Reports
IoTDA has various dashboards to intuitively present data.
In the navigation pane of the IoTDA console, choose Overview. The multiple reports displayed are from collected data of each instance and are valid for one month. The following table describes each report's name and function.
Report Name |
Description |
Data Update |
Time Frame |
Registered Devices |
Number of registered devices. |
Every hour |
Hour, day, and month |
Online Devices |
Number of online devices. This number is the highest collected in the time period (by hour or by day). |
Every hour |
Device Messages |
Number of device messages in either direction. Upstream messages are involved in message, property, and event reporting. Downstream messages are involved in message and command delivery, and property setting and query. Supported by the basic and enterprise editions. |
Every hour |
Upstream Message TPS |
Highest throughput of upstream messages per second, that is, the total number of messages sent from all devices to the platform in an instance per second. Only MQTT messages can be reported. The chart data comes from the average value every ten seconds. Supported by the standard edition. |
Every minute |
10 minutes, 30 minutes, 1 hour, or 1 day |
User Messages |
Number of user messages. This is mainly messages sent from devices to the cloud and vice versa. Any forward messages in excess of the messages sent from devices to the cloud are also counted. |
Every hour |
In the navigation pane of the IoTDA console, choose O&M > Reports to see multiple O&M reports. Click the + icon in the upper right corner of a report to view data by instance or resource space. Each report is valid for one month. The following table describes each report's name and function.
Report Name |
Description |
Data Update |
Time Frame |
Device Connection Status |
Number of devices (and percentage of total number of devices) in each status. Statuses: Online, Inactive, Offline, Abnormal |
Every hour |
Device Messages |
Messages reported: number of messages reported by devices to the platform. Downstream messages: number of messages delivered by the platform to devices. |
Every hour |
Hour and day |
MQTT Reported Messages TPS |
Maximum number of upstream requests sent by MQTT devices to the platform per second in the current instance. The chart data comes from the average value every ten seconds. Supported by the standard edition. |
Every minute |
MQTT Concurrent Connection Setup TPS |
The most new connection requests from MQTT devices per second. The chart data comes from the average value every ten seconds. Supported by the standard edition. |
Every minute |
General Device Trends |
Trends in the number of devices. Total and online devices counted separately. |
Every hour |
Hour and day |
Device Online Trends |
Trends in the number (and percentage of total number devices) of devices. Online and offline devices counted separately. |
Every hour |
Hour and day |
Devices by Status |
Trends in the number of devices in each status. Statuses: Inactive, Abnormal, Offline |
Every hour |
Hour and day |
Number of Online Devices (Accumulated) |
Total number of online devices. Supported by the standard edition. |
Every hour |
Hour and day |
Software Upgrade Statuses |
Number of upgrades of device software from the start. Successful and failed upgrades counted separately. |
Every hour |
Firmware Upgrade Statuses |
Number of upgrades of device firmware from the start. Successful and failed upgrades counted separately. |
Every hour |
Device Configuration Statuses |
Number of updates of device configuration from the start. Successful and failed updates counted separately. |
Every hour |
For more reports, log in to the AOM console, and choose Monitoring > Cloud Service Monitoring > IoT > IoT Device Access (IoTDA). Currently, AOM shows you the IoTDA monitoring information by instance or resource space.
Report Name |
Description |
Data Update |
Time Frame |
Device Status |
Number of devices in each status. Statuses: Online, Inactive, Offline, Abnormal. |
Every 10 minutes |
1 hour, 6 hours, 12 hours, 1 day, or 7 days |
Trends in the number of devices. Total, online, and offline devices counted separately. |
Every 10 minutes |
Data Transfer Trend |
Trends in the number of data transfers. AMQP transfers and HTTP message pushes counted separately. |
Every minute |
Data Report Trend |
Trends in the number of reporting records. Reporting of NB-IoT data, MQTT events, MQTT properties, and MQTT messages counted separately. |
Every minute |
Report Name |
Description |
Data Update |
Time Frame |
Total Devices |
