- What's New
- Getting Started
User Guide
- Permissions Management
- Managing Organizations
- Managing OUs
- Managing Accounts
Managing SCPs
- Overview of an SCP
- Enabling or Disabling the SCP Type
- Creating an SCP
- Modifying or Deleting an SCP
- Attaching or Detaching an SCP
- Example SCPs
- System-defined SCPs
- Cloud Services for Using SCPs
- Regions for Using SCPs
Actions Supported by SCP-based Authorization
- Compute
- Storage
- Networking
- Containers
- Analytics
- Content Delivery & Edge Computing
- Databases
- Security & Compliance
- Internet of Things
- Middleware
- Developer Services
- Business Applications
- Simple Message Notification (SMN)
- Log Tank Service (LTS)
- Identity and Access Management (IAM)
- Security Token Service (STS)
- Resource Formation Service (RFS)
- IAM Identity Center
- Organizations
- Resource Access Manager (RAM)
- Enterprise Project Management Service (EPS)
- Tag Management Service (TMS)
- Config
- IAM Access Analyzer
- Cloud Trace Service (CTS)
- Resource Governance Center (RGC)
- Application Operations Management (AOM)
- Cloud Eye (CES)
- IAM Identity Broker
- User Support
- Migration
- Managing Tag Policies
- Managing Trusted Services
- Managing Tags
- CTS Auditing
- Adjusting Quotas
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Managing OUs
Managing Accounts
- Creating an account and adding it to your organization
- Creating an Account
- Listing Accounts in an Organization
- Closing an Account
- Getting Account Information
- Updating an Account
- Removing the Specified Account
- Moving an Account
- Inviting an Account to Join an Organization
- Querying Account Creation Requests in Specified State
- Querying Account Creation Status
- Querying CloseAccount Requests in Specified State
- Managing Invitations
- Managing Delegated Administrators
- Managing Policies
Managing Tags
- Listing Tags for the Specified Resource
- Adding Tags to the Specified Resource
- Removing Tags from the Specified Resource
- Listing Tags for the Specified Resource Type
- Adding Tags to the Specified Resource Type
- Deleting Tags with the Specified Key from the Specified Resource Type
- Querying Resource Instances by Resource Type and Tag
- Querying Number of Resource Instances by Resource Type and Tag
- Querying Resource Tags
- Others
- Appendixes
- Change History
- FAQs
Creating an Account
You can use the management account to create new accounts in your organization. The accounts you created are referred to as resource accounts. For details, see What Are the Differences Between a Resource Account and a Member Account for Unified Accounting? If you want to convert a resource account to a cloud account, refer to Converting a Resource Account to a Cloud Account.
This section includes the following content:
- Accessing Account Resources Via Agency
- Accessing Account Resources Via IAM Identity Center
- An organization administrator can create a maximum of five accounts at a time.
- The email address associated with the account you are creating cannot be used by another account.
- Accounts created via Organizations can only be used for login only by switching roles via an agency or by accessing the IAM Identity Center console.
- The accounting of accounts created via Organizations is hosted by the organization management account by default.
The email address to be associated with the new account must be valid.
Creating an Account
- Log in to Huawei Cloud as the organization administrator or using the management account, navigate to the Organizations console, and access the Organization page.
- On the Organization page, choose Add > Add Account.
Figure 1 Adding an account
- Click Create new in the displayed dialog box.
- Enter the account name and email address. Ensure that the account name is different from any existing one.
You can retain the default agency name or change it as required.Figure 2 Creating an account
- (Optional) Add one or more tags to the account.
A tag consists of a key-value pair. Tags are used to identify, classify, and search for accounts. You can add up to 20 tags to an account.
Table 1 describes the key and value descriptions of a tag.Table 1 Tag description Element
Example
Tag key
A tag key of an account must be unique. You can create a custom key or select a key of an existing tag created in Tag Management Service (TMS).
A tag key:
- Cannot be an empty string.
- Contains 1 to 128 characters.
- Consists of letters, digits, underscores (_), hyphens (-), and Unicode characters (\u4E00-\u9FFF).
Key_0001
Tag value
A tag value can be repetitive or an empty string.
A tag value:
- Can be an empty string.
- Contains 1 to 225 characters.
- Consists of letters, digits, underscores (_), periods (.), hyphens (-), and Unicode characters (\u4E00-\u9FFF).
Value_0001
- Click OK. The new account is added to the list.
- Hover the mouse pointer over the username in the upper right corner and choose Switch Role.
Figure 3 Switching the role
- On the Switch Role page, enter the account name.
Figure 4 Entering the account name
After you enter the account name, the agencies created under this account will be automatically displayed when you click the agency name text box. An agency name starting with cbc_ will also be displayed. This agency is mainly used by an enterprise master account to centrally manage expenditures and grant permissions to member accounts. You need to select the agency name entered when creating the account.
- Click OK to switch to the account.
You can associate an account with users and permission sets in IAM Identity Center, and log in to the IAM Identity Center console via the user portal URL to access the resources in the account in the given organization. The specific access permission for resources is controlled by the permission set in IAM Identity Center.
- Associate the account with users and permission sets. For details, see Associating Accounts with Users/Groups and Permission Sets.
- Log in to the IAM Identity Center console and access the account resources. For details, see Logging In as an IAM Identity Center User and Accessing Resources.
