Help Center/ Data Lake Insight/ Spark SQL Syntax Reference/ Built-In Functions/ String Functions/ space
Updated on 2023-10-25 GMT+08:00
space
This function is used to return a specified number of spaces.
Syntax
space(bigint <n>)
Parameters
| Parameter | Mandatory | Type | Description |
| n | Yes | BIGINT | Number of spaces |
Return Values
The return value is of the STRING type.
- If the value of n is empty, an error is reported.
- If the value of n is NULL, NULL is returned.
Example Code
The value 6 is returned.
select length(space(6));
Parent topic: String Functions
