Updated on 2025-08-14 GMT+08:00
Operation Guide
The operations of cloud services that can be deployed in IEC HomeZones are basically the same as those of the original cloud services. Cloud services can be classified into three types:
  1. Cloud services related to AZs. When purchasing this type of cloud services, you need to select HomeZones for AZ Type. For details about other configurations, see the operation guide of the corresponding cloud service. For example, Elastic Cloud Server (ECS) and Elastic Volume Service (EVS).
  2. Region-level cloud services that are irrelevant to AZs. When purchasing this type of cloud services, you do not need to select HomeZones. You only need to perform operations by referring to the operation guide of the corresponding cloud service. For example, Host Security Service (HSS) and Web Application Firewall (WAF).
  3. Network cloud services. When using this type of services, you need to select options related to local lines. For details, see the operation guide of the corresponding cloud service. For example, Elastic IP (EIP).
Cloud Services Related to AZs
When purchasing a cloud service related to AZs, you must set AZ Type to HomeZones. For details about other operations, see the purchase or creation guide of the corresponding cloud service.
Table 1 Cloud services related to AZs
Service Name
Operation Guide
Set AZ Type to HomeZones.
Purchasing and Using an ECS
Purchasing an EVS Disk
Cloud Container Engine (CCE)
  • When you purchase a CCE cluster, select CCE Turbo Cluster for Type.
  • In the Network Settings area, select the VPC of the parent region for VPC. Select the subnet of the central AZ where the cluster is deployed for Default Node Subnet.
  • After a container cluster is created, you need to deploy container nodes and storage resources in the HomeZones.
  • In the Node Configuration area, select the corresponding HomeZones for Node Type.
  • Create a PersistentVolumeClaim (PVC) and select the corresponding HomeZones.
For details about other configurations, see the Cloud Container Engine User Guide.
Buying a CCE Standard/Turbo Cluster
Cloud Services Irrelevant to AZs
When purchasing region-level cloud services that are irrelevant to AZs, see the operation guide of the corresponding cloud service.
Table 2 Purchasing cloud services irrelevant to AZs
Service Name
Operation Guide
Purchasing and Enabling HSS
Buying a Cloud WAF Instance
Purchasing or Creating Network Cloud Services
Table 3 Operation guide for purchasing network cloud services
Service Name
Operation Guide
Elastic IP (EIP)
When purchasing an EIP, you need to select HomeZones for EIP Type, that is, the line corresponding to the local city or region After you specify the HomeZones, the corresponding network border group is displayed.
For details about other configurations, see the Elastic IP User Guide.
Assigning an EIP
Virtual Private Cloud (VPC)
When creating a VPC, you do not need to specify the HomeZones. When configuring a subnet of the VPC, you need to select HomeZones for AZ Type.
For details about other configurations, see the Virtual Private Cloud User Guide.
Creating a VPC and Subnet
When purchasing a Direct Connect connection, set Location to the region where the IEC HomeZones is located.
For details about other configurations, see the Direct Connect User Guide.
Creating a Connection
To enable communication between the parent region AZ and IEC HomeZones, you need to create an edge gateway and bind the edge connection of the edge gateway to the global connection bandwidth of Cloud Connection.
  • On the Huawei Cloud console, go to the Cloud Connections page. In the navigation pane on the left, choose Intra-Cloud > Global Connection Bandwidths. Click Buy Global Connection Bandwidth in the upper right corner.
  • Bandwidth Type: Select HomeZones.
  • Specify Region as required.
For details about other configurations, see the Cloud Connect User Guide.
Buying a Global Connection Bandwidth
Elastic Load Balance (ELB)
When buying a load balancer, select the parent region for which the HomeZones permissions has been granted, and select the HomeZones you desire.
For details about other configurations, see the Elastic Load Balance User Guide.
Creating a Dedicated Load Balancer
Virtual Private Network (VPN)
When purchasing an S2C VPN gateway, select HomeZones for AZ. Then the value of EIP Type can only be HomeZones.
For details about other configurations, see the Virtual Private Network User Guide.
Creating a VPN Gateway
