Registering an Individual Device
A device is a physical entity that belongs to a product. Each device has a unique ID. It can be a device directly connected to the platform, or a gateway that connects child devices to the platform. You can register a physical device with the platform, and use the device ID and secret allocated by the platform to connect your SDK-integrated device to the platform.
The platform allows an application to call the API Creating a Device to register an individual device. Alternatively, you can register an individual device on the IoTDA console. This topic describes the procedure on the IoTDA console.
- Access the IoTDA service page and click Access Console. Click the target instance card.
- In the navigation pane, choose Devices > All Devices. On the displayed page, click Register Device, set parameters based on the table below, and click OK.
Figure 1 Device - Registering a secret device
Table 1 Registering a device with secret Parameter
Resource Space
Select the resource space to which a device belongs.
Product
Select the product to which the device belongs.
You can select a product only after it is defined. If no product is available, create a product by following the instructions provided in Product Creation.
Node ID
Set this parameter to the IMEI, MAC address, or serial number of the device. If the device is not a physical one, set this parameter to a custom string that contains letters, digits, hyphens (-), and underscores (_).
Device ID
Enter a unique device ID. If this parameter is carried, the platform will use the parameter value as the device ID. Otherwise, the platform will allocate a device ID, which is in the format of product_id_node_id.
Device Name
Customize the name of the device.
Customize device description.
Authentication Type
- Secret: The device uses the secret for identity verification.
- X.509 certificate: The device uses an X.509 certificate for identity verification.
Secret
Customize the secret used for device access. If the secret is left blank, the platform automatically generates one.
Fingerprint
This parameter is displayed when Authentication Type is set to X.509 certificate. Import the fingerprint corresponding to the preset device certificate on the device side. You can run openssl x509 -fingerprint -sha256 -in deviceCert.pem in the OpenSSL view to query the fingerprint.
Delete the colons (:) from the obtained fingerprint when filling it.
Save the device ID and secret. They are used for authentication when the device attempts to access the platform.
Figure 2 Device registeredIf the secret is lost, you can update the secret. The secret generated during device registration cannot be retrieved.
You can delete a device that is no longer used from the device list. Deleted devices cannot be retrieved. Exercise caution when performing this operation.
