Unsubscribing from a Read Replica
You can unsubscribe a read replica of a yearly/monthly instance.
- You can only unsubscribe from a read replica when the instance has two or more read replicas. At least one read replica must be retained in the instance.
- Only isolated read replicas can be unsubscribed.
- If a read replica of a DB instance is being isolated, you cannot perform the following operations for the instance:
- Creating read replicas
- Scaling up storage space
- Changing instance specifications
- Rebooting the instance
- Resetting the password
- Upgrading the patch
- Changing the private IP address
- Changing the database port
- Enabling or disabling SSL
- Binding an EIP
- Operations related to proxy instances
- The following operations cannot be performed on other read replicas of the instance:
- Changing a failover priority
- Promoting a read replica to primary
- Isolating a read replica
Billing
For unsubscription fees, see Unsubscription Rules.
- Log in to the TaurusDB console.
- On the Instances page, click the instance name to go to the Basic Information page.
- In the Node List area, locate a read replica and click Isolate in the Operation column.
- When a read replica is isolated, you can only unsubscribe or release it.
- When the workloads are heavy, you can release the isolated read replica if necessary.
- After the read replica status changes to Isolated, choose More > Unsubscribe in the Operation column.
- It takes about 1 minute to isolate a read replica.
- When a read replica is isolated, read operations and database synchronization cannot be performed.
- On the displayed page, confirm the order to be unsubscribed and select a reason. Then, click Confirm.
For unsubscription details, see Unsubscription Rules.
- In the displayed dialog box, click Yes.
After an unsubscription request is submitted, resources and data will be deleted and cannot be retrieved.
- View the unsubscription result. After the order is successfully unsubscribed, the unsubscribed read replica of the instance will be deleted.
