Help Center/ Object Storage Service/ User Guide/ Domain Name Management/ Accessing a Bucket Using a User-Defined Domain Name
Updated on 2026-09-10 GMT+08:00
After you upload a file to a bucket, OBS generates an access address for the file that includes the bucket's default domain name. Accessing this address using a browser will automatically download the file. To avoid exposing the default domain name of a bucket or to preview files online through a browser, you can bind a user-defined domain name to the bucket and use it to access the files in the bucket.
  • File preview: To avoid automatic file downloads, you can bind a user-defined domain name to a bucket for online file preview.
  • Keeping the access address unchanged: To keep website or file access addresses unchanged after a migration or storage location change, you can upload the files to a bucket and bind a user-defined domain name to the bucket. This will establish a mapping between the website domain name and the default bucket domain name. In this way, you can still access the files using the original address.
  • Improved brand image: Having a fixed and personalized domain name for accessing an enterprise website can make the enterprise appear more professional and reliable. This enhances enterprise image and improves customer experience.
  • Easy access: You can use a user-defined domain name that is easy to remember to access a bucket and files in the bucket.
Principles
The following describes the process of accessing objects in a bucket using a user-defined domain name and the process of accessing objects in a bucket using the default bucket domain name.
Figure 1 shows the process of using a user-defined domain name to access objects in a bucket.
Figure 1 Using a user-defined domain name to access objects in a bucket
  1. A user enters a file access address (that includes a user-defined domain name) in a browser to initiate an access request.
  2. DNS maps the user-defined domain name to the default domain name of the bucket.
  3. DNS translates the default domain name of the bucket to the IP address of the OBS server.
  4. OBS returns the IP address of the server to the client.
  5. The client sends a request with the user-defined domain name specified in the Host header to the IP address of the OBS server.
  6. OBS identifies the user-defined domain name in the Host header and returns a response with Content-Disposition set to inline to the client, which indicates that the file is expected to be displayed in the browser.
Figure 2 shows the process of using a bucket's default domain name (bucketName.obs.endpoint.myhuaweicloud.com) to access objects in the bucket.
Figure 2 Using a bucket's default domain name to access objects in the bucket
  1. A user enters a file access address (that includes the default domain name of the bucket) in the browser to initiate an access request.
  2. DNS translates the default domain name of the bucket to the IP address of the OBS server.
  3. OBS returns the IP address of the server to the client.
  4. The client sends a request with the default domain name specified in the Host header to the IP address of the OBS server.
  5. OBS identifies the default domain name in the Host header and returns a response with Content-Disposition set to attachment to the client, which indicates that the file is expected to be downloaded and saved locally.
Table 1 Constraints
Item
Bucket version
Only buckets whose version is 3.0 or later support user-defined domain names. To check the version of a bucket, go to OBS Console, click the bucket name and go to the Overview page, and find the version in the Basic Information area.
Number of domain names
By default, a bucket can have up to 100 user-defined domain names bound.
Functions
  • A user-defined domain name can be bound to only one bucket.
  • Chinese domain names are not supported.
  • The suffix of a user-defined domain name can contain 2 to 63 uppercase or lowercase letters.
  • As required by the MIIT, if the bucket which a user-defined domain name is bound to is in a Chinese mainland region, you must complete the ICP filing.
  • To access an OBS bucket over the Internet, typically use a user-defined domain name. For intranet access, it is recommended to use the bucket's default domain name (bucketName.obs.endpoint.myhuaweicloud.com).
If an acceleration domain name is also required, to prevent objects in OBS buckets from being directly downloaded upon access, you need to perform other required operations after the user-defined domain name and the acceleration domain name have been configured. For details, see With CDN Acceleration Enabled, Why Are the Objects in My OBS Bucket Directly Downloaded When I Access Them?
Permissions
In cross-account scenarios, the APIs for setting, obtaining, or deleting a bucket's user-defined domain name cannot be called. Assume there are two HUAWEI IDs. One of them cannot set, obtain, or delete the user-defined domain of the other.
In the same account, you must be the bucket owner or have the permissions to set (obs:bucket:PutBucketCustomDomainConfiguration), obtain (obs:bucket:GetBucketCustomDomainConfiguration), and delete (obs:bucket:DeleteBucketCustomDomainConfiguration) the user-defined domain name. You are advised to use IAM or bucket policies for authorization. For more information about OBS authorization methods, see Differences Between OBS Permissions Control Methods.
  • There is a bucket with objects. For details, see Creating a Bucket.
  • There is a second-level domain.
Configuring a User-Defined Domain Name
You can use OBS Console, APIs, obsutil, or SDKs to configure user-defined domain names. You cannot use OBS Browser+ to do so.
Specifically, perform the following steps:
  1. Bind a user-defined domain name to the bucket.
  2. Add a CNAME record set to map the user-defined domain name to the default domain name of the bucket.
  3. (Optional) Configure HTTPS to secure access through the user-defined domain name.
Using a User-Defined Domain Name to Access Objects
After a user-defined domain name is bound to a bucket and the domain name resolution is successful, verify that you can use the domain name to access objects. You can use APIs, SDKs, or obsutil to access objects through a user-defined domain name. You cannot use OBS Console or OBS Browser+ to do so.
References
