- What's New
- Function Overview
- Billing
- Getting Started
- User Guide
Best Practices
- Using Global Accelerator to Speed Up Cross-Border Access to Web Servers
- Using CDN and Global Accelerator to Speed Up Cross-Border Access
- Using Global Accelerator to Speed Up Cross-Border Access to Third-Party On-premises Servers
- Using Global Accelerator to Accelerate Communications Between Cloud and On-Premises Servers and Implement Multi-active DR
- Transferring the Source IP Address of a Client
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Global Accelerator
- Listener
- Endpoint Group
- Endpoint
- Health Check
IP Address Group
- Creating an IP Address Group
- Querying IP Address Groups
- Querying Details of an IP Address Group
- Updating an IP Address Group
- Deleting an IP Address Group
- Adding CIDR Blocks to an IP Address Group
- Removing CIDR Blocks from an IP Address Group
- Associating an IP Address Group with a Listener
- Disassociating an IP Address Group from a Listener
- Region
- Tag
- Log
- Appendix
- SDK Reference
- Can I Use the Ping Command to Test Latency?
- How Will I Be Billed for Global Accelerator?
- How Can I Increase the Global Accelerator Quotas?
- How Can I Use Traffic Dial to Distribute Traffic?
- What Types of Endpoints Can Be Added to a Global Accelerator?
- Can I Use Global Accelerator in an Area That Is Not Listed Among the Acceleration Areas?
- What Are the Statuses and Health Check Results of Endpoints?
- What Should I Do If an Endpoint Is Unhealthy?
- Most Frequently Asked Questions
- Configuring the TOA Module
- How Can I Use Global Accelerator to Enable European Users to Access the Applications Deployed in or Outside the Chinese Mainland (Excluding Europe) Faster?
Viewing Traces
After CTS is enabled, CTS starts recording operations on cloud resources. The CTS management console stores the last seven days of operation records.
This section describes how to query or export the last seven days of operation records on the management console.
- Click
in the upper left corner and select the desired region and project.
- In the upper left corner of the page, click
to go to the service list. Under Management & Governance, click Cloud Trace Service.
- In the navigation pane on the left, choose Trace List.
- Specify filters as needed. The following filters are available:
- Trace Type: Set it to Management or Data.
- Trace Source, Resource Type, and Search By
Select filters from the drop-down list.
If you select Trace name for Search By, select a trace name.
If you select Resource ID for Search By, select or enter a resource ID.
If you select Resource name for Search By, select or enter a resource name.
- Operator: Select a specific operator (a user other than an account).
- Trace Status: Select All trace statuses, Normal, Warning, or Incident.
- Search time range: In the upper right corner, choose Last 1 hour, Last 1 day, or Last 1 week, or specify a custom time range.
- Click arrow on the left of the required trace to expand its details.
- Locate the required trace and click View Trace in the Operation column.
A dialog box is displayed, showing the trace content.
