HTTPS Access
Overview
Hypertext Transfer Protocol Secure (HTTPS) is a secure communication protocol based on HTTP and encrypted using SSL. IoTDA supports communication through HTTPS.
Description |
Limit |
Supported HTTP version |
HTTP 1.0 HTTP 1.1 |
Supported HTTPS |
The platform supports only the HTTPS protocol. For details about how to download a certificate, see Certificates. |
Supported TLS version |
TLS 1.2 |
Body length |
1 MB |
API specifications |
Number of child devices of which properties can be reported by a gateway at a time |
50 |
API Calling
For details about the platform endpoint, see Platform Connection Information.
Use the endpoint of IoTDA and the HTTPS port number 443.
Communication Between HTTPS Devices and the Platform
When a device connects to the platform through HTTPS, HTTPS APIs are used for their communication. These APIs can be used for device authentication as well as message and property reporting.
Message Type |
Description |
Device authentication |
Devices obtain access tokens. |
Device reporting properties |
Devices report property data to IoTDA in the format defined in the product model. |
Device reporting messages |
Devices report custom data to IoTDA, which then forwards reported messages to an application or other Huawei Cloud services for storage and processing. |
Gateway reporting device properties in batches |
A gateway reports property data of multiple child devices to the platform. |
Service Flow
- Create a product on the IoTDA console or by calling the API for creating a product.
- Register a device on the IoTDA console or calling the API for creating a device.
- Call the device authentication API to obtain the access token of the device.
Figure 1 Obtaining the access token
- The obtained access token can be used by devices to report messages and properties. The access token is in the message header. The following uses property reporting as an example.
Figure 2 Reporting propertiesFigure 3 Reporting properties
HTTP APIs
The following table describes the platform APIs.
API Category |
API |
API |
Description |
Device authentication API |
/v5/device-auth |
This API is used to authenticate a device. Connections can be established between devices and IoTDA after successful authentication. After the authentication is successful, IoTDA returns an access token. An access token is required when APIs for property reporting and message reporting are called. If an access token expires, you need to authenticate the device again to obtain an access token. If you obtain a new access token before the old one expires, the old access token will be valid for 30 seconds before expiration. |
Device message reporting API |
/v5/devices/{device_id}/sys/messages/up |
This API is used by a device to report custom data to IoTDA, which then forwards reported messages to an application or other Huawei Cloud services for storage and processing. |
Device property reporting APIs |
/v5/devices/{device_id}/sys/properties/report |
This API is used by a device to report property data in the format defined in the product model to IoTDA. |
/v5/devices/{device_id}/sys/gateway/sub-devices/properties/report |
This API is used to report device data in batches to IoTDA. A gateway can use this API to report the property data of a maximum of 50 child devices at the same time. |
Device Authentication API
This API is used to authenticate a device. After successful authentication, connections can be established between devices and IoTDA, and the platform returns an access token. The access token is required when APIs for property reporting and message reporting are called. If an access token expires, you need to authenticate the device again to obtain an access token. If you obtain a new access token before the old one expires, the old access token will be valid for 30 seconds before expiration.
Request Method |
POST |
URI |
/v5/device-auth |
Transport Protocol |
HTTPS |
Parameter |
Mandatory |
Type |
Location |
Description |
device_id |
Yes |
String |
Body |
Device ID, which uniquely identifies a device. The value of this parameter is specified during device registration or allocated by IoTDA. If the value is allocated by the platform, the value is in the format of [product_id]_[node_id]. The value is a string of no more than 128 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed. Value length: 1 to 128 characters |
sign_type |
Yes |
Integer |
Body |
Password verification mode. 0: When the timestamp is verified using the HMAC-SHA256 algorithm, IoTDA does not check whether the message timestamp is consistent with the IoTDA time but only checks whether the password is correct. 1: When the timestamp is verified using the HMAC-SHA256 algorithm, IoTDA checks whether the message timestamp is consistent with the IoTDA time and then checks whether the password is correct. Value range: 0 to 1 |
timestamp |
Yes |
String |
Body |
The timestamp is the UTC time when the device was connected to IoTDA, in the format of YYYYMMDDHH. For example, if the UTC time is 2018/7/24 17:56:20, the timestamp is 2018072417. Value length: a fixed length of 10 characters |
password |
Yes |
String |
Body |
The value of this parameter is the value of the device secret signed by using the HMAC-SHA256 algorithm with the timestamp as the key. For details, see the secret generation tool. The device secret is returned by IoTDA upon successful device registration. Value length: a fixed length of 64 characters |
Parameter |
Type |
Description |
access_token |
String |
Device token, which is used for device authentication. Value length: 32 to 256 characters |
expires_in |
Integer |
Remaining validity period of the authentication information, in seconds. |
Request example:
POST https://{endpoint}/v5/device-auth Content-Type: application/json { "device_id" : "********", "sign_type" : 0, "timestamp" : "2019120219", "password" : "********" }
Response example:
Status Code: 200 OK
Content-Type: application/json { "access_token" : "********", "expires_in" : 86399 }
HTTP Status Code |
Description |
Error Code |
Error Message |
Error Description |
200 |
OK |
400 |
Bad Request |
IOTDA.000006 |
Invalid input data. |
Invalid request parameters. |
401 |
Unauthorized |
IOTDA.000002 |
Authentication failed. |
403 |
Forbidden |
IOTDA.021101 |
Request reached the maximum rate limit. |
The request frequency has reached the upper limit. |
IOTDA.021102 |
The request rate has reached the upper limit of the tenant, limit %s. |
The request frequency has reached the upper limit of the tenant. |
Device Message Reporting
Request Method |
POST |
URI |
HTTPS |
Parameter |
Mandatory |
Type |
Location |
Description |
access_token |
Yes |
String |
Header |
Access token returned after the device authentication API is called. Value length: 1 to 256 characters |
device_id |
Yes |
String |
Path |
This API allows a device to use a request body to report custom data to IoTDA, which then forwards the body content to applications or other Huawei Cloud services for storage and processing. IoTDA has no specific format requirements on the body content. This API can carry data whose size is smaller than 1 MB.
