Auditing and Logging
Auditing
Cloud Trace Service (CTS) is a log audit service intended for Huawei Cloud security. It allows you to collect, store, and query cloud resource operation records. You can use these records to monitor resource changes, analyze security, audit compliance, and locate faults.
After you enable CTS and configure a tracker, CTS can record management and data traces of COC for auditing.
To learn how to enable CTS, see CTS Overview.
Logging
After you enable CTS and configure a tracker for COC, CTS can record operations performed on COC.
For more information, see Viewing Logs.
