Pull from URLs (OBT)
Audio/Video files can be pulled from their URLs and uploaded to VOD.
- Log in to the VOD console.
- In the navigation pane, choose Audio and Video Uploads > Pull from URLs.
- Click Pull from URLs. The Pull from URLs page is displayed, as shown in Figure 1.
See Table 1.
Table 1 Parameters Parameter
Pull File
Constraints:
- A URL must contain the filename extension, for example, https://xxxx.mp4.
- Files can be pulled from a maximum of 100 URLs.
- Currently, only HTTPS (recommended) and HTTP (risky) are supported.
You can add the file(s) to be pulled in either of the following ways:
- Adding one file: Enter information about the audio/video file to be pulled in the audio/video file URL and audio/video file name columns.
- Batch adding files: Click Batch Import Template to download the template file to the local PC. After all audio/video file URLs and names are added, click Select File to import files.
NOTE:Do not attach sensitive information such as authentication credentials to the URLs that pull content.
Process
Determine whether to process the obtained audio/video files.
This function is disabled by default. To enable it, you need to select the processing mode, that is, to select a transcoding template group or a workflow.
Select Process Mode
This parameter is displayed only when Process is enabled.
Click Select on the right of Select Process Mode.
On the dialog box displayed, configure the following parameters:
- Transcoding template group: Select a preset template group or customize a template group by referring to Creating a Template Group.
- Workflow: Select an existing workflow or create one by referring to Workflow Settings.
Video Cover
Sets whether to use the first frame of the video as the thumbnail.
- Click Confirm. You can view the task status in the URL pull list. When the status becomes Completed, the pull is successful. You can view audio/video information on the Audio and Video Management page.Figure 2 URL pull status
