El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Help Center/
Cloud Operations Center/
User Guide/
Faults/
Issue Management/
Handling an Issue Ticket/
Upgrading/Downgrading an Issue Ticket
After an issue ticket is submitted, if the issue handler thinks that the current issue level is improper, the problem handler can upgrade or degrade the issue.
- Log in to COC.
- In the navigation pane on the left, choose Fault Management > Issues. On the displayed page, click Pending.
- Click the issue name to go to the issue details page. Click Upgrade and Downgrade in the upper right corner.
Figure 1 Upgrading and downgrading an issue
- Currently, the upgrade and downgrade do not need to be approved. After you complete the upgrade or degrade, the ticket level will be changed.
Parent topic: Handling an Issue Ticket
