- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Faults/
Issue Management/
Handling an Issue Ticket/
Issues to Be Implemented on the Live Network
To solve this issue, change implementation is required.
On the Positioning solution page, if you select Need for Whether the live network needs to be changed. The issue ticket enters the To be implemented on the live network status.
- Log in to COC.
- In the navigation pane on the left, choose Fault Management > Issues. On the displayed page, click Pending.
- Click the issue ticket name to go to the issue details page. Click Live network implementation in the upper right corner. The involved regions are displayed. Click Associate Change Order to associate the change tickets and obtain the change result. If some regions do not involve changes, click No change required in the Operation column.
- When you complete the change information, click Implementation completed. The issue enters the To be verified status.
Figure 1 Associating an issue with a change ticket
Parent topic: Handling an Issue Ticket
