- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Show all
Identity Authentication and Access Control
Identity authentication
You can access COC through the COC console, application programming interfaces (APIs), and software development kits (SDKs). No matter which method you choose, you actually use REST APIs to access COC.
COC APIs can authenticate requests. An authenticated request must contain a signature value. The signature value is calculated based on the access key (AK/SK) of the requester and the specific information carried in the request body. COC supports authentication using an Access Key ID (AK)/Secret Access Key (SK) pair. This means it can use AK/SK-based encryption to authenticate a request sender. For more information about access keys and how to obtain them, see Access Keys/Secret Keys.
Access control
You can use IAM to securely control access to your COC resources. For more information about IAM and COC permissions management, see Permissions Management.
