levenshtein
This function is used to returns the Levenshtein distance between two strings, for example, levenshtein('kitten','sitting') = 3.
![](https://support.huaweicloud.com/intl/en-us/sqlref-spark-dli/public_sys-resources/note_3.0-en-us.png)
Levenshtein distance is a type of edit distance. It indicates the minimum number of edit operations required to convert one string into another.
Syntax
levenshtein(string A, string B)
Parameters
Parameter |
Mandatory |
Type |
Description |
A, B |
Yes |
STRING |
String to be entered for calculating the Levenshtein distance |
Return Values
The return value is of the INT type.
Example Code
The value 3 is returned.
SELECT levenshtein('kitten','sitting');
