Overview
Kubernetes logs allow you to locate and rectify faults. This section describes how to manage Kubernetes logs using different methods.
The following are Kubernetes log management methods:
- Use the Cloud Native Log Collection add-on to collect application logs and report them to LTS, which provides log statistics and analysis. For details, see Collecting Container Logs Using the Cloud Native Log Collection Add-on.
- Collect container logs to AOM 1.0. (This method is not recommended because AOM 1.0 will be taken offline soon.) For details, see Collecting Container Logs Using ICAgent (Not Recommended).
- Collect control plane component logs and Kubernetes audit logs from the CCE control plane and add them to the LTS log streams in your account. For details, see Collecting Control Plane Component Logs and Collecting Audit Logs.
- Collect Kubernetes events and add them to the LTS log stream in your account for persistent storage and statistical analysis. For details, see Collecting Kubernetes Events.
- Collects the logs of the Nginx Ingress Controller add-on to analyze traffic changes and obtain service traffic characteristics, providing data support for service decision making. For details, see Collecting NGINX Ingress Controller Logs.
Comparison Between ICAgent and Cloud Native Log Collection
Collection Tool |
ICAgent |
Cloud Native Log Collection |
Log Storage Location |
LTS |
AOM 1.0 |
LTS |
AOM 2.0 |
Content to Be Collected |
- Container stdout logs - Container file logs - Node logs - Kubernetes events |
- Container stdout logs - Container file logs |
- Container stdout logs - Container file logs - Node logs - Kubernetes events - Kubernetes audit logs - Control plane component logs - Add-on logs |
Kubernetes events |
Advantages and Disadvantages |
- Log collection policies and workloads are configured separately. Modifying policies does not affect pod running. - You can specify a container whose logs are to be collected. - Docker and containerd are supported. If a node uses containerd, the ICAgent version must be 5.12.130 or later. - Container file log collection supports overlay2, not Device Mapper. |
- Each workload needs to be configured separately. - Log collection policies are coupled with pods. Modifying policies will restart the pod. |
- Log collection policies and workloads are configured separately. Modifying policies does not affect pod running. - You can specify a container whose logs are to be collected. - If the node storage driver is Device Mapper, container file logs must be collected from the path where the data disk is attached to the node. |
All warning events and some normal events are reported by default. The reported events can be used to configure alarms. |
Configuration Method |
Create a collection policy on LTS. For details, see Ingesting CCE Application Logs to LTS. |
Create a collection policy in the workload. For details, see Collecting Container Logs Using ICAgent (Not Recommended). |
Create a policy on the Logging page. For details, see Collecting Container Logs Using the Cloud Native Log Collection Add-on. |
For details, see Reporting Kubernetes Events to AOM. |
Monitored Directories |
Up to five levels of directories, with up to 1,000 files |
Up to three levels of directories by fuzzy match |
Monitored Files |
Up to 4,096 logs collected based on log policies on each node |
