Creating a General Storage Migration Workflow
This section describes how to create a general storage migration workflow from the predefined template.
This feature is available in certain regions. You can see these regions on the console.
- See What Are the Restrictions on Using MgC for Storage Migration?
- Data in the Deep Cold Archive storage of Alibaba Cloud OSS cannot be restored using the restoration function of MgC. You need to manually restore the data before migration.
- Microsoft Azure Blob does not support automatic archiving of restored data. If needed, you can manually archive the data after the migration is complete.
Warnings
When you create a workflow, there are three options for Overwrite Existing: Never, Always, and If older or different size. If you choose Never, restarting a migration after an interruption or pause may lead to incomplete data migration, even though the task may appear successful. This could impact data integrity, so use the Never option with caution.
- You have created an OBS bucket or SFS file system on Huawei Cloud.
- You have created a migration cluster.
- Sign in to the MgC console. In the navigation pane, under Project, select your application migration project from the drop-down list.
- In the navigation pane, choose Workflows.
- Click Create Workflow in the upper right corner of the page.
- In the General Storage Migration card, click Preview Steps to view the stages and steps predefined in the template and the detailed description of each stage and step. Automated steps are handled by the system. Click Configure Workflow in the lower right corner.
- Set workflow basics based on Table 1.
Table 1 Basic parameters Parameter
Name
User-defined. Only letters, digits, hyphens (-), underscores (_), and periods (.) are allowed. The name must start with a letter or digit, and it must not start or end with a period.
Region
Select the region you are migrating to.
User-defined. It can contain a maximum of 255 characters. Allowed characters include letters, digits, hyphens (-), underscores (_), commas (,), periods (.), spaces, and decimal points (.). It cannot start with a decimal point (.), hyphen (-), or underscore (_).
Cluster
Select a migration cluster. The cluster consists of a master node and several migration and list nodes. If no cluster is available, create a cluster.
NOTE:A master node is created by the system in a migration cluster by default. You do not need to configure it.
- Configure the migration source and target based on Table 2 and Table 3.
Table 2 Parameters for configuring a migration source Parameter
Remarks
Location Type
Credential
Select the credential from the drop-down list. If the credential has not been added, click Add Credential, enter a credential name, select an authentication method, enter the AK/SK pair, and click Verify and Save.
These parameters are available when cloud storage is selected for Location Type.
Bucket
Enter the name of the source bucket to be migrated.
NOTE:Symbolic links cannot be used for specifying migration paths which define the migration scope. To migrate a path pointed to by a symbolic link, you need to:- Enter the actual path when specifying the migration path.
- After the migration is complete, manually create a symbolic link to the path at the target.
Endpoint
Enter the endpoint of the region where the source bucket is located.
For example, if Location Type is set to Alibaba Cloud OSS and the source bucket is located in CN East 1 (Hangzhou), enter oss-cn-hangzhou.aliyuncs.com.
Type
Set this parameter based on the source bucket type. You can view the bucket type in the basic information.
This parameter is available when Location Type is set to Huawei Cloud OBS.
APPID
Enter the APPID of your Tencent Cloud account.
NOTE:You can view the APPID on the account information page of the Tencent Cloud console.
This parameter is available when Tencent Cloud COS is selected for Location Type.
Authentication Type
The following authentication types are supported:
- Connection string
- Storage account name and key
For details about how to obtain the credentials, see How Do I Obtain Credentials for Accessing Microsoft Azure?
This parameter is available when Azure Blob Storage is selected for Location Type.
List Path
Enter the path to the lists of files to be migrated. These lists must be stored in the same region as the target bucket. You need to write the URLs of files to be migrated and their new names at the target into the lists. Each line in the list can contain only one URL and one file name.
These parameters are available when HTTP/HTTPS data source is selected for Location Type.
File System Address
Enter the mount address of the source file system. The format is IP address:/ or IP address:/xxx, for example, 192.1.1.1:/0001.
These parameters are available when Location Type is set to NAS_SMB, NAS_NFS_V3_MOUNT, or NAS_NFS_V3_PROTOCOL.
