Updated on 2026-10-28 GMT+08:00
Viewing Traces
COC Operations That Can Be Audited
With Cloud Trace Service (CTS), you can record operations associated with COC for later query, audit, and backtracking. Table 1 lists the key operations.
Table 1 Key operations recorded by CTS
Action
Resource
Trace
Creating a war room
War rooms
createWarRoom
Creating a war room initiation rule
MeetingRule
createMeetingRule
Deleting a war room initiation rule
MeetingRule
deleteMeetingRule
Modifying a war room initiation rule
MeetingRule
updateMeetingRule
Modifying war room information
War rooms
modifyWarRoomInfo
Sending notifications using war room
NotificationBriefing
sendNotificationBriefing
Adding a war room member
War rooms
addWarRoomMember
Removing a war room member
War rooms
deleteWarRoomMember
Creating affected applications involved in the war room
ImpactApplication
createImpactApplication
Modifying affected applications involved in the war room
ImpactApplication
updateImpactApplication
Deleting affected applications involved in the war room
ImpactApplication
deleteImpactApplication
Executing actions
Ticket
actionTicket
Creating a service ticket
Ticket
createTicket
Modifying a service ticket
Ticket
updateTicket
Deleting a service ticket
Ticket
deleteTicketInfo
Uploading an attachment
uploadFileTicket
Downloading files
downloadFileTicket
Updating the integration configuration key
IntegrationConfig
updateIntegrationConfigKey
Accessing integration
IntegrationConfig
accessIntegrationConfig
Disabling integration
IntegrationConfig
disableIntegrationConfig
Enabling integration
IntegrationConfig
enableIntegrationConfig
Canceling integration
IntegrationConfig
removeIntegrationConfig
Creating an alarm conversion rule
TransferRule
createTransferRules
Modifying an alarm conversion rule
TransferRule
updateTransferRules
Deleting an alarm conversion rule
TransferRule
deleteTransferRules
Disabling an alarm conversion rule
TransferRule
disableTransferRules
Enabling an alarm conversion rule
TransferRule
enableTransferRules
Unsubscription
NotificationRule
disableNotificationRule
Subscription
NotificationRule
enableNotificationRule
Creating a subscription task
NotificationRule
createNotificationRule
Deleting a subscription task
NotificationRule
deleteNotificationRule
Modifying subscription information
NotificationRule
updateNotificationRule
Creating a shift scenario
ScheduleScene
createSceneOncall
Deleting a shift scenario
ScheduleScene
deleteSceneOncall
Updating a shift scenario
ScheduleScene
updateSceneOncall
Creating a shift role
ScheduleRole
createRoleOncall
Updating a shift role
ScheduleRole
updateRoleOncall
Deleting a shift role
ScheduleRole
deleteRoleOncall
Deleting a fixed shift personnel
ScheduleUser
deleteGlobalFixed
Adding a user to the global fixed shift
ScheduleUser
createGlobalFixed
Updating fixed shift personnel
ScheduleUser
updatePersonnelsOncall
Clearing shifts with one click
ScheduleUser
batchDeleteShift
Creating shift agents in batches
ScheduleUser
batchCreateShift
Updating the shift schedule personnel of a specific day
ScheduleUser
UpdateUserShift
Creating shift scenarios and roles
ScheduleRole
createRoleOncall
Creating a custom script
Document
createJobScript
Deleting a custom script
Document
deleteJobScript
Modifying a custom script
Document
editJobScript
Approving a custom script
Document
approveJobScript
Executing a custom script
Document
executeJobScript
Operating a script service ticket
Job
jobScriptOrderOperation
Creating a custom job
Document
CreateRunbook
Deleting a custom job
Document
DeleteRunbook
Modifying a custom job
Document
EditRunbook
Approving a custom job
Document
ApproveRunbook
Executing a custom job
Job
ExecuteRunbook
Executing a public job
Job
ExecutePublicRunbook
Operating a job service ticket
Job
OperateJobTicket
Viewing Traces
  1. Log in to CTS.
  2. In the navigation pane, choose Trace List.
  3. Specify filter criteria as needed.
    Figure 1 CTS events
  4. Select the trace to be viewed and click the trace name to expand the overview.
    Figure 2 Trace overview
