- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Creating an Incident
Create an incident ticket using Cloud Operations Center.
You have created an application by referring to Application Management.
Precautions
Create an incident service ticket.
- Log in to COC.
- In the navigation pane, choose Fault Management > Incidents. On the displayed page, click Create.
Figure 1 Incident ticket list
- Enter the basic information about the incident ticket and click Submit.
If no shift is available for the owner, create a schedule in Overview.Figure 2 Creating an incident service ticket
The incident levels are defined as follows:
P1: Core service functions are unavailable, affecting all customers.
P2: Core service functions are affected, affecting the core services of some customers.
P3: An error is reported for non-core service functions, affecting some customer services.
P4: Non-core service functions are faulty. The service latency increases, the performance deteriorates, and user experience decrease.
P5: Non-core service exception occurs, which is customer consultation or request issue.