Path
Enter the directory that contains the files to be migrated. The format is /Folder name.
Username
Enter the username of the account that can access all files in the source file system, for example, administrator.
These parameters are available when Location Type is set to NAS_SMB.
Password
Enter the password corresponding to the username.
Domain on Windows
Enter the corresponding domain name.
NOTE:You only need to enter the content before .com. For example, if the domain is test.com, enter test.
Table 3 Parameters for configuring a migration target Parameter
Remarks
Location Type
Select a Huawei Cloud storage type based on the source storage type.
Credential
These parameters are available when Location Type is set to Huawei Cloud OBS.
Bucket
Select the OBS bucket you are migrating your data to.
NOTE:Only Standard and Infrequent Access buckets are supported.
Type
Endpoint
Enter the endpoint of the region where the target OBS bucket is located. For example, if the target bucket is located in the CN North-Beijing4 region of Huawei Cloud, enter obs.cn-north-4.myhuaweicloud.com.
NOTE:You can view the endpoint in the OBS bucket overview.
Specify Prefix
Specify a prefix to rename or relocate objects migrated to the target bucket. For example, if you specify the prefix /D, source file /A/B/C.txt will be relocated to /D/A/B/C.txt after being migrated to the target bucket. For details, see:
File System Address
Enter the mount address of the target file system. To obtain the mount address, go to the file system list and click the
icon next to the address in the Mount Point column.
These parameters are available when Location Type is set to NAS_NFS_V3_PROTOCOL, NAS_GFS, NAS_SMB, or NAS_NFS_V3_MOUNT.
Path
Enter the directory for storing files migrated. The format is /Folder name.
Username
Enter the username of the account that can access all files in the target file system, for example, administrator.
Password
Domain on Windows
- Configure migration settings based on Table 4.
Table 4 Migration settings Parameter
Sub-parameter
Task Type
Full migration
Migrates all data in a source bucket or in specific paths.
List migration
Migrates objects recorded in the list files.
In List Path box, enter the path of the object lists stored in the target bucket. Restrictions on an object list file vary with the target location.
- Target location: Huawei Cloud OBS
- An object list file cannot exceed 30 MB.
- An object list file must be a .txt file, and the Content-Type metadata must be text/plain.
- An object list file must be in UTF-8 without BOM.
- Each line in an object list file can contain only one object name, and the object name must be URL encoded.
- Each line in an object list file cannot exceed 16 KB, or the migration will fail.
- The Content-Encoding metadata of an object list file must be left empty, or the migration will fail.
- An object list file can contain a maximum of 10,000 lines.
- Target location: NAS
- An object list file must be a .txt file.
Prefix migration
This option is only available for cloud storage migration.
If you enter a file name or name prefix in the Prefix box, only the objects that exactly match the specified name or prefix are migrated.
NOTICE:- If the files to be migrated are stored in the root directory of the source bucket, add their name prefixes directly. If the files are stored in a non-root directory, add their directories and name prefixes in the format of <folder-name>/<prefix>.
- Use commas (,) to separate multiple prefixes.
Listing Mode
NOTE:This parameter is available only when Task Type is set to Full migration or Prefix migration
Serial
This is the default listing mode if the source is a bucket.
Parallel
This is the default listing mode if the source is a parallel file system (PFS). If this mode is selected when the source is a bucket, the listing operation may take a long time.
Concurrent Subtasks
User-defined. There cannot be more than 10 concurrent subtasks for each online migration node. For example, if there are 2 online migration nodes, the maximum number of subtasks can be 20 or any number below.
Overwrite Existing
Never
Files existing at the target will never be overwritten.
WARNING:- If you choose Never for the initial migration, the attributes of involved parent folders at the source will not be migrated to the target. As a result, the folder attributes may be incomplete at the target. To avoid this issue, use the Never option with caution for the initial migration.
- If you choose Never, restarting a migration after an interruption or pause may lead to incomplete data migration, even though the task may appear successful. This could impact data integrity, so use the Never option with caution.
