Registering an Account
You can log in to the user portal as a user that has been created by the administrator. If you do not have an account, follow the instructions in this section to register one.
The administrator has enabled user account registration. For details, see Global Settings.
- Go to the user portal login page.
Obtain the user portal URL from the enterprise administrator. For example, https://example.huaweioneaccess.com.
- Click Register now on the login page.
- Enter a mobile number on the registration page.
- Click Send Code and enter the verification code you received into the designated text box.
- Click Next, enter a username, and set and confirm the password.
The administrator determines the user information that needs to be entered by setting the user attributes used for registration information collection.
- (Optional) Select the user agreement enabled and configured by the administrator.
When registering an account, you are required to select the user agreement that has been configured and enabled. For details, see Enabling and Configuring the User Agreement.
- Click Save. Once registered, you can access the user portal using the account.
By default, the new account is assigned to the root organization. If you want to select your desired organization during account registration, contact the administrator to enable organization configuration. For details, see Modifying User Attributes.