Request example:
POST https://{endpoint}/v5/devices/{device_id}/sys/messages/up Content-Type: application/json access_token: ******** { "name" : "name", "id" : "id", "content" : "messageUp" }
Response example:
Status Code: 200 ok
HTTP Status Code |
Description |
Error Code |
Error Message |
Error Description |
200 |
OK |
400 |
Bad Request |
IOTDA.000006 |
401 |
Unauthorized |
IOTDA.000002 |
403 |
Forbidden |
IOTDA.000004 |
Invalid access token. |
Invalid token. |
IOTDA.021101 |
IOTDA.021102 |
Device Property Reporting
Request Method |
POST |
URI |
HTTPS |
Parameter |
Mandatory |
Type |
Location |
Description |
access_token |
Yes |
String |
Header |
device_id |
Yes |
String |
Path |
services |
Yes |
List<Table 1> |
Body |
Device service data list. |
Parameter |
Mandatory |
Type |
Description |
service_id |
Yes |
String |
Service ID of the device. |
properties |
Yes |
Object |
Service properties, which are defined in the product model of the device. |
event_time |
No |
String |
UTC time when the device collects data. The value is in the format of yyyy-MM-dd'T'HH:mm:ss.SSS'Z'. If this parameter is not carried in the reported data or is in an incorrect format, the time when IoTDA receives the data is used. |
Example request:
POST https://{endpoint}/v5/devices/{device_id}/sys/properties/report Content-Type: application/json access_token: ******** { "services" : [ { "service_id" : "serviceId", "properties" : { "Height" : 124, "Speed" : 23.24 }, "event_time" : "2021-08-13T10:10:10.555Z" } ] }
Response example:
If the status code is 200, reporting is successful.
HTTP Status Code |
Description |
Error Code |
Error Message |
Error Description |
200 |
OK |
400 |
Bad Request |
IOTDA.000006 |
IOTDA.021104 |
Subdevices in the request does not exist or does not belong to the gateway. |
Some child devices in the request do not exist or do not belong to the gateway. |
403 |
Forbidden |
IOTDA.000004 |
Invalid token. |
IOTDA.021101 |
IOTDA.021102 |
IOTDA.021105 |
The content reported in a single request cannot exceed 1 MB. |
Gateway Reporting Child Device Property
Request Method |
POST |
URI |
HTTPS |
Parameter |
Mandatory |
Type |
Location |
Description |
access_token |
Yes |
String |
Header |
device_id |
Yes |
String |
Path |
devices |
Yes |
List<Table 2> |
Body |
Device data list. Value length: 50 characters at most |
Parameter |
Mandatory |
Type |
Description |
device_id |
Yes |
String |
ID of the child device, which is unique and is allocated by IoTDA during device registration. The value is a string of no more than 128 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed. |
services |
Yes |
List<Table 3> |
Parameter |
Mandatory |
Type |
Description |
service_id |
Yes |
String |
properties |
Yes |
Object |
event_time |
No |
String |
An example request is as follows:
POST https://{endpoint}/v5/devices/{device_id}/sys/gateway/sub-devices/properties/report Content-Type: application/json access_token: ******** { "devices" : [ { "device_id" : "deviceId_0001", "services" : [ { "service_id" : "serviceId", "properties" : { "Height" : 124, "Speed" : 23.24 }, "event_time" : "2021-08-13T10:10:10.555Z" } ] }, { "device_id" : "deviceId_0002", "services" : [ { "service_id" : "serviceId", "properties" : { "Height" : 124, "Speed" : 23.24 }, "event_time" : "2021-08-13T10:10:10.555Z" } ] } ] }
Response example:
HTTP Status Code |
Description |
Error Code |
Error Message |
Error Description |
200 |
OK |
400 |
Bad Request |
IOTDA.000006 |
IOTDA.021104 |
401 |
Unauthorized |
IOTDA.000002 |
403 |
Forbidden |
IOTDA.000004 |
Invalid token. |
IOTDA.021101 |
IOTDA.021102 |
IOTDA.021103 |
The number of child devices in the request has reached the upper limit (%s). |
The number of child devices in the request reaches the upper limit. |
IOTDA.021105 |
