Updated on 2025-12-12 GMT+08:00
Data Replication Overview
A fault in data storage can severely impact services. Therefore, backup and disaster recovery (DR) are critical to data storage. To ensure backup and DR, you can replicate data between buckets (either in the same region or across different regions).
Data replication falls into the following types: cross-region replication within an account, cross-region replication across accounts, same-region replication within an account, and same-region replication across accounts.
The following source and destination buckets are all Huawei Cloud OBS buckets.
Content Replicated
When data is replicated, it may often have features such as versioning, lifecycle rules, server-side encryption, and WORM retention policies. The following explains how these features affect replication, specifically, which data will be replicated and which will not.
The following tables describe how versioning affects data replication.
Table 1 The impact of versioning on cross-region replication within an account
Condition
Operation
Replication Result
(Using OBS Console)
Replication Result
(Using OBS APIs)
Replication Result
(Using obsutil)
Source and destination buckets have the same versioning status (disabled, enabled, or suspended).
Replicated
Replicated
Replicated
Source and destination buckets have different versioning statuses (disabled, enabled, or suspended).
Not replicated
Not replicated
Not replicated
Cross-region replication within an account is enabled.
Change the versioning status of the source or destination bucket.
Not replicated
Not replicated
Not replicated
Source and destination buckets have their versioning enabled or suspended, and cross-region replication within an account is enabled.
Delete an object from the source bucket without specifying a version.
The object copy is synchronously deleted from the destination bucket.
Delete a specific version of an object from the source bucket.
The copy of the object version is synchronously deleted from the destination bucket.
Source and destination buckets have their versioning disabled, and cross-region replication within an account is enabled.
Delete an object from the source bucket.
To use cross-region replication within an account, the source and destination buckets must have the same versioning status (enabled or disabled).
Table 2 The impact of versioning on cross-region replication across accounts
Condition
Operation
Replication Result
(Using the OMS Console)
Replication Result
(Using OMS APIs)
Replication Result
(Using obsutil)
Upload or modify an object.
Replicated
Replicated
Replicated
Replicated
Replicated
Not replicated
Source and destination buckets have versioning enabled or suspended.
The object copy is not deleted from the destination bucket.
The copy of the object version is not deleted from the destination bucket.
Source and destination buckets have versioning disabled.
Table 3 The impact of versioning on same-region replication (within an account or across accounts)
Condition
Operation
Replication Result
Replication Result
(Using OMS APIs)
Replication Result
(Using OBS APIs)
Replication Result
Using OBS SDKs
Replication Result
(Using obsutil)
Replicated
Replicated
Replicated
Replicated
Replicated
Replicated
Replicated
Not replicated
Not replicated
Not replicated
The impact of lifecycle rules on data replication is as follows:
Lifecycle rules configured in a source bucket are not replicated to the destination bucket. Instead, only the results of those rules are synchronized to the destination bucket.
The impact of server-side encryption on data replication is as follows:
  • If the objects in the source bucket are not encrypted and encryption is disabled for the destination bucket, the object copies in the destination bucket will remain unencrypted.
  • If the objects in the source bucket are not encrypted but SSE-OBS is enabled for the destination bucket, the object copies in the destination bucket will also be encrypted with SSE-OBS.
  • If the objects in the source bucket are not encrypted but SSE-KMS (that uses the default key or a custom key) is enabled for the destination bucket, the object copies in the destination bucket will be encrypted in the same way as the destination bucket.
  • If the objects in the source bucket are encrypted with SSE-OBS, the object copies in the destination bucket will be encrypted in the same way as the source objects, regardless of the encryption settings of the destination bucket.
  • If the objects in the source bucket are encrypted with SSE-KMS that uses the default key or a custom key, the object copies in the destination bucket will be encrypted in the same way as the source objects, regardless of the encryption settings of the destination bucket.
  • If the objects in the source bucket are encrypted with SSE-C, they cannot be replicated when you use OBS Console or OBS APIs, but they can be replicated when you use OBS SDKs, obsutil, OMS console, or OMS APIs.
During the retention period of a WORM-protected bucket, users can upload objects to or read objects from the bucket but cannot modify (overwrite) or delete objects in it. For details, see Configuring WORM to Protect Objects from Being Overwritten or Deleted.
The impact of WORM retention policies on data replication is as follows:
  • If the source bucket (together with objects in it) is in a WORM retention period, the replication is not affected by whether the destination bucket is in a WORM retention period. Objects newly uploaded to the source bucket will be replicated to the destination bucket, but the WORM retention policy of the source bucket will not be replicated.