Trends in the total number of devices and the number of devices in each status. Statuses: Online, Offline, Abnormal, Inactive |
Every 10 minutes |
Reported NB Data Records |
Trends in the number of NB-IoT data reporting records. Total, successful, and failed reporting counted separately. |
Every minute |
Reported MQTT Events |
Trends in the number of MQTT event reporting records. Total, successful, and failed reporting counted separately. |
Every minute |
Reported MQTT Properties |
Trends in the number of MQTT property reporting records. Total, successful, and failed reporting counted separately. |
Every minute |
Reported MQTT Messages |
Trends in the number of MQTT message reporting records. Total, successful, and failed reporting counted separately. |
Every minute |
AMQP Transfers |
Trends in the number of AMQP transfers. Total, successful, and failed transfers counted separately. |
Every minute |
FunctionGraph Transfers |
Trends in the number of FunctionGraph transfers. Total, successful, and failed transfers counted separately. |
Every minute |
MRS Kafka Transfers |
Trends in the number of MRS Kafka transfers. Total, successful, and failed transfers counted separately. |
Every minute |
MQTT Transfers |
Trends in the number of MQTT transfers. Total, successful, and failed transfers counted separately. |
Every minute |
MySQL Transfers |
Trends in the number of MySQL transfers. Total, successful, and failed transfers counted separately. |
Every minute |
InfluxDB Transfers |
Trends in the number of InfluxDB transfers. Total, successful, and failed transfers counted separately. |
Every minute |
HTTP Message Pushes |
Trends in the number of HTTP message pushes. Total, successful, and failed pushes counted separately. |
Every minute |
OBS Transfers |
Trends in the number of OBS transfers. Total, successful, and failed transfers counted separately. |
Every minute |
DMS Kafka Transfers |
Trends in the number of DMS for Kafka transfers. Total, successful, and failed transfers counted separately. |
Every minute |
DIS Transfers |
Trends in the number of DIS transfers. Total, successful, and failed transfers counted separately. |
Every minute |
ROMA Transfers |
Trends in the number of ROMA Connect transfers. Total, successful, and failed transfers counted separately. |
Every minute |
LTS Transfers |
Trends in the number of LTS transfers. Total, successful, and failed transfers counted separately. |
Every minute |
BCS Huawei Cloud Blockchain Transfers |
Trends in the number of BCS Huawei Cloud Blockchain transfers. Total, successful, and failed transfers counted separately. |
Every minute |
BCS-Hyperledger Fabric Enhanced Edition Transfers |
Trends in the number of BCS-Hyperledger Fabric Enhanced Edition transfers. Total, successful, and failed transfers counted separately. |
Every minute |
MongoDB Transfers |
Trends in the number of MongoDB transfers. Total, successful, and failed transfers counted separately. |
Every minute |
To obtain report data using an AOM API, see Querying Monitoring Data. The following tables show the details about custom parameters of IoTDA metrics. In Table 5, Name corresponds to metrics[].metric.dimensions[].name and Value to metrics[].metric.dimensions[].value. In Table 6, Namespace corresponds to metrics[].metric.namespace and MetricName to metrics[].metric.metricName.
Name |
Value |
app |
Resource space ID |
instance |
Instance ID |
taskType |
Task type: software upgrade status (softwareUpgrade), firmware upgrade status (firmwareUpgrade), and device configuration status (deviceConfig) |
Report Name |
Namespace |
MetricName |
Total Devices |
IoTDA.DEVICE_STATUS |
Total number of devices: iotda_device_status_totalCount |
Number of online devices: iotda_device_status_onlineCount |
Number of offline devices: iotda_device_status_offlineCount |
Number of abnormal devices: iotda_device_status_abnormalCount |
Number of inactive devices: iotda_device_status_inactiveCount |
IoTDA.NB_DATA_REPORT |
Total number of reported NB-IoT data records: iotda_south_dataReport_totalCount |
Number of NB-IoT data reporting successes: iotda_south_dataReport_successCount |
Number of NB-IoT data reporting failures: iotda_south_dataReport_failedCount |
IoTDA.EVENT_UP |
Total number of reported MQTT event records: iotda_south_eventUp_totalCount |
Number of MQTT event reporting successes: iotda_south_eventUp_successCount |
Number of MQTT event reporting failures: iotda_south_eventUp_failedCount |
IoTDA.PROPERTIES_REPORT |
Total number of reported MQTT property records: iotda_south_propertiesReport_totalCount |
Number of MQTT property reporting successes: iotda_south_propertiesReport_successCount |
