Help Center/ Cloud Container Engine/ User Guide/ Networking/ Ingresses/ LoadBalancer Ingresses/ Creating a LoadBalancer Ingress on the Console
Updated on 2026-06-16 GMT+08:00
In Kubernetes, an ingress is a resource object that controls how Services within a cluster can be accessed from outside the cluster. You can use ingresses to configure different forwarding rules to access pods in a cluster. The following uses an Nginx workload as an example to describe how to create a LoadBalancer ingress on the console.
Notes and Constraints
  • Only clusters v1.17 or later support dedicated load balancers.
  • It is recommended that other resources not use the load balancer automatically created by an ingress. Otherwise, the load balancer will be occupied when the ingress is deleted, resulting in residual resources.
  • After an ingress is created, upgrade and maintain the configuration of the selected load balancers on the CCE console. Do not modify the configuration on the ELB console. Otherwise, the ingress service may be abnormal.
  • The URL registered in an ingress forwarding policy must be the same as the URL used to access the backend Service. Otherwise, a 404 error will be returned.
  • In an IPVS cluster, if the LoadBalancer ingress and Service share the same load balancer, the ingress cannot be accessed from within the cluster's nodes and containers. This is because kube-proxy binds the LoadBalancer Service address to the ipvs-0 bridge, which intercepts the ELB traffic. Use different load balancers for the LoadBalancer ingress and Service.
  • Do not connect an ingress and a Service that uses HTTP to the same listener of the same load balancer. Otherwise, a port conflict occurs.
  • Dedicated load balancers must be of the application type (HTTP/HTTPS) and support private networks (private IP addresses).
  • If multiple ingresses access the same ELB port in a cluster, the listener configuration items (such as the certificate associated with the listener and the HTTP/2 attribute of the listener) are subject to the configuration of the first ingress.
Adding a LoadBalancer Ingress
This section uses an Nginx workload as an example to describe how to add a LoadBalancer ingress.
  2. Choose Services and Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
  3. Configure ingress parameters.
    • Name: Enter a name for the ingress, for example, ingress-demo.
    • Namespace: namespace that the LoadBalancer ingress belongs to.
    • Interconnect with Nginx: This option is displayed only after the NGINX Ingress Controller add-on is installed. If this option is available, the NGINX Ingress Controller add-on has been installed. Enabling this option will create an Nginx ingress. Disable it if you want to create a LoadBalancer ingress. For details, see Creating an Nginx Ingress on the Console.
    • Protocol Version: Select a protocol version of the LoadBalancer ingress. This parameter is only available for IPv4/IPv6 dual-stack clusters.
    • Load Balancer: Select a load balancer type and creation mode.
      A load balancer can be dedicated or shared. A dedicated load balancer must be of the application type (HTTP/HTTPS) and support private networks.
      You can select Use existing or Auto create to obtain a load balancer. For details about the configuration of different creation modes, see Table 1.
      Table 1 Load balancer settings
      How to Create
      Configuration
      Use existing
      Only the load balancers in the same VPC as the cluster can be selected. If no load balancer is available, click Create Load Balancer to create one on the ELB console.
      Auto create
      • Instance Name: Enter a load balancer name.
      • Enterprise Project (only for dedicated load balancers): This parameter is available only for enterprise users who have enabled an enterprise project. Enterprise projects facilitate project-level management and grouping of cloud resources and users.
      • AZ: available only to dedicated load balancers. You can create load balancers in multiple AZs to improve service availability. If disaster recovery is required, you are advised to select multiple AZs.
      • Frontend Subnet: available only to dedicated load balancers. It is used to allocate IP addresses for load balancers to provide services externally.
      • Backend Subnet: available only to dedicated load balancers. It is used to allocate IP addresses for load balancers to access the backend service.
      • Network Specifications, Application-oriented Specifications, or Specifications (available only to dedicated load balancers)
        • Fixed: applies to stable traffic, billed based on specifications.
      • EIP: If you select Auto assign, you can configure the billing mode and bandwidth for the public network.
      • Resource Tag: You can add resource tags to classify resources. You can create predefined tags on the TMS console. These tags are available to all resources that support tags. You can use these tags to improve the tag creation and resource migration efficiency.
    • Listener: An ingress configures a listener for the load balancer, which listens to requests from the load balancer and distributes traffic. After the configuration is complete, a listener is created on the load balancer. The default listener name is k8s_<Protocol type>_<Port number>, for example, k8s_HTTP_80.