  • If the source bucket is not in a WORM retention period:
    • If the objects in the source bucket are in a WORM retention period, the replication is not affected by whether the destination bucket is in a WORM retention period. Objects newly uploaded to the source bucket will be replicated to the destination bucket, but the WORM retention policy of the source objects will not be replicated.
    • If the objects in the source bucket are not in a WORM retention period but the destination bucket is, objects newly uploaded to the source bucket will be replicated to the destination bucket, but object modifications or deletions will not.
    • If both the objects in the source bucket and the destination bucket are not in a WORM retention period, new object uploads or modifications in the source bucket will be replicated to the destination bucket; object deletions will be replicated to the destination bucket through the OBS console, APIs, SDKs, or obsutil but will not be replicated through the OMS console or APIs.
  • An object copy in the destination bucket retains the creation time of the source object, rather than the replication time.
  • The impact of storage classes on data replication is as follows:
    • Objects in the Archive, or Deep Archive storage class in the source bucket can be replicated to the destination bucket only when they have been restored. If source objects are not restored or are being restored, the replication will fail.
    • If the region of the destination bucket does not support storage class setting or does not support a specific storage class, object copies will be stored in the Standard storage class.
  • The impact of object ACLs on data replication is as follows:
    • If source objects have ACLs configured, the objects and their ACLs will be replicated when you use the OBS console, APIs, SDKs, or obsutil. If you use the OMS console or APIs, only the objects will be replicated, while their ACLs will not.
    • If source objects have no ACLs configured, the objects will be replicated regardless of which method is used.
Billing for Data Replication
  • When you use the OMS console or APIs to migrate data, OBS APIs of both the source and destination ends are invoked to handle data upload and download. You will be billed for the API requests and data download traffic. For details, see OMS Billing. In addition, you will be billed for storing the objects in the destination bucket. For details, see Storage Costs.
  • When you use the OBS console, APIs, or obsutil to replicate data across regions, you will be billed for requests, traffic, and storage. For details, see Table 4.
    Table 4 Billing for data replication across regions
    Action
    Billing Item
    Billing Mode
    Replicate data across regions
    Requests
    You are billed for the number of successfully replicated objects. Successfully replicating one object creates a copy request. For details, see Copying Objects.
    • For non-multipart objects, replicating an object creates a GET request to the source bucket and a PUT request to the destination bucket; deleting an object from the source bucket creates a DELETE request to the destination bucket.
    • For multipart objects, replicating each part creates a GET request to the source bucket and a PUT request to the destination bucket.
    For details about how requests are billed, see Requests.
    Pay-per-use
    Data transfer
    Traffic generated when you replicate data from the source bucket to the destination bucket in another region. Billing only applies to the data transferred out of the source bucket.
    If objects are encrypted using server-side encryption, the cost of their cross-region replication traffic is calculated based on the length of the plaintext for SSE-KMS and SSE-OBS.
    Pay-per-use
    Storage space
    Space occupied by the replicated objects in the destination bucket
    If you have specified another storage class for object copies in the destination bucket, these copies are billed based on the new storage class.
    If objects are encrypted using server-side encryption, their storage cost is calculated based on the length of the ciphertext.
    Pay-per-use
    Resource packages
    Synchronize existing objects
    Requests
    You are billed for the number of existing objects that are successfully replicated to the destination bucket.
    Billing applies to the number of objects that are successfully replicated. You are also billed for listing the existing objects.
    Pay-per-use
    Data transfer
    Traffic generated when OBS replicates existing objects to the destination bucket in another region. Billing only applies to the data transferred out of the source bucket.
    If historical objects are encrypted using server-side encryption, the cost of their cross-region replication traffic is calculated based on the length of the plaintext for SSE-KMS and SSE-OBS.
    Pay-per-use
    Storage space
    If historical objects are encrypted using server-side encryption, their storage cost is calculated based on the length of the ciphertext.
    Pay-per-use
    Resource packages
  • When you use OBS APIs, OBS SDKs, OBS Browser+, or obsutil to replicate data within the same region, you will be billed for requests and storage. For details, see Table 5.
    Table 5 Billing for data replication in the same region
    Action
    Billing Item
    Billing Mode
    Replicate data in the same region
    Requests
    To learn about the request billing, see Requests.
    Pay-per-use
    Data transfer
    Free, because data in the same region is replicated over an intranet.
    N/A
    Storage space
    Storage space occupied by objects stored in the destination bucket.
    Pay-per-use
    Resource packages