Number of MQTT property reporting failures: iotda_south_propertiesReport_failedCount |
IoTDA.MESSAGE_UP |
Total number of reported MQTT message records: iotda_south_messageUp_totalCount |
Number of MQTT message reporting successes: iotda_south_messageUp_successCount |
Number of MQTT message reporting failures: iotda_south_messageUp_failedCount |
AMQP Transfers |
IoTDA.AMQP_FORWARDING |
Total number of AMQP transfers: iotda_amqp_forwarding_totalCount |
Number of successful AMQP transfers: iotda_amqp_forwarding_successCount |
Number of failed AMQP transfers: iotda_amqp_forwarding_failedCount |
IoTDA.FUNCTIONGRAPH_FORWARDING |
Total number of FunctionGraph transfers: iotda_functionGraph_forwarding_totalCount |
Number of successful FunctionGraph transfers: iotda_functionGraph_forwarding_successCount |
Number of failed FunctionGraph transfers: iotda_functionGraph_forwarding_failedCount |
IoTDA.MRS_KAFKA_FORWARDING |
Total number of MRS Kafka transfers: iotda_mrsKafka_forwarding_totalCount |
Number of successful MRS Kafka transfers: iotda_mrsKafka_forwarding_successCount |
Number of failed MRS Kafka transfers: iotda_mrsKafka_forwarding_failedCount |
MQTT Transfers |
IoTDA.MQTT_FORWARDING |
Total number of MQTT transfers: iotda_mqtt_forwarding_totalCount |
Number of successful MQTT transfers: iotda_mqtt_forwarding_successCount |
Number of failed MQTT transfers: iotda_mqtt_forwarding_failedCount |
MySQL Transfers |
IoTDA.MYSQL_FORWARDING |
Total number of MySQL transfers: iotda_mysql_forwarding_totalCount |
Number of successful MySQL transfers: iotda_mysql_forwarding_successCount |
Number of failed MySQL transfers: iotda_mysql_forwarding_failedCount |
IoTDA.INFLUXDB_FORWARDING |
Total number of InfluxDB transfers: iotda_influxDB_forwarding_totalCount |
Number of successful InfluxDB transfers: iotda_influxDB_forwarding_successCount |
Number of failed InfluxDB transfers: iotda_influxDB_forwarding_failedCount |
IoTDA.HTTP_FORWARDING |
Total number of HTTP message push transfers: iotda_http_forwarding_totalCount |
Number of successful HTTP message push transfers: iotda_http_forwarding_successCount |
Number of failed HTTP message push transfers: iotda_http_forwarding_failedCount |
OBS Transfers |
IoTDA.OBS_FORWARDING |
Total number of OBS transfers: iotda_obs_forwarding_totalCount |
Number of successful OBS transfers: iotda_obs_forwarding_successCount |
Number of failed OBS transfers: iotda_obs_forwarding_failedCount |
IoTDA.DMS_KAFKA_FORWARDING |
Total number of DMS for Kafka transfers: iotda_dmsKafka_forwarding_totalCount |
Number of successful DMS for Kafka transfers: iotda_dmsKafka_forwarding_successCount |
Number of failed DMS for Kafka transfers: iotda_dmsKafka_forwarding_failedCount |
DIS Transfers |
IoTDA.DIS_FORWARDING |
Total number of DIS transfers: iotda_dis_forwarding_totalCount |
Number of successful DIS transfers: iotda_dis_forwarding_successCount |
Number of failed DIS transfers: iotda_dis_forwarding_failedCount |
ROMA Transfers |
IoTDA.ROMA_FORWARDING |
Total number of ROMA Connect transfers: iotda_roma_forwarding_totalCount |
Number of successful ROMA Connect transfers: iotda_roma_forwarding_successCount |
Number of failed ROMA Connect transfers: iotda_roma_forwarding_failedCount |
LTS Transfers |
IoTDA.LTS_FORWARDING |
Total number of LTS transfers: iotda_lts_forwarding_totalCount |
Number of successful LTS transfers: iotda_lts_forwarding_successCount |
Number of failed LTS transfers: iotda_lts_forwarding_failedCount |
IoTDA.BCS_HW_FORWARDING |
Total number of BCS Huawei Cloud blockchain transfers: iotda_bcshw_forwarding_totalCount |
Number of successful BCS Huawei Cloud blockchain transfers: iotda_bcshw_forwarding_successCount |
Number of failed BCS Huawei Cloud blockchain transfers: iotda_bcshw_forwarding_failedCount |
IoTDA.BCS_FABRIC_FORWARDING |
Total number of BCS-Hyperledger Fabric Enhanced Edition transfers: iotda_bcsfabric_forwarding_totalCount |
Number of successful BCS-Hyperledger Fabric Enhanced Edition transfers: iotda_bcsfabric_forwarding_successCount |
Number of failed BCS-Hyperledger Fabric Enhanced Edition transfers: iotda_bcsfabric_forwarding_failedCount |
MongoDB Transfers |
IoTDA.MONGODB_FORWARDING |
Total number of MongoDB transfers: iotda_mongodb_forwarding_totalCount |
Number of successful MongoDB transfers: iotda_mongodb_forwarding_successCount |
Number of failed MongoDB transfers: iotda_mongodb_forwarding_failedCount |
Software and Firmware Upgrades/Remote Configuration |
AOM.IoTDA |
Number of successes: count: iotda_batchtask_success_count |
Number of failures: iotda_batchtask_failure_count |
