticky session timeout, in minutes. This parameter is valid only when elb.session-affinity-mode is set to SOURCE_IP.
Value range: 1 to 60. Default value: 60
