Creating an HPA Policy
As application access requests fluctuate, the preset number of pods often fails to meet the requirements for efficient, elastic resource utilization. For example, if the number of pods is insufficient during peak hours, the response delay may increase and user experience may deteriorate. If the number of pods is excessive during off-peak hours, resources go wasted.
Kubernetes provides the HPA policy to horizontally scale pods. The HPA policy monitors application loads, such as the CPU usage and memory usage, and automatically increases or decreases the number of pods to adapt to the current workload. This ensures stable application performance and efficient resource utilization.
- Kubernetes Metrics Server: provides basic resource usage metrics, such as container CPU and memory usage. The default collection period is 60s. It is supported by all cluster versions.
- Cloud Native Cluster Monitoring: To use HPA policies, enable local data storage in this add-on. This add-on is available in clusters v1.17 or later. The default collection period is 15s.
- Auto scaling based on basic resource metrics: Prometheus needs to be registered as a metrics API. For details, see Providing Basic Resource Metrics Through the Metrics API. If Kubernetes Metrics Server has been installed in the cluster, the Metrics API is provided by default. No manual registration is required.
- Auto scaling based on custom metrics: In addition to registering Prometheus as a Metrics API service, you need to aggregate custom metrics to the Kubernetes API server. For details, see Creating an HPA Policy Using Custom Metrics.
- Prometheus (EOM): If Kubernetes Metrics Server is not installed in the cluster, you need to manually create the Metrics API for Prometheus. For details, see Providing Resource Metrics Through the Metrics API. This add-on supports only clusters v1.21 or earlier. This add-on is no longer maintained in clusters v1.21 or later. This add-on is not recommended for CCE clusters. You are advised to use Cloud Native Cluster Monitoring or Kubernetes Metrics Server instead.
- HPA policies can be created only for clusters v1.13 or later.
- For clusters earlier than v1.19.10, if an HPA policy is used to scale out a workload with EVS volumes mounted, the existing pods cannot be read from or written to when a new pod is scheduled to another node.
For clusters v1.19.10 and later, if an HPA policy is used to scale out a workload with EVS volumes mounted, a new pod cannot be started because EVS disks cannot be attached.
- Choose Workloads in the navigation pane. Locate the target workload and choose More > Auto Scaling in the Operation column. Figure 1 Scaling a workload
- Set Policy Type to HPA+CronHPA, enable the created HPA policy, and configure parameters.
This section describes only HPA policies. To enable CronHPA, see Creating a Scheduled CronHPA Policy.
Figure 2 Enabling the HPA policy
Table 1 HPA policy Parameter
Pod Range
Minimum and maximum numbers of pods.
When a policy is triggered, the workload pods are scaled within this range.
NOTICE:In CCE Turbo clusters, if you use a dedicated load balancer for your workload, the number of pods cannot exceed the backend server group quota of the load balancer, which is 500 by default. If you exceed this limit, you will not be able to add any more pods to the load balancer backend.
Cooldown Period
Interval between a scale-in and a scale-out. The unit is minute. The interval cannot be shorter than 1 minute.
This parameter is supported only in clusters v1.15 to v1.23.
This parameter indicates the interval between consecutive scaling operations. The cooldown period ensures that a scaling operation is initiated only when the previous one is completed and the system is running stably.
Scaling Behavior
This parameter is supported only in clusters v1.25 or later.
- Default: scales workloads using the Kubernetes default behavior. For details, see Default Behavior.
- Custom: scales workloads using custom policies such as stabilization window, steps, and priorities. Unspecified parameters use the values recommended by Kubernetes.
- Disable scale-out/scale-in: Select whether to disable scale-out or scale-in.
- Stabilization Window: a period during which CCE continuously checks whether the metrics used for scaling keep fluctuating. CCE triggers scaling if the desired state is not maintained for the entire window. This window restricts the unwanted flapping of pod count due to metric changes.
- Step: specifies the scaling step. You can set the number or percentage of pods to be scaled in or out within a specified period. If there are multiple policies, you can select the policy that maximizes or minimizes the number of pods.
System Policy
When calculating the number of pods to add or remove, HPA determines the target number of pods based on the current metric value, desired value, and the current number of pods. The current number of pods is the maximum number of pods over the last 5 minutes. The formula is as follows:
Desired number of pods = Rounded up value of [Current number of pods × (Current metric value/Desired value)]
- Metric: You can select CPU usage or Memory usage.
Usage = Average resource usage of all pods in a workload/Requested resources
- Desired Value: Enter the desired average resource usage.
- Tolerance Range: Scaling is not triggered when the metric value is within the tolerance range. The desired value must be within the tolerance range.
If the metric value is greater than the scale-in threshold and less than the scale-out threshold, no scaling is triggered. This parameter is supported only in clusters v1.15 or later.
Custom Policy (supported only in clusters v1.15 or later)
NOTE:Before creating a custom policy, install an add-on that supports custom metric collection (for example, Prometheus) in the cluster. Ensure that the add-on can collect and report the custom metrics of the workloads.
For details, see Monitoring Custom Metrics Using Cloud Native Cluster Monitoring.
- Metric Name: name of the custom metric. You can select a name based on suggested values.
- Metric Source: Select an object type from the drop-down list. You can select Pod.
- Desired Value: the average metric value of all pods. Number of pods to be scaled (rounded up) = (Current metric value/Desired value) × Number of current pods NOTE:
When calculating the number of pods to be added or reduced, the HPA policy uses the maximum number of pods in the last 5 minutes.
- Click Create.
