On this page
Creating a Release Environment
Updated on 2025-01-22 GMT+08:00
  1. Log in to the Huawei Cloud console.
  2. Click in the upper left corner of the page, and choose Developer Services > CodeArts from the service list.
  3. Click Access Service to go to the CodeArts homepage.
  4. Click a project name to access the project.
  5. Choose CICD > Release to access the release environment list page.
  6. Click Create Environment. On the displayed page, set basic information. For details, see Table 1.
    Table 1 Parameter description
    Project
    Project to which the environment belongs. The project cannot be changed.
    Environment Name
    Unique identifier of the release environment. Enter only letters, digits, underscores (_), and hyphens (-) with a maximum of 128 characters.
    Resource Type
    CCE, UCS, and K8s are available. They support different deployment extensions.
    • CCE: a type of Kubernetes cluster encapsulated by Huawei Cloud. Select this type if you want to use Huawei Cloud resources. Learn more.
    • UCS: a type of Kubernetes cluster encapsulated by Huawei Cloud for multi-cloud deployment. Select this type if you want to deploy clusters on multiple clouds. Learn more.
    • K8s: the native Kubernetes cluster. Select this type if you want to use self-built clusters or third-party clusters.
    Publish User
    Options: Current User or Other Users.
    • Current User: Create an environment based on the cluster of the current user.
    • Other Users: Create an environment based on the clusters of other users. Obtain other users' cluster permissions through endpoints. For details, see Creating Service Endpoints.
    Region
    This parameter is required when you select CCE for Resource Type.
    Select the region where the environment is to be deployed.
    Cluster
    Select the purchased Kubernetes clusters in Cloud Container Engine (CCE).
    Association Type
    This parameter is required when you select UCS for Resource Type.
    Associated UCS resources. Only fleet is supported.
    Fleets
    Select a fleet.
    Kubernetes Endpoint
    This parameter is required when you select K8s for Resource Type.
    Select a created Kubernetes endpoint to access cluster resources with credential. For details, see Creating Service Endpoints.
    Environment Level
    Available environment types: development, test, pre-release, and production. For details about environment permissions, see Project-level Permissions.
    Enter the description of the environment with no more than 200 characters.
  7. After setting all parameters, click OK. The environment information page is displayed.
    Table 2 Environment information
    Resource Type
    Resource types associated with the environment.
    Publish User
    Current user.
    Service Endpoint
    Service endpoint of CCE resources.
    Cluster Region
    Kubernetes cluster region applied in CCE.
    Cluster ID
    Kubernetes cluster ID applied in CCE.
    Variable Version
    Version number of the environment variable in the current environment.
    Tag
    Environment type.
    Description of the environment.
