Updated on 2025-07-21 GMT+08:00
Multi-level Memory Reclamation Policy
Background
In high-density hybrid container deployments, offline services with a large number of I/O reads and writes consume a large amount of page cache. As a result, the idle memory of the system decreases, and memory reclamation is triggered when the idle memory watermark is reached. Online tasks enter the slow path for memory reclamation when applying for memory, causing latency and jitter.
To solve this problem, HCE 2.0 provides multi-level memory reclamation. You can set a memory warning value to trigger a memory reclamation task, which ensures available memory space. For memory reclamation, you can set multiple levels of memory protection watermarks to protect task availability.
memory.min and memory.low take effect only on leaf cgroups. When a memory cgroup is created, memory.min and memory.low of the parent cgroup are cleared.
Interface Description
The memory.min, memory.low, and memory.high interfaces exist in the non-root memory cgroup by default. You can write values to the files or read the current configuration. The proper value sequence is memory.min ≤ memory.low < memory.high. The three values can be used independently or together.
The following figure shows the memory reclamation mechanism.
Figure 1 Memory reclamation mechanism
Table 1 Interface parameters
Interface
memory.min
Specifies the minimum amount of memory the cgroup must always retain. The default value is 0. Even if there is no memory that can be reclaimed, the system will not reclaim the memory that is less than or equal to the value of this parameter. The read and write operations are described as follows:
  • Reading this interface can view the size (in byte) of the protection memory.
  • Writing to this interface can set the size of the protection memory. The unit is not limited.
  • The value ranges from 0 to memory.limit_in_bytes.
memory.low
Specifies the best-effort memory protection. The default value is 0.
The system preferentially reclaims the memory of unprotected cgroups. If the memory is still insufficient, the system reclaims the memory between memory.min and memory.low.
  • Reading this interface can view the best-effort memory protection value, in bytes.
  • Writing to this interface can set the best-effort memory protection value. The unit is not limited.
memory.high
Specifies the memory reclamation warning. The default value is max. When the memory usage of a cgroup reaches the high value, a synchronous memory reclamation task is triggered for the cgroup and its child cgroups. The memory is limited to a value lower than the high value to prevent OOM caused by the memory limit. The read and write operations are described as follows:
  • Reading this interface can view the Throttle limit, in bytes.
  • Writing to this interface can set the Throttle limit. The unit is not limited.
Interface Configuration Example
Create cgroups A, B, C, D, E and F and configure the memory.min interface.
Figure 2 Multi-level memory reclamation
Table 2 Data planning
cgroup
memory.min
memory.usage_in_bytes
A
200M
0
B
0
C
75M
50M
D
25M
50M
E
0
50M
F
125M
  1. Create cgroup A and set memory.limit_in_bytes to 200M.
    mkdir /sys/fs/cgroup/memory/A
    echo 200M > /sys/fs/cgroup/memory/A/memory.limit_in_bytes
  2. Create cgroup B.
    mkdir /sys/fs/cgroup/memory/A/B
  3. Create cgroup C, set memory.min to 75M, and create a process that will use 50-MB cache in the cgroup.
    mkdir /sys/fs/cgroup/memory/A/B/C
    echo 75M > /sys/fs/cgroup/memory/A/B/C/memory.min
  4. Create cgroup D, set memory.min to 25M, and create a process that will use 50-MB cache in the cgroup.
    mkdir /sys/fs/cgroup/memory/A/B/D
    echo 25M > /sys/fs/cgroup/memory/A/B/D/memory.min
  5. Create cgroup E, set memory.min to 0, and create a process that will use 50-MB cache in the cgroup.
    mkdir /sys/fs/cgroup/memory/A/B/E
  6. Create cgroup F, set memory.min to 125M, and request 125-MB cache for memory protection.
    mkdir /sys/fs/cgroup/memory/A/F
    echo 125M > /sys/fs/cgroup/memory/A/F/memory.min
Information similar to the following is displayed:
cgroup C: memory.min=75M, memory.usage_in_bytes=50M
cgroup D: memory.min=25M, memory.usage_in_bytes=25M
cgroup E: memory.min=0, memory.usage_in_bytes=0
cgroup B: memory.usage_in_bytes=75M