Always
Files existing at the target will always be overwritten.
- The system replaces existing target files if they are older than or differ in size from their source counterparts. Files with matching modification times and sizes remain unchanged and are skipped during migration.
- The system verifies folders after their content is migrated. Folders that already exist at the target will be overwritten if they have different last modification times, sizes, or permissions from the paired folders at the source.
The same overwriting policy is applied to empty folders as files.
If different CRC 64 checksum
If a source object has a CRC64 checksum different from the paired target object, the source object will overwrite the target one. Otherwise, the source object will be skipped during the migration. If either of them does not have a CRC64 checksum, their sizes and last modification times are checked.NOTE:- This option is only available for migration within Huawei Cloud or from Alibaba Cloud or Tencent Cloud.
- Using this option requires that target OBS buckets be whitelisted for the CRC64 feature.
Consistency Verification
Size and last modified
With this default method, the system checks data consistency by comparing object size and last modification time.
CRC64 checksum
The system verifies data consistency by comparing CRC64 values in the metadata. If a source object and the paired target object have CRC64 checksums, the checksums are checked. Otherwise, their sizes and last modification times are checked.NOTE:- This option is only available for migration within Huawei Cloud or from Alibaba Cloud or Tencent Cloud.
Migrate Metadata
Determine whether to migrate metadata.
- If you select this option, object metadata will be migrated.
- If you do not select this option, only the Content-Type and Content-Encoding metadata will be migrated.
Clear Cluster
Determine whether to clear the migration cluster after the migration is complete.
- If you select this option, a step for clearing the migration cluster will be created in the workflow. You can also choose whether to clear resources used by the cluster, such as NAT gateways, security groups, and VPCEP resources.
- If you do not select this option, a step for clearing the migration cluster will not be created in the workflow, but the migration cluster and its resources will automatically be deleted 30 days after the workflow is created.
- (Optional) Configure advanced options based on Table 5.
Table 5 Advanced options Parameter
Remarks
Target Storage Class
Choose the storage class that your data will be migrated to. For details about storage classes, see How Do I Choose Storage Classes?
NOTE:CRC64-based consistency verification is not available for Archive and Deep Archive storage classes. Even if you choose the CRC64-based verification method, the system automatically uses the object size and last modification time to verify data consistency.
Enable KMS Encryption
- If you do not select this option, whether migrated data will be encrypted in the target buckets depends on the server-side encryption setting of the buckets.
- If you select this option, all migrated objects will be encrypted before they are stored to the target bucket.
NOTE:- Using KMS to encrypt migrated data may slow down the migration speed by about 10%.
- This option is only available when KMS is supported in the region you are migrating to.
This parameter is only available for migrations to Huawei Cloud OBS.
Restore Archive Data
- If you do not select this option, the system records archived objects in the list of objects that failed to be migrated and continues to migrate other objects in the migration task.
- If you select this option, the system automatically restores and migrates archived objects in the migration task. If an archived object fails to be restored, the system skips it and records it in the list of objects that failed to be migrated and continues to migrate other objects in the migration task.
NOTE:- The system will restore all listed archived data before migrating it, and you pay the source cloud platform for the API requests and storage space generated accordingly.
Filter Source Data
Use exclude patterns, include patterns, and time ranges to filter files to be migrated. For details about the filters, see Source Data Filters.
Download Data from CDN
If the default domain name cannot meet your migration requirements, then as long as the source cloud service provider supports custom domain names, you can bind a custom domain name to the source bucket, and enable the CDN service on the source platform to reduce data download expenses. Enter a custom domain name in the Domain Name text box and select a transmission protocol. HTTPS is more secure than HTTP and is recommended.
If the migration source is the Alibaba Cloud OSS or Tencent Cloud COS, you also need to select an authentication type and enter an authentication key.
Send SMN Notifications
Determine whether to use SMN to get notifications about migration results.
- If you do not select this option, no SMN messages will be sent after the migration is complete.
- If you select this option, after the migration is complete, SMN messages will be sent to the subscribers of the selected topic. You can select the language and trigger conditions for sending messages.
