此内容的本地化语言页面暂未提供。我们将不断努力以提供本地化语言版本。感谢您的关注。
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Help Center/
Cloud Operations Center/
User Guide/
Change Management/
Change Center/
Reviewing a Change Ticket
Any created change ticket needs to be reviewed.
- Log in to COC.
- In the navigation pane on the left, choose Change Ticket Management > Change Center. On the displayed page, locate a pending ticket and click the ticket title or click Deal in the Operation column of a change record to view the change details and review the change.
Figure 1 Reviewing a change ticket
Parent topic: Change Center
