Updated on 2025-12-26 GMT+08:00
Forwarding Data to MySQL for Storage
IoTDA can forward data reported by devices to RDS for MySQL for storage. You can use device data for service processing without developing additional code to store data.
In this example, data reported by all devices is forwarded to a MySQL database.
  • You have purchased an IoTDA Enterprise or Standard edition instance.
  • You have purchased an RDS for MySQL instance.
Creating a MySQL Database
  1. Log in to the Huawei Cloud official website and visit RDS for MySQL.
  2. When you purchase a MySQL instance, design database tables by referring to Data Transfer APIs to enable editing of forwarded data using filter statements. In this example, the default formats in Push a Device Property Reporting Notification are used to store the resource, event, notify_data, and event_time fields in the forwarded data to the resource, event, content, and event_time fields in the database table.
    Figure 1 Example of creating a database table
Configuring IoTDA
Using IoTDA, you can create a product model, register a device, and set a data forwarding rule to forward data reported by the device to MySQL.
  1. Access the IoTDA service page and click Access Console. Click the target instance card.
  2. In the navigation pane, choose Products. Click Create Product and select the resource space to which the new product will belong.
    The product model and device used in this topic are only examples. You can use your own product model and device.
  3. Click Create Product to create a product using MQTT. Set the parameters and click OK.
    Basic Information
    Product Name
    Enter a value, for example, MQTT_Device.
    Protocol Type
    Select MQTT.
    Data Type
    Select JSON.
    Industry
    Set the parameters as required.
    Device Type
  4. Click here to download a sample product model.
  5. On the Basic Information tab page, click Import from Local. In the displayed dialog box, load the local product model and click OK.
    Figure 2 Product - Uploading a product model
  6. In the navigation pane, choose Devices > All Devices. Click Register Device, set device registration parameters, and click OK. Save the device ID and secret returned after the registration.
    Figure 3 Device - Registering a secret device
    Resource Space
    Select the resource space (created in 3) to which the product will belong.
    Product
    Select the product created in 3.
    Node ID
    Set this parameter to the IMEI, MAC address, or serial number of the device. If the device is not a physical one, set this parameter to a custom character string that contains letters and digits.
    Device Name
    Customize the product name.
    Device ID
    This parameter is optional. If this parameter is not set, the platform automatically generates a device ID.
    Authentication Type
    Select Secret.
    Secret
    Customize the secret used for device access. If the secret is left blank, the platform automatically generates one.
  7. In the navigation pane, choose Rules > Data Forwarding, and click Create Rule.
    You can also add a MySQL database as the forwarding target on the details page of a created rule.
  8. Set the parameters based on the table below. The following parameter values are only examples. You can configure parameters of data forwarding rules by referring to Data Forwarding. After configuring the parameters, click Create Rule.
    Rule Name
    Customize a name, for example, iotda-mysql.
    Enter a rule description, for example, forwarding data to MySQL for storage.
    Data Source
    Select Device property.
    Trigger
    Device property reported is automatically configured.
    Resource Space
    Select a resource space to which the data source to be forwarded belongs or all resource spaces.
  9. Click the Set Forwarding Target tab, and then click Add to set a forwarding target.
    Forwarding Target
    Select MySQL (RDS).
    Database Instance Address
    Enter the IP address (or port number) for connecting the database instance.
    Database Name
    Enter the name of the destination database in the database instance.
    Access Account
    Enter the account of the database instance.
    Access Password
    Enter the password of the database instance.
    SSL
    Select whether to connect to the database in SSL mode. You are advised to use the SSL mode. Otherwise, security risks may exist during data transmission. To use the SSL mode, configure an SSL connection in the database instance first.
    Certificate ID
    Truststore certificate, which is used by the client to verify the server certificate. If this parameter is left blank, the default certificate provided by RDS for MySQL is used. For RDS for MySQL instances using custom certificates, upload the custom CA on the Devices > Device Certificates > CA Certificates page and complete the binding.
  10. Click Next. IoTDA will connect to the database during the process.
  11. Select the target table and configure the mapping between the data to forward and the database table.
    • Forwarding Field: JSON key of the data to forward.
    • Target Field: field in the database table. After a target field is selected, the field type is automatically matched.
    Figure 4 Setting MySQL field mapping
  12. Click Enable Rule to activate the configured data forwarding rule.
Verifying Configurations
An event (for example, device property reporting) triggers data forwarding.
Expected result:
Log in to the RDS for MySQL console and open the target table. Data forwarded to the target fields is displayed in the table.
Figure 5 Querying data reported
