Creating a Blank Standard Page
If the preset standard page templates cannot meet your service requirements, you can create a blank standard page and design it by yourself.
Creating a Standard Page
- Log in to the application designer by referring to Logging In to the Application Designer.
- In the navigation pane, choose Page.
- (Optional) Click
next to Standard Page to add a folder.
By default, standard pages are stored in the root folder. Before creating a standard page, you can create a folder for storing the standard page. You can drag the standard page to a specified folder.
- Move the cursor to a created standard page folder and click
If you do not need to create a standard page folder, click
next to Standard Page. - Select Create from scratch, set the label and name of the standard page, and click Add.
Figure 1 Setting basic information about the standard page
- Design the standard page.
- Add widgets to the standard page by referring to Adding Widgets to Standard Pages.
- Set properties of the standard page widget by referring to Setting Properties of Standard Page Widgets.
- Add interaction actions for the widget by referring to Adding an Event to Implement Interaction Between Widgets.
- Click
in the upper part of the page to save the standard page. - Click
to preview the standard page.
If the preview effect does not meet the expectation, return to the standard page to modify the preview effect until it meets the expectation.
