Updated on 2026-09-30 GMT+08:00
Example
Preparations
  1. Create a product by referring to Product Creation.
  2. Create a device by referring to Registering an Individual Device.
Configuring a Data Forwarding Rule
  1. Access IoT Device Access and click Access Console. Click the target instance card.
  2. In the navigation pane, choose Rules > Data Forwarding.
    Figure 1 Data forwarding - List
  3. On the Rule List tab page, click Create Rule. Set the rule parameters and forwarded data, and configure the data filtering statement as follows: STARTS_WITH(notify_data.body.topic,'/test/M2M/').
    Figure 2 Creating a forwarding rule - M2M
    • Configuration of Figure 2: For all devices in the resource space XXX, when they report messages with topics containing /test/M2M/, the forwarding rule will be triggered and the messages will be forwarded to the specified forwarding target.
    • To forward the data reported by a specified device, add AND notify_data.header.device_id='${Device ID}' to the SQL statements.
    • To forward the data reported by a specified product, add AND notify_data.header.product_id='${Product ID}' to the SQL statements.
      Figure 3 Data forwarding - M2M_SQL statement example
    • For details about SQL settings, see SQL Statements.
  4. Set the forwarding target. Click Add. Select Device for Forwarding Target, set Topic to $topic() (the topic remains unchanged after forwarding), and set ttl to 5 minutes (data is cached for 5 minutes). Click OK.
    Figure 4 Creating a forwarding target - to a device
  5. Click Enable Rule in the middle of the page.
    Figure 5 Enabling a rule - Forwarding data to a device
Verification
  1. To use the M2M communication function, perform the following steps:
    2. Create a product by referring to Product Creation and set Protocol to MQTT.
      Figure 6 Creating a product - M2M
  2. Register device A (test111) and device B (test222) under the product created in 1. For details, see Registering an Individual Device.
    Figure 7 Device - Registering an M2M device
  3. This section uses MQTT.fx as an example to describe how to implement M2M communications. You can also test based on your service requirements.
    1. Open two MQTT.fx to simulate devices A (test111) and B (test222).
    2. On the Subscribe page of device B, enter the topic /test/M2M/# and click Subscribe.
      Figure 8 Entering a topic on the Subscribe page of device B
    3. Let device A send a message to device B. On the Publish page of device A, enter the topic /test/M2M/${Any word}. Enter the message to be sent (for example, hello) in the text box, and click Publish.
      Figure 9 Entering a message on the Publish page of device A
      On the Subscribe page of device B, you can see the received message, as shown in the following figure.
      Figure 10 Subscribe page of device B
