ascii
This function is used to return the ASCII code of the first character in str.
Syntax
ascii(string <str>)
Parameters
Parameter |
Mandatory |
Type |
Description |
str |
Yes |
STRING |
If the value is of the BIGINT, DOUBLE, DECIMAL, or DATETIME type, the value is automatically converted to the STRING type for calculation. Example: ABC |
Return Values
The return value is of the BIGINT type.
- If the value of str is not of the STRING, BIGINT, DOUBLE, DECIMAL, or DATETIME type, an error is reported.
- If the value of str is NULL, NULL is returned.
