regexp_extract
This function is used to match the string source based on the pattern grouping rule and return the string content that matches groupid.
Syntax
regexp_extract(string <source>, string <pattern>[, bigint <groupid>])
Parameters
Parameter |
Mandatory |
Type |
Description |
source |
Yes |
STRING |
String to be split |
pattern |
Yes |
STRING |
Constant or regular expression of the STRING type. Pattern to be matched. |
groupid |
No |
BIGINT |
Constant of the BIGINT type. The value must be greater than or equal to 0. |
Return Values
The return value is of the STRING type.
- If the value of pattern is an empty string or there is no group in pattern, an error is reported.
- If the value of groupid is not of the BIGINT type or is less than 0, an error is reported.
- If this parameter is not specified, the default value 1 is used, indicating that the first group is returned.
- If the value of groupid is 0, the substring that meets the entire pattern is returned.
- If the value of source, pattern, or groupid is NULL, NULL is returned.
Example Code
Splits basketball by bas(.*?)(ball). The value ket is returned.
select regexp_extract('basketball', 'bas(.*?)(ball)');
The value basketball is returned.
select regexp_extract('basketball', 'bas(.*?)(ball)',0);
The value 99 is returned. When submitting SQL statements for regular expression calculation on DLI, two backslashes (\) are used as escape characters.
select regexp_extract('8d99d8', '8d(\\d+)d8');
The value [Hello] is returned.
select regexp_extract('[Hello] hello', '([^\\x{00}-\\x{ff}]+)');
The value Hello is returned.
select regexp_extract('[Hello] hello', '([\\x{4e00}-\\x{9fa5}]+)');
