- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Help Center/
Cloud Operations Center/
User Guide/
Faults/
Issue Management/
Handling an Issue Ticket/
Verifying the Issue Handling Result
After the issue ticket is processed, the creator checks whether the issue is solved.
- Log in to COC.
- In the navigation pane on the left, choose Fault Management > Issues. On the displayed page, click Pending.
- Click the issue ticket name to go to the issue details page. Click Validate in the upper right corner to go to the verification details page. Enter information and click OK.
Figure 1 Issue ticket verification page
- After the verification is passed, the issue ticket is closed. If the verification fails, the issue ticket status becomes Locate the solution.
Parent topic: Handling an Issue Ticket
