El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
To-do Center
Overview
Main function of To-do Center: You can use a HUAWEI ID (primary SRE of the tenant) to create tasks for IAM users (sub-SREs of the tenant). For example, a company can create IAM accounts for different departments.
Adding a To-do Ticket
- Log in to COC.
- In the navigation pane on the left, choose Task Management > To-do Center.
Figure 1 Viewing the to-do list
- Click Create Ticket. The Create Ticket page is displayed.
- Specify the to-do ticket name, description, type, severity, and other mandatory parameter.
Figure 2 Creating a to-do ticket
Table 1 Parameters Parameter
Ticket
Mandatory.
- The ticket name can contain a maximum of 255 characters, including letters, digits, underscores (_), hyphens (-), and periods (.).
- Start with a letter or number.
- Cannot end with a period (.).
Mandatory.
The description can contain a maximum of 1,000 characters, including letters, numbers, and special characters.
Type
Mandatory.
To-do ticket type. The options are as follows:
- Scheduled Events
- Risk warning
- Other
Severity
Mandatory.
The severity of a to-do ticket. The options are as follows:
- Critical
- Major
- Minor
- Suggestion
Owner
Mandatory.
The owner of a to-do ticket can be:
- Shift
- Individual
Notification Mode
Mandatory.
Notification mode. The options are as follows:
- Default
- SMS
- Enterprise WeChat
- DingTalk
- Lark
- No notification
Ticket Deadline
Mandatory.
Time when a to-do ticket needs to be closed
Label
Optional.
Recommended Solution
Mandatory.
- Specify optional parameters such as Label and Add File.
- Click Submit. If a message indicating the creation succeeded displayed in the upper right corner, the creation is successful.
You can select Shift or Individual for Owner. The size of a file to be uploaded must be less than 50 MB. Various formats are supported.
To-do Ticket List
- Log in to COC.
Figure 3 Viewing the to-do center list
- Click the search box. The search criteria list is displayed. Select search criteria, enter values, and press Enter to search for data.
- You can click the refresh icon next to the search box to refresh the data and set the fields to be displayed in the list.
Figure 4 Adding search criteria
- Click the All To-do Tickets, Pending, Handled By Me, or Created By Me tabs. The corresponding to-do ticket list is displayed.
Figure 5 To-do ticket list
An user can only view the tickets related to itself on the All To-do Tickets tab page.
Viewing Pending Tickets
- Log in to COC.
- Click a to-do ticket name in the list to go to the ticket details page.
Figure 6 To-do ticket details
- On the details page, click the attachment name to download the attachment.
Figure 7 Downloading an attachment
The attachment download traffic is limited. After downloading an attachment, the next download can be performed after 5 seconds.
Handling To-do Tickets
- Log in to COC.
- In the navigation pane on the left, choose Task Management > To-do Center. Click the Pending tab.
- Click a to-do ticket name in the list to go to the to-do ticket details page. Click Accept in the upper right corner to complete the handling.
Figure 8 Handling a to-do ticket
The current login user can handle only the to-do tickets whose owner is himself/herself.
Canceling a To-Do Ticket
- Log in to COC.
- In the navigation pane on the left, choose Task Management > To-do Center. Click the Created by Me tab.
- Click Cancel in the upper right corner and enter the cancellation reason.
Figure 9 Canceling a to-do task
The current login user can cancel only the to-do tickets that are created by or owned by this user.
Closing a To-do Ticket
- Log in to COC.
- In the navigation pane on the left, choose Task Management > To-do Center. Click the Handled by Me tab.
- Click a to-do ticket name in the list. On the to-do ticket details page that is displayed, click Close in the upper right corner.
Figure 10 Closing a to-do ticket
The current login user can close only the to-do tickets whose owner is himself/herself.
