Constraints and Limitations
By June 2025, COC supports the following Huawei Cloud regions:
COC is universally applicable. However, it is not supported in some special regions and scenarios (such as dedicated regions). If you have any requirements, contact COC service personnel.
| Region |
| ME-Riyadh |
| CN-Hong Kong |
| AP-Singapore |
| AP-Bangkok |
| AP-Jakarta |
| CN East-Shanghai1 |
| CN East-Shanghai2 |
| CN East2 |
| CN North-Ulanqab1 |
| CN East-Qingdao |
| CN North-Beijing1 |
| CN North-Beijing4 |
| CN South-Guangzhou |
| CN South-Shenzhen |
| TR-Istanbul |
| LA-Sao Paulo1 |
| LA-Santiago |
| LA-Mexico City |
| LA-Mexico City2 |
| CN Southwest-Guiyang1 |
| AF-Cairo |
| AF-Johannesburg |
When using COC, pay attention to the restrictions listed in Table 2.
| Functional Module | Object | Restriction |
| Public | Managing patches, scripts, jobs, or ECSs | A maximum of 200 instances can be selected for a single operation task. |
| Managing patches, scripts, jobs, or ECSs | The timeout interval for executing a service ticket must be less than or equal to 86,400 seconds (24 hours). | |
| Resource management | Installing OSs supported by UniAgent | Currently, the following Linux OS versions are supported:
| UniAgent client | If the CPU usage is greater than 10% or the memory is greater than 200 MB, the UniAgent client automatically restarts. | |
| Installing a UniAgent | A maximum of 100 UniAgent hosts can be installed at a time. | |
| Application management | Applications | An application must be within 5 layers. |
| Patch management | Patch baselines | A tenant can create a maximum of 50 (public baselines excluded) patch baselines. |
| Script management | Script content | The content of a custom script cannot exceed 100 KB. |
| Job management | Global parameters | The number of global parameters of a user-defined job cannot exceed 30. |
| War rooms | War room initiation rules | A maximum of 50 war room initiation rules can be created by a tenant. |
| Alarm conversion rules | Alarm conversion rules | A tenant can create a maximum of 50 alarm conversion rules. |
| Data source management | Data records | COC retains only the latest 10 records of integrated data sources. |
| Personnel management | Number of engineers | The number of personnel created by a tenant cannot exceed 50. |
| Shift schedule management | Roles | A maximum of 10 roles are allowed in a single shift scheduling scenario. |
| Account management | Resource types | Currently, the following types of resources can be managed: ECSs, RDS instances, and GaussDB instances. Currently, account hosting (account import) is supported for the following types of resources:
| Account baselines | The number of baseline accounts is less than or equal to 30, and the number of components associated with the accounts is less than or equal to 100. |
Currently, COC supports IAM login, IAM federated user login (including IAM user SSO and virtual user SSO), and login via IAM Identity Center. Login via IAM agencies is not supported. You can select one from these supported login methods to use COC features, such as ticket creation and review. For details about each login method, see Managing O&M Engineers.
