- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Help Center/
Cloud Operations Center/
User Guide/
Faults/
Issue Management/
Handling an Issue Ticket/
Suspending an Issue Ticket
After an issue ticket is accepted, the ticket creator needs to provide data or other information in the fault locating phase, and approve the requests during issue implementation phase. After the issue handler suspends the ticket, the creator needs to approve the suspension.
- Log in to COC.
- In the navigation pane on the left, choose Fault Management > Issues. On the displayed page, click Pending.
- Click the issue name to go to the issue details page. Click Suspend in the upper right corner.
Figure 1 Issue ticket suspension
- After the ticket is submitted for suspension, the creator clicks the ticket name to go to the issue details page, clicks Suspend Review in the upper right corner of the page, enters review information, and submits the review result. Then the issue handling duration stops counting to prevent suspension recovery.
Parent topic: Handling an Issue Ticket