Limit Traffic
Set the maximum bandwidth for the migration task during different periods.
- If you do not select this option, migration traffic will not be limited.
- If you select this option, you can limit the migration traffic by setting Start Time, End Time, and Bandwidth Limit.
For example, if you set Start Time to 08:00, End Time to 12:00, and Bandwidth Limit to 20 MB/s, the maximum migration speed is limited to 20 MB/s from 08:00 to 12:00. The migration speed is not limited outside this period.NOTE:
- The bandwidth limit ranges from 1 MB/s to 1,048,576 MB/s.
- A maximum of five rules can be added.
- The time is the local standard time of the region you are migrating to.
Schedule Migration
Schedule the migration to automatically run during a period.
- If you do not select this option, you need to manually start or stop the migration.
- If you select this option, the migration runs during the specified period and stops outside that period.
- If you set Start Time to 08:00 and End Time to 12:00, the migration task runs from 08:00 to 12:00 every day. The migration stops outside that period.
- If you set Start Time to 12:00 and End Time to 08:00, the migration runs from 12:00 of the current day to 08:00 of the next day. The migration stops outside that period.
- Click Next: Confirm.
- Confirm the workflow settings and click Confirm. The Run Workflow dialog box is displayed, which indicates that the workflow has been created.
- If you want to start the migration immediately, click Confirm to run the workflow.
- If you want to add a stage or step to the workflow, click Cancel. The workflow enters a Waiting state, and the migration has not started yet. To start the migration, click Run in the Operation column.
- On the migration workflow details page, view the workflow settings and the migration progress. You can also perform the operations below.
- Move the cursor to the migration progress bar of a resource. In the displayed window, view the migration details about the resource.
- When a migration reaches a step that requires manual confirmation, place the cursor on the progress bar and click Confirm next to the step status in the displayed window. The migration can continue only after you confirm.
- In the Basic Information area, click Manage next to the cluster name. The cluster details page is displayed on the right. On the displayed page, you can:
- Add, edit, or delete traffic limiting rules to control cluster traffic based on your requirements.
- Add or delete migration nodes or list nodes, or upgrade plug-ins for existing nodes as required.
- (Optional) Click the migration progress bar of a resource or click Migration Progress in the window displayed when you move course to the progress bar. The migration details page is displayed on the right. You can view the task overview and progress details. You can also perform the operations below.
Source Data Filters
Table 6 describes the rules and restrictions for setting source data filters.
Option |
Description |
Patten Rule |
Constraint |
Exclude Patterns |
If a file matches any excluded pattern, the file will not be migrated or compared for consistency. Both exact match and fuzzy match are supported. |
Include Patterns |
Time Range |
Filters files and directories to be migrated based on when they were last modified. Only files and directories whose last modification times fall in the configured time range will be migrated. The start time and end time can be left empty. If they are left empty, the system will not filter out source files by time. The time can be precise to the minute. |
The following table lists example pattern rules for different scenarios.
Assume that you want to migrate the directory test in the source storage system.
- If the source storage system is a NAS device, enter /test as an "include" pattern.
- If the source storage system is an object storage system, enter test as an "include" pattern.
Scenario |
Example Pattern for NAS |
Example Pattern for Object Storage |
Description |
File paths that end with xx |
/xx/**xx |
xx/**xx |
xx can be an expression containing asterisks (*) and question marks (?). |
Files whose names start with xx in the root directory |
/xx*
/xx*
File paths that start with xx |
/xx** /xx/** |
xx** xx/** |
Files whose names contain xx |
**xx* |
**xx* |
File paths that contain xx |
**xx** |
**xx** |
File paths that start with xx and end with yy. |
/xx**yy |
xx**yy |
xx and yy can be expressions containing asterisks (*) and question marks (?). |
File paths that end with xx or yy |
**{xx,yy} |
**{xx,yy} |
Files whose names contain xx or yy |
**{xx,yy}* |
**{xx,yy}* |
Files paths that contain xx or yy |
**{xx,yy}** |
**{xx,yy}** |
