Configuring a Start Processor
The start node serves as the start of a function flow.
Notes and Constraints
- Function flows created in Data Workroom (DWR) can only be viewed on the FunctionGraph console; editing and deletion must be done within DWR.
- Each function flow must start with only one Start node and end with an End node.
- The start node must be followed by a node that is not stop or error handling.
- Only triggers can be configured for the Start node.
- Flow triggers include APIG (dedicated) and timer triggers.
- A flow can have a maximum of 10 triggers.
- Triggers must be included in the start node.
- Triggers cannot be connected to any other node.
Timer Trigger Configuration Description
Parameter | Description |
Trigger Type | Select Timer. |
Rule | Triggering rule of the timer. Currently, only cron expressions are supported. |
Cron Expression | Specifies the date and time when the flow will be scheduled. For details, see Cron Expression Rules. |
Additional Info | Must be in JSON format and contain an input. The value of input will be passed to the flow. |
APIG (Dedicated) Trigger Configuration Description
- APIG flow triggers support only IAM authentication.
- Ensure that you have created a dedicated gateway before this operation. For details, see Buying a Dedicated Gateway.
Trigger Type | Select API Gateway (dedicated). |
Gateway | Select a dedicated gateway. For details, see Creating a Gateway. |
API Group | An API group is a collection of APIs. You can manage APIs by API group. For details, see Creating an API Group. |
Environment | An API can be called in different environments, such as production, test, and development environments. APIG supports environment management, which allows you to define different request paths for an API in different environments. To ensure that the API can be called, select RELEASE. |
Visibility | Options:
Path | Path for requesting the API. Format: /users/projects |
Method | The API calling method. Options: GET, POST, DELETE, PUT, PATCH, HEAD, OPTIONS, and ANY. ANY indicates that the API can be called using any request method. |