      • Frontend Protocol: Set the protocol of the load balancer listener for establishing connections with clients.
      • External Port: port number that is open to the ELB service address. The port number is configurable. If you select an existing load balancer, the listener ports of different clusters cannot be reused. Multiple ingresses within the same cluster can share the same listener port, but the listener configuration that works is determined by the earliest ingress configuration. For details, see Configuring Multiple Ingresses to Use the Same Load Balancer.
      • Access Control
        • Inherit ELB Configurations: CCE does not modify the existing access control configurations on the ELB console.
        • Allow all IP addresses: No access control is configured.
        • Trustlist: Only the selected IP address group can access the load balancer.
        • Blocklist: The selected IP address group cannot access the load balancer.
        For clusters v1.25.16-r10, v1.27.16-r10, v1.28.15-r0, v1.29.10-r0, v1.30.6-r0, v1.31.1-r0, or later, when using a dedicated load balancer, you can select a maximum of five IP address groups at a time for access control.
      • Certificate Source: TLS secret and ELB server certificates are supported.
        • TLS secret: For details about how to create a secret certificate, see Creating a Secret.
        • ELB server certificate: Use a certificate created on ELB.
      • SSL Authentication: This parameter is available only when Certificate Source is set to ELB server certificate. Clusters v1.28.15-r60, v1.29.15-r20, v1.30.14-r20, v1.31.10-r20, v1.32.6-r20, v1.33.5-r10, or later support this configuration.
        • One-way authentication: Only the backend server is authenticated. If you also need to authenticate the identity of the client, select two-way authentication.
        • Two-way authentication: Both the clients and the load balancer authenticate each other. This ensures only authenticated clients can access the load balancer. No additional backend server configuration is required if you select this option.
      • CA Certificate: If SSL Authentication is set to Two-way authentication, add a CA certificate to authenticate the client. A CA certificate is issued by a Certificate Authority (CA) and is used to verify the issuer of the client's certificate. If HTTPS two-way authentication is enabled, HTTPS connections can be established only if the client provides a certificate issued by a specific CA.
      • Server Certificate: When an HTTPS listener is created for a load balancer, bind a certificate to the load balancer to support encrypted authentication for HTTPS data transmission.
        If there is already an HTTPS ingress for the chosen port on the load balancer, the certificate of the new HTTPS ingress must be the same as the certificate of the existing ingress. This means that a listener has only one certificate. If two certificates, each with a different ingress, are added to the same listener of the same load balancer, only the certificate added earliest takes effect on the load balancer.
      • SNI: stands for Server Name Indication (SNI), which is an extended protocol of TLS. SNI enables several TLS domain names to share one IP:port pair while using different security certificates for each domain name. With SNI enabled, the client can send the requested domain name during the TLS handshake. The load balancer uses the domain name from the TLS request to find the matching certificate. If found, it returns that certificate. Otherwise, it returns the default server certificate.
        • The SNI option is available only when HTTPS is used.
        • This function is supported only in clusters v1.15.11 or later.
        • Only one domain name can be specified for each SNI certificate. Wildcard-domain certificates are supported.
        • For ingresses connected to the same ELB port, do not configure SNIs with the same domain name but different certificates. Otherwise, the SNIs will be overwritten.
      • Security Policy: combinations of different TLS versions and supported cipher suites available to HTTPS listeners. The default value is TLS-1-2.
        For details about security policies, see Security Policy.
        • Security Policy is available only when HTTPS is selected.
        • This function is supported only in clusters v1.17.9 or later.
      • Backend Protocol:
        When the listener is HTTP-compliant, only HTTP can be selected.
        If it is an HTTPS listener, this parameter can be set to HTTP, gRPC, or HTTPS. Only dedicated load balancers support gRPC. After HTTP/2 is enabled, CCE will automatically add the kubernetes.io/elb.http2-enable:true annotation. gRPC is available only in certain regions. For details, see the CCE console.
        When the listener uses QUIC, you can select HTTP or HTTPS.
      • Advanced Options
        Configuration
        Constraint
        Transfer Listener Port Number
        If this function is enabled, the listening port on the load balancer can be transferred to backend servers through the HTTP header of the packet.
        This function is available only for dedicated load balancers.
        Transfer Port Number in the Request
        If this function is enabled, the source port of the client can be transferred to backend servers through the HTTP header of the packet.
