El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Starting a War Room
Start a war room for critical incident to recovery the incident quickly.
- Log in to COC.
- In the navigation pane on the left, choose Incident Management > Incident Center. On the displayed page, click the Pending tab and click the incident title to go to the incident details page.
Figure 1 Incident ticket details
- Click Start WarRoom.
Figure 2 Starting a war room
- Enter war room information and click OK.
Figure 3 Entering war room information
CAUTION:
If a group (Only enterprise WeChat groups and DingTalk groups are supported) needs to be added when a war room is started, configure the following information:
(1) Configure applications in Mobile App Management.
(2) Configure the enterprise WeChat email address on O&M Engineer Management Overview.
(3) If shift is selected, you need to create a schedule and add personnel to the schedule. Then the enterprise WeChat accounts will be added when the war room starting rule is met.
