On this page
Show all
Overview
Updated on 2024-09-29 GMT+08:00
Table 1 lists the string functions supported by DLI.
Table 1 String functions
Function
Syntax
Value Type
ascii
ascii(string <str>)
BIGINT
Returns the numeric value of the first character in a string.
concat
concat(array<T> <a>, array<T> <b>[,...]), concat(string <str1>, string <str2>[,...])
ARRAY or STRING
Returns a string concatenated from multiple input strings. This function can take any number of input strings.
concat_ws
concat_ws(string <separator>, string <str1>, string <str2>[,...]), concat_ws(string <separator>, array<string> <a>)
ARRAY or STRUCT
Returns a string concatenated from multiple input strings that are separated by specified separators.
char_matchcount
char_matchcount(string <str1>, string <str2>)
BIGINT
Returns the number of characters in str1 that appear in str2.
encode
encode(string <str>, string <charset>)
BINARY
Returns strs encoded in charset format.
find_in_set
find_in_set(string <str1>, string <str2>)
BIGINT
Returns the position (stating from 1) of str1 in str2 separated by commas (,).
get_json_object
get_json_object(string <json>, string <path>)
STRING
Parses the JSON object in a specified JSON path. The function will return NULL if the JSON object is invalid.
instr
instr(string <str>, string <substr>)
INT
Returns the index of substr that appears earliest in str. It returns NULL if either of the arguments are NULL and returns 0 if substr does not exist in str. Note that the first character in str has index 1.
instr1
instr1(string <str1>, string <str2>[, bigint <start_position>[, bigint <nth_appearance>]])
BIGINT
Returns the position of str2 in str1.
initcap
initcap(string A)
STRING
Converts the first letter of each word of a string to upper case and all other letters to lower case.
keyvalue
keyvalue(string <str>,[string <split1>,string <split2>,] string <key>)
STRING
Splits str by split1, converts each group into a key-value pair by split2, and returns the value corresponding to the key.
length
length(string <str>)
BIGINT
Returns the length of a string.
lengthb
lengthb(string <str>)
STRING
Returns the length of a specified string in bytes.
levenshtein
levenshtein(string A, string B)
INT
Returns the Levenshtein distance between two strings, for example, levenshtein('kitten','sitting') = 3.
locate
locate(string <substr>, string <str>[, bigint <start_pos>])
BIGINT
Returns the position of substr in str.
lower/lcase
lower(string A) , lcase(string A)
STRING
Converts all characters of a string to the lower case.
lpad
lpad(string <str1>, int <length>, string <str2>)
STRING
Returns a string of a specified length. If the length of the given string (str1) is shorter than the specified length (length), the given string is left-padded with str2 to the specified length.
ltrim
ltrim([<trimChars>,] string <str>)
STRING
Trims spaces from the left hand side of a string.
parse_url
parse_url(string urlString, string partToExtract [, string keyToExtract])
STRING
Returns the specified part of a given URL. Valid values of partToExtract include HOST, PATH, QUERY, REF, PROTOCOL, AUTHORITY, FILE, and USERINFO.
For example, parse_url('http://facebook.com/path1/p.php?k1=v1&k2=v2#Ref1', 'HOST') returns 'facebook.com'.
When the second parameter is set to QUERY, the third parameter can be used to extract the value of a specific parameter. For example, parse_url('http://facebook.com/path1/p.php?k1=v1&k2=v2#Ref1', 'QUERY', 'k1') returns 'v1'.
printf
printf(String format, Obj... args)
STRING
Prints the input in a specific format.
regexp_count
regexp_count(string <source>, string <pattern>[, bigint <start_position>])
BIGINT
Returns the number of substrings that match a specified pattern in the source, starting from the start_position position.
regexp_extract
regexp_extract(string <source>, string <pattern>[, bigint <groupid>])
STRING
Matches the string source based on the pattern grouping rule and returns the string content that matches groupid.
replace
replace(string <str>, string <old>, string <new>)
STRING
Replaces the substring that matches a specified string in a string with another string.
regexp_replace
  • For Spark 2.4.5: regexp_replace(string <source>, string <pattern>, string <replace_string>)
  • For Spark 3.3.1: regexp_replace(string <source>, string <pattern>, string <replace_string>[, bigint <occurrence>])
STRING
  • For Spark 2.4.5: Replaces the substring that matches the pattern for the occurrence time in the source string and the substring that matches the pattern later with the specified string replace_string and returns the result string.
  • For Spark 3.3.1: Replaces the substring that matches the pattern for the occurrence time in the source string and the substring that matches the pattern later with the specified string replace_string and returns the result string.
regexp_replace1
regexp_replace1(string <source>, string <pattern>, string <replace_string>[, bigint <occurrence>])
STRING
Replaces the substring that matches pattern for the occurrence time in the source string with the specified string replace_string and returns the result string.
regexp_instr
regexp_instr(string <source>, string <pattern>[,bigint <start_position>[, bigint <occurrence>[, bigint <return_option>]]])
BIGINT
Returns the start or end position of the substring that matches a specified pattern for the occurrence time, starting from start_position in the source string.
regexp_substr
regexp_substr(string <source>, string <pattern>[, bigint <start_position>[, bigint <occurrence>]])
STRING
Returns the substring that matches a specified pattern for the occurrence time, starting from start_position in the source string.
repeat
repeat(string <str>, bigint <n>)
STRING
Repeats a string for N times.
reverse
reverse(string <str>)
STRING
Returns a string in reverse order.
rpad
rpad(string <str1>, int <length>, string <str2>)
STRING
Right-pads str1 with str2 to the specified length.
rtrim
rtrim([<trimChars>, ]string <str>),
rtrim(trailing [<trimChars>] from <str>)
STRING
Trims spaces from the right hand side of a string.
soundex
soundex(string <str>)
STRING
Returns the soundex string from str, for example, soundex('Miller') = M460.
space
space(bigint <n>)
STRING
Returns a specified number of spaces.
substr/substring
substr(string <str>, bigint <start_position>[, bigint <length>]), substring(string <str>, bigint <start_position>[, bigint <length>])
STRING
Returns the substring of str, starting from start_position and with a length of length.
substring_index
substring_index(string <str>, string <separator>, int <count>)
STRING
Truncates the string before the count separator of str. If the value of count is positive, the string is truncated from the left. If the value of count is negative, the string is truncated from the right.
split_part
split_part(string <str>, string <separator>, bigint <start>[, bigint <end>])
STRING
Splits a specified string based on a specified separator and returns a substring from the start to end position.
translate
translate(string|char|varchar input, string|char|varchar from, string|char|varchar to)
STRING
Translates the input string by replacing the characters or string specified by from with the characters or string specified by to. For example, replaces bcd in abcde with BCD using translate("abcde", "bcd", "BCD").
trim
trim([<trimChars>,]string <str>),
trim([BOTH] [<trimChars>] from <str>)
STRING
Trims spaces from both ends of a string.
upper/ucase
upper(string A), ucase(string A)
STRING
Converts all characters of a string to the upper case.