        Rewrite X-Forwarded-Host
        If this function is enabled, X-Forwarded-Host will be rewritten using the Host field in the client request header and transferred to backend servers.
        Rewrite X-Real-IP
        If this function is enabled, the source IP address of the client will be rewritten into the X-Real-IP header and transferred to backend servers.
        Data Compression
        If this function is enabled, specific files will be compressed. If it is not enabled, files will not be compressed.
        • Brotli can compress all file formats.
        • GZIP can compress the files of the following types:
          text/xml, text/plain, text/css, application/javascript, application/x-javascript, application/rss+xml, application/atom+xml, application/xml, and application/json
        Idle Timeout (s)
        The duration for which a client connection can remain idle before being terminated. If there are no requests reaching the load balancer during this period, the load balancer will disconnect the connection from the client and establish a new connection when there is a new request.
        This configuration is not supported when UDP is used on a shared load balancer.
        Request Timeout (s)
        The duration within which a request from a client must be received. There are two cases:
        • If the client fails to send a request header to the load balancer during this period, the request will be interrupted.
        • If the interval between two consecutive request bodies reaching the load balancer exceeds this period, the connection will be disconnected.
        This function is available only for HTTP and HTTPS listeners.
        Response Timeout (s)
        Timeout for backend server response. If the backend server does not respond within this period after receiving a request, the load balancer will stop waiting and return an HTTP 504 error.
        Enable HTTP/2
        Whether to enable HTTP/2 for HTTPS requests between the client and the load balancer. Request forwarding using HTTP/2 improves access performance between your application and the load balancer. However, the load balancer still uses HTTP/1.x to forward requests to the backend server.
        This function is available only when the listener is HTTPS-compliant.
      • Redirect to HTTPS: When HTTP is selected for Frontend Protocol, traffic can be redirected to HTTPS. After this function is enabled, you can click Modify to configure the HTTPS port. For details, see the HTTPS-compliant listener configuration.
    • Gray release: After an ingress is created, you can create a grayscale release policy in the Operation column of the ingress. For details, see Configuring Grayscale Release for a LoadBalancer Ingress.
    • Forwarding Policy: When a request's access address matches the forwarding policy (which consists of a domain name, port, and URL, for example, 10.117.117.117:80/helloworld), the request is forwarded to the target Service for processing. You can click to add multiple forwarding policies.
      • Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through an IP address. The domain name must be registered and filed. Once used by a forwarding policy, only that domain name will be accepted for access.
      • Path Matching Rule:
        • Prefix match: If the URL is set to /healthz, the URL that meets the prefix can be accessed, for example, /healthz/v1 and /healthz/v2.
        • Exact match: The URL can be accessed only when it is fully matched. For example, if the URL is set to /healthz, only /healthz can be accessed.
        • RegEx match: The URL is matched based on the regular expression. For example, if the regular expression is /[A-Za-z0-9_.-]+/test, all URLs that comply with this rule can be accessed, for example, /abcA9/test and /v1-Ab/test. Two regular expression standards are supported: POSIX and Perl.
      • Path: access path, for example, /healthz
        The access path added here must exist in the backend application. Otherwise, the forwarding fails.
        For example, the default access URL of the Nginx application is /usr/share/nginx/html. When adding /test to the ingress forwarding policy, ensure the access URL of your Nginx application contains /usr/share/nginx/html/test. Otherwise, error 404 will be returned.
      • Destination Service: Select an existing Service. Only Services that meet the requirements are automatically displayed in the Service list. If no Service meets the requirements, create one by following the operations provided in Services Supported by Ingresses.
      • Destination Service Port: Select the access port of the destination Service. The destination Service port must use TCP.
      • Set ELB:
        • Algorithm: You can select Weighted round robin, Weighted least connections, or Source IP hash.
          • Weighted round robin: Requests are forwarded to different servers based on their weights, which indicate server processing performance. Backend servers with higher weights receive proportionately more requests, whereas equal-weighted servers receive the same number of requests. This algorithm is often used for short connections, such as HTTP services.
          • Weighted least connections: In addition to the weight assigned to each server, the number of connections processed by each backend server is considered. Requests are forwarded to the server with the lowest connections-to-weight ratio. This algorithm is based on the least connections algorithm and assigns a weight to each server based on their processing capability. This algorithm is often used for persistent connections, such as database connections.
