Updated on 2025-12-02 GMT+08:00
Adding Work Item Domains
  • You can add, edit, and delete work item domains in a project.
  • When creating or editing a work item, you can specify the domain to which the work item belongs.
    The default domains include performance, function, reliability, network security, maintainability, other DFX, and usability. You can add more domains as required.
  1. Access the CodeArts Req homepage.
  2. Go to a Scrum project and choose Settings > Work.
  3. In the navigation pane, choose Domains.
    Figure 1 Domains page
  4. Click Add Domain to add a work item domain by referring to the following table. A maximum of 25 domains can be added.
    Table 1 Adding a domain
    Name
    Domain name. Enter a maximum of 30 characters.
  5. Click Clone Domain to replace the domain settings of the target project with those of the current project.
  6. Edit or delete a domain if needed.
    Table 2 Domain operations
    Operation
    Edit
    Click to modify a domain. The default domains cannot be edited.
    Delete
    Click to delete a domain. The domains that are currently in use or the default domains cannot be deleted.
  7. On the page for creating or editing a work item, select an added domain in the Domain field.
    Figure 2 Work item details page
  8. (Optional) After the configuration is complete, click Save as Template in the upper right corner of the page. In the Save as Template dialog box, enter a template name and description, and click OK. This template can be used to create Scrum projects. For details, see the following figure.
    Figure 3 Applying a work item template
