soundex
This function is used to return the soundex string from str, for example, soundex('Miller') = M460.
Syntax
soundex(string <str>)
Parameters
| Parameter | Mandatory | Type | Description |
| str | Yes | STRING | String to be converted |
Return Values
The return value is of the STRING type.
If the value of str is NULL, NULL is returned.
Example Code
The value M460 is returned.
SELECT soundex('Miller'); Feedback