          • Source IP hash: The source IP address of each request is calculated using the hash algorithm to obtain a unique hash key, and all backend servers are numbered. The generated key allocates the client to a particular server. This enables requests from different clients to be distributed in load balancing mode and ensures that requests from the same client are forwarded to the same server. This algorithm applies to TCP connections without cookies.
        • Sticky Session: This function is disabled by default. Options are as follows:
          • Load balancer cookie: Enter the Stickiness Duration, which ranges from 1 to 1440 minutes.
          • Application cookie: Enter Cookie Name of 1 to 1024 characters.
          • When the distribution policy uses the source IP hash, the sticky session cannot be set.
          • Dedicated load balancers in the clusters earlier than v1.21 do not support sticky sessions. If sticky sessions are required, use shared load balancers.
        • Health Check: Set the health check configuration of the load balancer. If this function is enabled, the following configurations are supported:
          Protocol
          HTTPS, HTTP, gRPC, and TCP are supported. Only dedicated load balancers support HTTPS and gRPC. To use HTTPS, you must use a dedicated load balancer, and the cluster version must be v1.28.15-r90, v1.29.15-r50, v1.30.14-r50, v1.31.14-r10, v1.32.9-r10, v1.33.7-r10, v1.34.3-r0, or later. gRPC requires ELB capability. Before using this feature, submit a service ticket to enable ELB.
          • Check Path: This parameter is only available for HTTPS, HTTP, and gRPC health checks. It specifies the health check URL. The check path must start with a slash (/) and contain 1 to 80 characters.
          Port
          By default, the service port (NodePort or container port of the Service) is used for health check. You can also specify another port for health check. After the port is specified, a service port named cce-healthz will be added for the Service.
          • Node Port: If a shared load balancer is used or no ENI instance is associated, the node port is used as the health check port. If this parameter is not specified, a random port is used. The value ranges from 30000 to 32767.
          • Container Port: When a dedicated load balancer is associated with a network interface, the container port is used for health check. The value ranges from 1 to 65535.
          Check Period (s)
          The maximum interval between health checks. The value ranges from 1 to 50.
          Timeout (s)
          The maximum wait time for each health check response. The value ranges from 1 to 50.
          Max. Retries
          The maximum retry attempts before marking a backend as unhealthy. The value ranges from 1 to 10.
      • Operation: Click Delete to delete the configuration.
      • Actions: Redirect to URL and Rewrite URL are available only for dedicated load balancers.
        • Redirect to URL: When an access request meets the forwarding policy, the request will be redirected to a specified URL, and a specific status code will be returned.
        • Rewrite URL: When an access request meets the forwarding policy, the URL will be rewritten based on the matching rule. You are allowed to configure a regular expression for the patch matching rule, and the result obtained using the regular expression can be used for rewriting the URL. For example, the regular expression configured in the forwarding rule is /first/(.*)/(.*)/end, and the rewrite URL is set to /${1}/${2}. When the client URL for sending requests is /first/aaa/bbb/end, the forwarding rule matches /first/(.*)/(.*)/end. Then, ${1} in the rewrite URL will be replaced with aaa and ${2} replaced with bbb, the request path received by the backend server will be /aaa/bbb.
    • Annotation: Ingresses provide some advanced CCE functions, which are implemented by annotations. When you use kubectl to create a container, annotations will be used. For details, see Automatically Creating a Load Balancer While Creating an Ingress or Associating an Existing Load Balancer to an Ingress While Creating the Ingress.
  4. Click OK. After the ingress is created, it is displayed in the ingress list.
    On the ELB console, you can check the load balancer automatically created through CCE. The default name is cce-lb-<ingress.UID>. Click the load balancer name to go to the details page. On the Listeners tab page, check the listener and forwarding policy of the target ingress.
    After an ingress is created, upgrade and maintain the selected load balancer on the CCE console. Do not modify the configuration on the ELB console. Otherwise, the ingress service may be abnormal.
    Figure 1 LoadBalancer ingress configuration
  5. Access the /healthz interface of the workload, for example, workload defaultbackend.
    1. Obtain the access address of the /healthz interface of the workload. The access address consists of the load balancer IP address, external port, and mapping URL, for example, 10.**.**.**:80/healthz.
    2. Enter the URL of the /healthz interface, for example, http://10.**.**.**:80/healthz, in the address box of the browser to access the workload, as shown in Figure 2.
      Figure 2 Accessing the /healthz interface of defaultbackend
Helpful Links
